Go Back   BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X) > General BMW > General BMW Discussion
General BMW Discussion Place to discuss all things BMW. And a place for E30, E36, and E46 owners to get to know each other! BMW News
Old Sat, Jan-17-2009, 03:24:50 AM   #21
ThatOneGuy
In the left lane, flashing to pass.
ThatOneGuy's Avatar
Reputation: 0 ThatOneGuy is on a distinguished road
Germany
Originally Posted by rishi jon View Post
The BMW Maintenance System has been devised with the following objectives: maximize vehicle safety, reliability, and minimize breakdowns resulting from wear, at minimum cost. The Service Interval Light system will indicate when you are due for service based on your driving habits
rishu
______________________________________________
medium format digital general dentistry raleigh
Don't post BS in my thread.
The Blog
Jump to top ThatOneGuy is offline   Reply With Quote
Old Mon, Mar-09-2009, 11:37:13 PM   #22
Old Driver
Reputation: 0 Old Driver is on a distinguished road
Default 2003 bmw330ci with 27,000 miles no break-in service
This car is being offered to me by the original owner who faithfully followed the Free Schedule Mike talks about in his wonderful piece. Therefore, no break-in service and a long interval between oil changes, brake fluid, valve adjustment. But only 27,000 miles.
Any suggestions about the dangers of buying this baby besides paying too much?
Jump to top Old Driver is offline   Reply With Quote
Old Tue, Apr-28-2009, 07:47:17 PM   #23
ThatOneGuy
ThatOneGuy's Avatar
Germany
If "this car" is an M3, then it should have had the break-in service, though I know it's not always the case. If not, the best advice is ALWAYS to get a PPI (Pre-Purchase Inspection) done. It's money well spent.
The Blog
Old Tue, May-26-2009, 03:07:37 AM   #24
mm22176
Reputation: 0 mm22176 is on a distinguished road
Feedback to questions, from "The Author" (of this thread) ... Closest i got to was the one in the gallery service where they were putting together the bike. ...
__________________________________________________ ________________
Natural Medicine for Acne
Free Plastics Surgery
Jump to top mm22176 is offline   Reply With Quote
Old Fri, Jun-26-2009, 09:22:01 PM   #25
M32NV
Reputation: 0 M32NV is on a distinguished road
Originally Posted by ThatOneGuy View Post
Break-in Service for New Cars
Traditionally, BMW performed a break-in service at 1,200 miles on new cars, which included changing the engine oil and filter, manual gearbox oil or automatic transmission fluid, and differential oil. With the advent of Free Scheduled Maintenance, BMW stopped performing break-in services except on M cars.
I have seen that the engine and drive-line oils in new modern BMWs are literally full of metal at 1,200 miles – as has always been the case with any new car. For this reason, I recommend a 1,200-mile break-in service.
Engine
Oil and Filter Intervals
BMW recommends their Castrol 5W-30 synthetic motor oil in all BMWs except contemporary M cars, for which they recommend their Castrol 10W-60 synthetic motor oil. The factory oil change interval is controlled electronically, but is presently about every 15,000 miles. If you are running BMW’s oil, I recommend an oil and filter change interval between 5,000 and 7,500 miles.
I have a quick question on this. My engine was rebuilt in February (due to a cracked block)...they used a new block, pistons, & seals/gaskets and swapped over everything else from the original motor. I've been following the break-in instructions just to be safe even though the SA said it wasn't necessary...keeping it under 5500rpm, no extended high speed runs, varying engine speeds, etc. I've put about 1,250 miles on the car since the rebuild. Should I have the oil/filter changed now or am I okay till the 5k-7500 mile mark (when I would have normally changed it as the in-between interval)? My transmission was also replaced in April (factory rebuilt, I believe) under warranty...do I need to have the trans fluid changed at any sort of break-in interval or just at the 30k mark?
Thanks in advance for your help!
