Old Wed, Nov-01-2017, 09:22:20 PM   #1
Good
@GOOD_M3
Good's Avatar
Reputation: 0 Good is on a distinguished road
Default DME Faults, SMG Pressure
Recently took my car in for subframe bushings/reinforcement, giubo and input/output reseal. My mechanic ran a pressure test on the smg pump and pulled the dme. There are a few codes I'm a little concerned about. What is one to do when a component isn't receiving the correct voltage? Would this be the alternator that needs to be replaced?
Here is the smg pump pressure test:
Normal for 97k miles?
2006 M3 SILBERGRAU COMPETITION
EXTERIORJCSL 1X1 DIFFUSER | VÖRSTEINER CSL BUMPER
PREVENTATIVE ▌ VANOS BEISAN LOCKDOWN: UPPER GUIDE CHAIN | SOLENOID COIL PACK | OIL PUMP DISK
EXHAUSTSUPERSPRINT EXHAUST ~ OVERSIZED STEPPED V1 HEADERS | RACE CATTED SEC 1 | RESONATED X-PIPE SEC 2 | SPORT (GEN 2) SEC 3
BRAKES ▌ STOCK CSL/ZCP ROTORS | PORSCHE 996 BREMBO CALIPERS | SS LINES
WHEELS ▌ STOCK ZCP BBS 19" | 75MM ECS/TMS F&R WHEEL STUD CONVERSION
SUSPENSIONTURNER MOTORSPORT 30MM FRONT SWAY BAR | KW V2 COILOVERS | GROUND CONTROL CAMBER PLATES | SDW RTABS
ENGINE ▌ TUNED BY PAUL-CLAUDE | KARBONIUS CSL AIRBOX (ALPHA N), OEM SNORKEL (FLAP DELETE), OIL CATCH CAN
TRANSMISSION ▌'255' CSL SMG DME TUNE | INERTIA SMG DME UPDATE | WARM-UP LIGHT RECALIBRATION
Instagram: https://www.instagram.com/good_m3/?hl=en
Youtube: https://www.youtube.com/channel/UCOWWdc1VO3N7QDfZ5NSzriA
Jump to top Good is offline   Reply With Quote
Discussing B-Spec Tune in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
