Old Thu, Sep-06-2007, 03:20:21 PM   #1
Pr0b1ty
Done and Done
Reputation: 0 Pr0b1ty is on a distinguished road
Default Oil leak from front of oil pan
I have an 02 (04/2002) m3 and noticed that my oil is leaking from the front left hand side of the oil pan. It is leaking fairly consistently and I am wondering what my options are.
1: Is this covered under the 100,000 miles all oil lubricated parts for my engine?
2: Is this a hard DIY?
3: how much am I looking at if not covered if I go through an Indy shop?
thanks for your help on this matter!
-Rob
Jump to top Pr0b1ty is offline   Reply With Quote
Old Thu, Sep-06-2007, 06:41:08 PM   #2
king-rb
dammmmmmmmit!
king-rb's Avatar
Germany
I've also been trying to identify an oil leak that appears to be coming from my oil pan as well. Sorry, i don't have any answers to your questions....just a free bump! Lol!
Old Thu, Sep-06-2007, 07:02:44 PM   #3
Satans Idol
Tag Restricted
Satans Idol's Avatar
Reputation: 0 Satans Idol is on a distinguished road
Are you sure its the oil pan??? When I was looking to buy I had a silver one I put on the lift and thought it had an oil pan leak. Turns out after cleaning it and running the engine it was the back of the head gasket. Needless to say I did not purchase that one. The best way to determine an oil leak is to clean off the engine, install some oil dye, run the vehicle for a day and look with a black light. You should be able to identify the source of the leak fairly quickly. My shop does this for about $40. Its a shame you aren't closer or I could help you out.
Jump to top Satans Idol is offline   Reply With Quote
Old Thu, Sep-06-2007, 07:06:07 PM   #4
Fastdog911
Fastdog911's Avatar
Reputation: 0 Fastdog911 has disabled reputation
chain tensioner cover gasket.
[IMG]2002 SMG, Topaz Blue, BHS pulleys, all options. UUC Exhaust, GC Sway bars, SS lines, BHP Pads F1 paddles, GSP brake pedal, Huber Optik 20%, Iforged rims and a bunch of other things.. Sold
1970 911T Tangerine
1972 911T Albert Blue
1970 911E Ossi Blue
Jump to top Fastdog911 is offline   Reply With Quote
Old Thu, Sep-06-2007, 07:12:46 PM   #5
JoeE46M3
JoeE46M3's Avatar
Reputation: 0 JoeE46M3 is on a distinguished road
Thats common...the front seal is common (a couple hundred $'s at an indy)
If its the oil pan....(which is also common) expect around 400-500 at an indy.
How long ago was the bearing recall done...they have 2 years on the labor.
the 100k warranty wont do crap on this...they deny most gaskets.
Carbon Black/Cinnamon M3
OEM 19's /// 35% Tint
Jump to top JoeE46M3 is offline   Reply With Quote
Old Thu, Sep-06-2007, 07:29:47 PM   #6
Pr0b1ty
Done and Done
my production date is 04/2002 that is not with in the recall parameters for the bearing is it?
Old Thu, Sep-06-2007, 07:36:15 PM   #7
Travsm3
Reputation: 0 Travsm3 is on a distinguished road
If it's the gasket it will not be covered under the 100K warranty. My car just went in for a new oil pan gasket b/c of this exact problem.
Gone...not forgotten.
www.carolinaeuros.com
Jump to top Travsm3 is offline   Reply With Quote
Old Thu, Sep-06-2007, 07:52:40 PM   #8
JoeE46M3
JoeE46M3's Avatar
Yes it is...All 01's and 02'.
Make sure its BEEN done.
BMW let mine slip through.. I had to point it out.
Take it to a dealer and give them your key. They will get you the history. If it has been done..you have a very good case on a free replacement...along with a free oil change!
If it hasnt been done your really hooked up.. Free fix, free oil change...loaner and a full tank of gas
Old Thu, Sep-06-2007, 08:59:00 PM   #9
Pr0b1ty
Done and Done
hmm... I took the key to the dealer after I bought it and they wouldn't allow me to see the service history. I asked them if there were any recalls that needed to be done and they stated "no". I am going to give it another shot though, considering that my dealership is shady like a honda dealer.
is it a hard DIY to change the oil pan gasket?
and
is there a DIY somewhere? if so link please!
Old Thu, Sep-06-2007, 10:51:02 PM   #10
JoeE46M3
JoeE46M3's Avatar
Not sure about the DIY on this oil pan..
The gasket is cheap... $35 or so..
You have every right to know when the recall was done. If they said its been done...Ask "when"
The Pan is leaking because it has been opened up and not sealed correctly.
Common oil leak? Oil Pan or rear main seal? ///tonic E46 M3 (2001-2006) 54 Tue, Feb-22-2011 05:26:44 AM
E46 Oil Pan Gasket Leak and diff. leak. UKtRAINE3 E46 M3 (2001-2006) 5 Thu, Aug-06-2009 08:05:42 PM
Help Oil Leak on passenger side of oil pan. HareRee E46 M3 (2001-2006) 14 Sat, Dec-13-2008 12:05:09 AM
Oil Pan Leak - Again. M3Malcolm E46 M3 (2001-2006) 0 Thu, Jan-25-2007 07:20:07 PM
Oh My God, My Car Is Leaking Oil From Oil Pan mycbr1000rr E46 M3 (2001-2006) 22 Wed, May-31-2006 05:03:12 AM
Discussing Oil leak from front of oil pan in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