2004 TiAg Coupe 6MT w/ Prem Pkg, Cold Weather Pkg, Bi-Xenon, PDC, HK
New ZCPs & PSS, 5% Lumar Tint, Hardwired V1, CompuSTAR Alarm, K&N Panel, PF RTABs/FCABs, CDV delete, Aurora 60-LED AEs, SPP 6000k fogs, new VANOS bolts
Rebuilt Engine, New Transmission, New Clutch (Thank you BMW CPO Warranty)
Coming Soon: black grilles/gills, painted reflectors, SSK, upgraded brakes (Zimmerman or ZCP?)
Other Rides:
'02 Pathfinder LE 4x4
'02 Suzuki GSX-600
'94 Ford Taurus SHO Auto (stock) - sold
'95 Ford Taurus SHO 5-speed (modded) - sold
Jump to top M32NV is offline   Reply With Quote
Old Fri, Jul-03-2009, 04:31:20 AM   #26
ThatOneGuy
ThatOneGuy's Avatar
Germany
My advice, fluid changes are cheap insurance. The idea is to flush any loose metal shavings or debris that is inherent in the machining/manufacturing of an engine/transmission. Your SA is lazy, misinformed or doesn't want to eat the cost of the service, though I can't imagine why it wouldn't be covered if it was all replaced under warranty. Always follow the break-in procedure for new or replacement parts, always.
The Blog
Old Mon, Nov-09-2009, 11:12:16 PM   #27
E36DINANM3
Reputation: 0 E36DINANM3 is on a distinguished road
What is the best oil for an e36 supercharged m3
Jump to top E36DINANM3 is offline   Reply With Quote
Old Thu, Nov-12-2009, 06:08:05 AM   #28
ThatOneGuy
ThatOneGuy's Avatar
Germany
I have no personal experience with supercharged E36 M3's. I would suggest you contact the blowers manufacturer and ask them for advice. Failing that, Mobile 1 or Redline synthetics are a good place to start. Change it often.
The Blog
Old Mon, Nov-30-2009, 05:43:11 PM   #29
nb120902
Reputation: 0 nb120902 is on a distinguished road
Hey guys, on cold mornings my car makes a funny cracking sound when i turn , what could the possible reasons be?
Jump to top nb120902 is offline   Reply With Quote
Old Mon, Dec-21-2009, 07:57:15 PM   #30
HofmeisterKinky
See what I did there?
HofmeisterKinky's Avatar
Reputation: 0 HofmeisterKinky is on a distinguished road
Warning: Huge post incoming.
Note to the OP: I use the second person here. If you didn't write this, I'm talking to the writer, not you.
Real BMW Service Intervals: Alternative BMW Maintenance Schedule
Real or alternative? Pick one.
Prior to Free Scheduled Maintenance, you couldn’t change engine oil often enough according to most dealerships.
- Dealership service departments didn't do the R&D on the cars.
- Since they mostly see cars that have problems, they receive a highly biased picture of how the cars are performing.
- Dealerships have a stake in recommending frequent service. It makes them money.
But once BMW began paying for scheduled maintenance, lo and behold the “schedule” was revised. Now, magically, the cars hardly need any maintenance at all!
Also "magically", most of the engine line-up changed. A lot of the advancements that characterized those engines had to do with metallurgy and engine management. Hmm. Maybe that played into things a little bit.
So, is Free Scheduled Maintenance all about marketing and cost reduction – BMW’s costs? Draw your own conclusions.
Yes, please do.
But as long as we're advocating skepticism -- which honestly seems a bit hypocritical in an article that paints a very limited picture of the situation and then says "draw your own conclusions" -- let's bear in mind the following:
- BMW has some of the best powertrain engineers in the world.
- BMW's brand is all about sustainability and reputation, which means they depend strongly on resale values and long-term customer satisfaction.
Think about that when you evaluate whether BMW would gamble on screwing you over just to save a few bucks right now.
This is an alternative to BMW’s factory-recommended maintenance schedule. ... It is actually BMW’s maintenance schedule, more or less, which was used prior to Free Scheduled Maintenance.
