Old Tue, Feb-17-2015, 05:57:26 PM   #1
98M3csm
Reputation: 0 98M3csm is on a distinguished road
Default Torque Pro app
Has anyone used the Torque Pro app on their E36? I'm wondering if our old cars communicate enough information for it to be useful.
Thanks
Jump to top 98M3csm is offline   Reply With Quote
Old Tue, Feb-17-2015, 06:13:40 PM   #2
haus
haus's Avatar
Default Re: Torque Pro app
Yes and yes (assuming you're on OBDII, I don't know about the 95's). Emissions testing readiness indicators, fuel trims, stuff like that. It can read codes but I've always just used the Peake tool. For $5 (I think that's what I paid) it's kind of interesting to play around with, and in CA I'd say definitely for the readiness monitors, so you can be sure you'll be able to get a smog check before going in if you've recently pulled the battery or cleared codes.
But I found my cheap transceiver to be flaky (causing the program to freeze frequently) so I switched to an ultragauge.
'97 Cosmos (1 of thousands)
Old Wed, Feb-18-2015, 03:13:50 AM   #3
M3_Tiag
Reputation: 0 M3_Tiag is on a distinguished road
Check out my threads on the topic
Jump to top M3_Tiag is offline   Reply With Quote
Old Wed, Feb-18-2015, 12:41:43 PM   #4
NolliM3
NolliM3's Avatar
I can attest to it not working with the 95 model.
Old Wed, Feb-18-2015, 02:47:23 PM   #5
M3n00b
M3n00b's Avatar
North Korea
Yes! It's a little slow but works well.
Old Wed, Feb-18-2015, 06:54:41 PM   #6
m3hoon
m3hoon's Avatar
Reputation: 0 m3hoon is on a distinguished road
I use it paired to a $8 bluetooth Elm 327 on my 97. It has worked well so far for me especially to monitor coolant temp, but I agree ^^ it has a slight delay on gauge reading.
Jump to top m3hoon is offline   Reply With Quote
Old Wed, Feb-18-2015, 06:58:26 PM   #7
M3n00b
M3n00b's Avatar
North Korea
I have the same 327. I'm not sure if it's the old bus of the car or the adapter that causes the slowness? Going to try it on my wife's brand new cx5 and see.
Old Wed, Feb-18-2015, 07:28:05 PM   #8
haus
haus's Avatar
Torque has some preference settings about connection speed; see if there's anything in there as part of a recent update that might help as well.
Old Fri, Feb-20-2015, 02:33:25 AM   #9
Grimm5698
Reputation: 0 Grimm5698 is on a distinguished road
I've run Torque Pro for a while now, on my 98' M3. I mostly use it to data log information but i did have some problems with the first old obd2 adaptor "Gen 1", having to re-sync every time i ran the app and there was alot of lag while reading the sensors.
So i upgraded to a newer version "Gen 2" and it helped out a bit, did not have to re-sync anymore and there wasn't as much lag as before when data logging so i've been running that adaptor for a couple years now.
But a couple months ago i found a newer obd2 adaptor that claims very high read speeds for the PID's "up to 300%" faster than the cheap adaptors. Its sold by scantool.net - http://www.scantool.net/scan-tools/s...bdlink-lx.html , I haven't tested it yet but will be purchasing one soon as im finishing up my tablet installation and it would be awesome to finally get rid of the PID sensor lag and have instant readings specially while data logging.
Also from what i can remember pretty much all sensors are available except, oil pressure / oil temp / transmission temp. I contacted the creator of the app to see if he was gonna make the oil temp & oil pressure PID's available later on but he told me it was expensive to get BMW proprietary PID information and that most likely he would not be able to add those PID extensions.
Jump to top Grimm5698 is offline   Reply With Quote
Old Mon, Feb-23-2015, 11:06:48 PM   #10
M3_Tiag
^i wouldn't bother, our OBD port transmits max 3hz
Pretty easy to see in the torque app, you get about 3 updates per second
Discussing Torque Pro app in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
