Old Sat, Jun-07-2008, 08:13:45 PM   #1
bking
Reputation: 0 bking is on a distinguished road
Default Oil leak after oil change
I have only owned the car for about 6 weeks now, there was no leak before the change. Car has 41k miles on it, did the oil change 2 weeks ago. Took it back to my buddys shop who did the work last week and it fixed the leak for about a week but now its back. He said the drain plug is known to be pretty touchy, cant be too tight or else it will break. He tightened it more but now its leaking again, any ideas??
2002 BMW M3 6 speed: Dinan S Package, Dinan Signature wheels, Brembo Gran Turismo series brakes, UUC SSK
Jump to top bking is offline   Reply With Quote
Old Sat, Jun-07-2008, 08:23:13 PM   #2
doublearon20
Certified User
doublearon20's Avatar
Reputation: 0 doublearon20 is on a distinguished road
Did he put a new washer on? The filter should come with a new washer for every oil change. I normally tighten to about 15-20 ft lbs (a good snug after tightened by hand).
The land of the free, because of the brave.
Jump to top doublearon20 is offline   Reply With Quote
Old Sat, Jun-07-2008, 08:30:00 PM   #3
bking
Im not too sure since i wasn't down doing any work, i used the Mahle/Mann filter which im pretty sure includes the new washer as well as filter o-ring.
Common oil leak? Oil Pan or rear main seal? ///tonic E46 M3 (2001-2006) 54 Tue, Feb-22-2011 05:26:44 AM
Help Oil Leak on passenger side of oil pan. HareRee E46 M3 (2001-2006) 14 Sat, Dec-13-2008 12:05:09 AM
Oil leak from front of oil pan Pr0b1ty E46 M3 (2001-2006) 14 Fri, Sep-14-2007 08:33:54 PM
first oil change (low mileage oil service) and inspection 1 dt15 E46 M3 (2001-2006) 3 Wed, Aug-29-2007 02:41:16 PM
When to change the Rear Diff Oil & SMG Tranny Oil? Nominee E46 M3 (2001-2006) 8 Thu, Oct-05-2006 11:24:51 PM
Discussing Oil leak after oil change in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
