Old Sun, Jan-29-2006, 04:51:55 AM   #1
turb0charged
Reputation: 0 turb0charged is on a distinguished road
Default GC track/school coilovers vs. TEIN SS coilovers
i have an e36 m3 and i cant decide which coilover suspension kit i should get. ive heard a lot of great things about GC but there isnt much info on it on the web. (ie: how much i can lower the front and rear). while TEIN SS coilovers have 16 adjustable damping settings. Which one should i go for?
Jump to top turb0charged is offline   Reply With Quote
Old Sun, Jan-29-2006, 04:56:38 AM   #2
SG_M3
#56 JP M3
Reputation: 0 SG_M3 has disabled reputation
There is a ton of information about the GC kit, more than Tein.
What are you doing with the car? Tracking, autox, or street?
I will say GC or TCK are the best bang for the buck coilovers out there.
Sean
- 98 M3 EB/BLK
Jump to top SG_M3 is offline   Reply With Quote
Old Sun, Jan-29-2006, 07:34:44 AM   #3
turb0charged
is the GC setup easy to adjust height/damper settings? i cant find ne info on it on the web, if anyone have links please post it, i would appreciate it.
Old Sun, Jan-29-2006, 08:16:29 AM   #4
SG_M3
#56 JP M3
there is a ton of info on bf.c
The height is adjustment is probably the easiest on the market. No jamb perches or spanner wrenches. Just an allen key, you undo the set screw then turn the perch by hand.
Rebound is adjusted by using the koni knob on top of the front struts. Open the hood put the knob on the strut, turn.
The rear depends on what shocks you get. If you get the externally adjustable shocks you can just put the knob on top of the shock and turn it. If you get the internally adjustable shocks then you have to remove them from the car, remove the bumpstop, then compress the shock fully, and then turn it to adjust the rebound.
I can tell you everything you want to know about the GC kit, just ask.
Sean
- 98 M3 EB/BLK
Old Sun, Jan-29-2006, 09:55:08 PM   #5
95RogueM3
^Needs More Garage Space..
Reputation: 0 95RogueM3 has disabled reputation
Sean, do you actually tighten the allen-bolts on the adjuster? (I leave mine be as the spring should provide enough tension on the adjuster to keep it in place..unless you are getting airborne )
'98 M3 Sedan - Built 2JZ Swap - 915whp, 791wtq
'95 M3 - 37k Miles
Jump to top 95RogueM3 is offline   Reply With Quote
Old Sun, Jan-29-2006, 10:27:56 PM   #6
SG_M3
#56 JP M3
yes, i do tighten it down pretty snug. Just so I can't turn it by hand.
Sean
- 98 M3 EB/BLK
Old Sun, Jan-29-2006, 10:35:59 PM   #7
turb0charged
im about to purchase the GC kit, how come i dont get to choose my spring rate on the track/school package?
Old Sun, Jan-29-2006, 11:24:02 PM   #8
SG_M3
#56 JP M3
you do, just call them up and talk to someone at GC. Or you can call up Mpact and talk to someone there. www.mpactmotorsports.com
Sean
- 98 M3 EB/BLK
Old Mon, Jan-30-2006, 04:47:30 PM   #9
AMPowerJ
One mod leads to another ...
AMPowerJ's Avatar
Reputation: 0 AMPowerJ is on a distinguished road
I noticed that the bolt that holds the rear threaded perch for the spring was way loose on both sides the other day when I was adjusting my suspension. I have no idea how that happened but it wouldn't be a bad idea to check it.
2009 E90 M3 - LeMans Blue - Speed Cloth - 6 speed
ESS Tune - BMW Performance Exhaust - StopTech Trophy BBK - KW Clubsport Suspension - TE37SL Wheels
Jump to top AMPowerJ is offline   Reply With Quote
Old Mon, Jan-30-2006, 05:05:19 PM   #10
95RogueM3
A good thing to check if you have the bolt installed. Again, I dont see a situation in which the spring wont be able to provide adequate pressure onto the rear adjuster to not keep it from moving.
With my GC kit I dont:
-Tighten the allen bolts on the front adjuster
-Have a bolt installed through the rear adjuster
Ive had no troubles *knock on wood*..and it makes adjustments so much easier. :nixweiss:
'95 M3 - 37k Miles
TEIN Coilovers XKaLiBaR E46 M3 (2001-2006) 11 Fri, Aug-10-2007 04:14:26 PM
FS. Tein Coilovers mm28 Parts for Sale/Wanted 10 Mon, Jul-10-2006 06:03:10 AM
Tein Coilovers swizzreese Faults, Fixes and DIY 1 Thu, Jun-22-2006 09:52:34 PM
TEIN SS coilovers or H&R Coilovers mrmomoman E46 M3 (2001-2006) 5 Tue, Jun-08-2004 01:12:07 AM
GC Track/School Coilovers On the Way! AMPowerJ E36 M3 (1992-1999) 1 Wed, Sep-24-2003 11:45:09 PM
Discussing GC track/school coilovers vs. TEIN SS coilovers in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
