Old Mon, May-05-2008, 09:43:27 PM   #1
UKtRAINE3
Reputation: 0 UKtRAINE3 is on a distinguished road
Default E46 Oil Pan Gasket Leak and diff. leak.
Took the car to the stealer and they say that the oil pan gasket is leaking. However, when looking at it myself, there seems to be oil on the engine above the oil pan. Could be possible that the oil spayed up, but to me it seems that something else is leaking the oil. Are oil pan gaskets a common problem? I got 40k miles and it's a 2002. Stealer wants $1,200 to replace the gasket (8 hrs labor). Told them to go fcuk themselves.
Also, differential front seal is leaking fluid. They want $800... I could do this myself though, just going to be a b!tch without a lift. Anyone seen a DIY for this or done this themselves?? Is it difficult or are any special tools needed??
Jump to top UKtRAINE3 is offline   Reply With Quote
Old Mon, May-05-2008, 10:27:29 PM   #2
Str8///Left
Leave the others behind.
Str8///Left's Avatar
Reputation: 0 Str8///Left is on a distinguished road
for the oil leak, i would check the oil pressure relief valve first as it is more common to leak than the oil pan gasket. do a search in the forum. it's located on the side of the block just below the exhaust manifold on cylinder #6.
and the pinion diff seal. you have to drop the exhaust and drive shaft. i've done one, it wasn't that hard though if your not technically incline i would not attempt it. you might end up ruining your diff.
Jump to top Str8///Left is offline   Reply With Quote
Old Mon, May-05-2008, 10:42:35 PM   #3
UKtRAINE3
The pressure relief valve is what I originally thought it was, I still think that's what is leaking. Dealer doesn't think so however. I'll take a better look at it myself this weekend.
As for the diff. seal, if you say it's not too bad I think I'll go ahead and do it myself. Thanks for the help!
Old Mon, May-05-2008, 10:52:45 PM   #4
JeST
Old School
JeST's Avatar
Reputation: 0 JeST will become famous soon enough
China
remove the underpanel and take a light. You'll be able to see the plug. As I stated I believe in your previous post if you see a trail of oil originating from the plug then you have your culprit.
I haven't seen too many oil pan gaskets leak on our m3's. Maybe on a higher mileage E46. Diff seals leaking are actually pretty common checking them is as simple as flashing a light under the car and peaking at them.
Garage:
'05 Jet black ZCP 6spd M3
'94 Toyota Supra 6spd Red/Black
https://youtu.be/58MlI21LoGM
Gone:
'03 AW/Cinn e46 M3
'08 DTM B7 S4
'87 Mtech 1 S50 e30
'88 Hennarot e30 M3
'11 LeMans Blue/Chestnut Mtech 335d
'11 e70 VF stage 2 X5M
'08 Interlagos/Extended Fox Red e92 M3
'02 Steelgrey slicktop
Jump to top JeST is offline   Reply With Quote
Old Thu, Aug-06-2009, 12:20:20 AM   #5
cyounes
Reputation: 0 cyounes is on a distinguished road
The Stealer charged me today 808$ for replacing the Pinion and the other 2 axle seals.
Jump to top cyounes is offline   Reply With Quote
Old Thu, Aug-06-2009, 08:05:42 PM   #6
turbof128
Slow AutoxR
turbof128's Avatar
Reputation: 0 turbof128 is on a distinguished road
Just curious, how many miles do you have on the car?
Jump to top turbof128 is offline   Reply With Quote
diff, e46, gasket, leak, oil, pan
Common oil leak? Oil Pan or rear main seal? ///tonic E46 M3 (2001-2006) 54 Tue, Feb-22-2011 05:26:44 AM
Help Oil Leak on passenger side of oil pan. HareRee E46 M3 (2001-2006) 14 Sat, Dec-13-2008 12:05:09 AM
oil leak - valve cover gasket? flyingmachine E46 M3 (2001-2006) 4 Wed, Oct-01-2008 06:59:34 PM
Oil leak = head gasket (what's involved?) OBS3SSION E46 M3 (2001-2006) 6 Wed, Sep-03-2008 05:16:38 PM
Oil Pan Leak - Again. M3Malcolm E46 M3 (2001-2006) 0 Thu, Jan-25-2007 07:20:07 PM
Discussing E46 Oil Pan Gasket Leak and diff. leak. in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
