Old Mon, Jun-20-2011, 08:52:39 PM   #51
genuity
Reputation: 0 genuity is on a distinguished road
Default Re: Differential Bolts replacement DIY: updated bolts
Originally Posted by spr12 View Post
Did you use the new bolts? They're cheap. FYI there are updates for all 3. Just get new ones and do it correctly. Did you do the center bearing and guibo at same time?
I'm going to redo all the rear end bushes, install adj control arms and do center bearing and guibo along with diff bolts all at same time.
I replaced and am replacing everything that is a maintenance item including the old rusty bolts and nuts while I am in there...no sense in doing things twice! Also rebuilding axles and thinking about repacking the drive shaft CV joint if possible.
Jump to top genuity is offline   Reply With Quote
Old Wed, Jun-22-2011, 03:07:25 AM   #52
M Nectar
M Nectar's Avatar
Reputation: 0 M Nectar is on a distinguished road
Upgraded bolts on my 2004 this afternoon. Thanks for the great DIY! Note for those doing the upgrade: the space is super tight and a swivel is a must. After breaking the bolts free, adjust the jack on the diff until the bolt can be turned by hand. I.e. you won't have space to take the bolt out with the E14 + swivel, so get the holes lined up and it's super easy.
Thanks again!
Jump to top M Nectar is offline   Reply With Quote
Old Sun, Sep-25-2011, 04:45:07 AM   #53
kuksul08
I did this tonight. The inside of the bushings is made oval like that, and there were no marks from the threads of the bolt at all. Also they were perfectly tight on my 05 M3, but I changed them anyway and used a little blue loctite.
I was thinking of doing the front also since I bought the bolt, but I can't seem to find it... the one bushing I could feel doesn't have this torx bolt, it's a hex head.
Anyway, it's pretty easy. I don't expect to feel anything different since it was fine already.
Old Tue, Oct-04-2011, 12:56:26 AM   #54
BDUB328I
Reputation: 0 BDUB328I is on a distinguished road
note that using a swivel (univeral joint or extension) on your torque wrench makes it less accurate
Jump to top BDUB328I is offline   Reply With Quote
Old Tue, Oct-04-2011, 01:12:35 AM   #55
IFX
Reputation: 0 IFX is on a distinguished road
why the heck are we changing out diff bolts now?
I thought backing out bolts were vanos only thing..
05 AW Vert/Imola
Red Roundels
Black Hood Grills
Black Fender Gills
Magnaflow Exhaust
Tinted Tails
6K HID Fogs
C/F Guage Cluster
Jump to top IFX is offline   Reply With Quote
Old Tue, Oct-04-2011, 01:31:57 AM   #56
kaiv
SoCal S54 specialist :P
kaiv's Avatar
France
I've had the right side diff bolt snap a while ago. With the diff hanging from only one side it made quite a racket. Thankfully I was able to backout the broken part out easily. They were the the old bolts, I replaced them with the upgraded ones.
E46 ///M325i Touring journal
Old Tue, Oct-04-2011, 01:44:06 AM   #57
emax13
emax13's Avatar
Reputation: 0 emax13 is on a distinguished road
The numbers are correct, however see my last post... The 20nm also has an angle measurement as it is a stretch bolt. E.g., 20nm then X degrees thereafter!!! Huge difference!!!!
for the rear, go right to 61ftlb? or to 20nm then 90 degrees further?
'06 CB/IR w/SMG/NAV/HK/Eibach/19" BBS RGR/Hankooks
Jump to top emax13 is offline   Reply With Quote
Old Tue, Oct-04-2011, 08:07:45 AM   #58
jfowler
Reputation: 0 jfowler is on a distinguished road
Just did this last weekend. The factory bolts were tight and all, but I have noticed a huge decrease in clunk noise upon shifting. I did it the night before I went to a lapping day, drove the whole day with the SMG on 5 or 6, and didn't notice any clunk at all. I don't know why this worked, but it was worth the $9 in bolts or whatever pittance it cost. Took all of 15 minutes. Definitely get the jack on the diff to relieve the pressure off the bolts, it makes everthing a lot smoother.
2002 TiAg, SMG, TCK coilovers, Racing Dynamics FSB, Enkei RPF-01, Wilwoods, GC Front sway, Borla/Gruppe M exhaust, aFe Intake kit, Vorsteiner and ACS carbon goodies, EAS Carbon interior trim.
Jump to top jfowler is offline   Reply With Quote
Old Tue, Nov-08-2011, 06:06:45 PM   #59
new//m3fan
Reputation: 0 new//m3fan is on a distinguished road
Is there a cut off date on when BMW started producing M3's with the improved bolts? Or were they released after the M3's production run ended?
Jump to top new//m3fan is offline   Reply With Quote
Old Tue, Nov-08-2011, 06:08:33 PM   #60
spr12
Reputation: 0 spr12 is on a distinguished road
Dunno but I have a very late 05 - 9.05 and it had the old ones front and rear...
2005 M3 ZCP with every option...
Jump to top spr12 is offline   Reply With Quote
bolts, differential, diy, replacement, updated
Discussing Differential Bolts replacement DIY: updated bolts in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