And that makes it credible? What is your basis?
It also represents my opinion, based upon my experience and that of my readers, tech advisors, and professional BMW technicians both dealer and independent.
...but no powertrain engineers, lubrication specialists, or statisticians to validate the data?
The fact that my opinions may differ from those of others does not mean anyone is necessarily right or wrong. You will get a different answer from every person you ask about routine vehicle maintenance.
Aha, here's the disclaimer. But if this is the case, of what use is the opinion? What this really says is, "all of this is my gut feeling and there's really no data to back it up." That's fine, but it shouldn't be presented with any attempt to sound credible (i.e. the first few paragraphs).
Translation: O NOES I SEE METAL, CHANGE TEH OILS
I know what he's talking about. Oil used at break-in usually comes out looking glittery because of metal bits that are just big enough to cause light to glint off them. Well, if you think those metal bits are harmful and BMW has never seen them in their testing, you probably shouldn't trust them enough to buy their cars.
Why?
I use Red Line synthetic oil (www.redlineoil.com)
Hmm.
in 5W-30, 10W-40, 15W-50, or 20W-50, depending on factory recommendation, ambient temperatures, and severity of service (track use, sustained high rpm use), with a drain interval – 7,500 to 18,000 miles depending on engine and severity of service. Under racing or track conditions I’d use a short interval; same for carbureted engines which tend to get some fuel into the oil. I would run the same intervals with very high end synthetics such as Amsoil and Lubrication Engineers Monolec Ultra.
Wait a sec. So you wouldn't run factory oil change intervals with an oil designed by BMW and Castrol specifically to run that long in BMW engines... but you would run MORE than that with a product from a company that prides itself on never paying for third-party certifications?
I like Red Line too, but cripes...
All other commercially available synthetic oils, 5,000-7,500-mile drain intervals (Mobil-1 is good, we don’t know much about the factory BMW Castrol product).
Half of Mobil 1's products don't even carry the ACEA certifications that qualify them to be considered for BMW's testing.
We don't know much about the BMW Castrol product? How much do you know about "all other commercially available synthetic oils?"
The BMW Castrol product was specifically designed and engineered to BMW's specs fro BMW engines running BMW OCIs. Can't say that for the other oils.
Old fashioned petroleum oil, same viscosities, 3,000-to-5,000 mile drain intervals (I prefer Kendall)
While you're thumbing your nose at BMW's recommendations and putting forth your own, you might want to say something about what cars need synthetics and what cars don't. Just a thought.
“Redline is Group V (polyol ester) based (POE or esters).
“Amsoil and Mobil-1 are Group IV (poly-alpha olefin) based (PAO or synthesized hydrocarbons SHC).
So?
“Castrol Syntec and all the others calling themselves synthetic are Group III (hydrocracked slack wax).
LOL, no. Not even slightly. Some are known to be predominantly group III (e.g. Pennzoil Platinum), but to say "all others" are group III is ludicrous. Motul, Fuchs, Elf, Lubro Moly, etc. all make group IV/V synthetics.
Not all Castrol Syntec is group III. The 0w-30 and 5w-50 definitely are not.
Not all group III base stocks come from slack wax, either.
“The petroleum motor alls are all mineral oil based and make up Group II.
I was about to say "wow, finally some good info" but I realized that not even this is true. Some of the lighter viscosity grades (e.g. 5w-20) have to have some synthetic component just to keep from evaporating too quickly. Oddly enough, this makes them thicker in the hottest parts of an engine than many non-synthetic 5w-30s...
”We really should group Red Line by itself, and put the others in separate categories (according to the groups) because their performance is so different.
Orly? How so?
Motul and RLI are all about esters, too.
Esters don't guarantee good performance anyway. Again, it's the whole formulation that matters.
Red Line isn't even close to being in a category by itself.
Original BMW filters are recommended for price and quality, or MANN, Mahle, Bosch, or Knecht filters
Okay, NOW we have some good info.
...but why the sudden faith in BMW's recommendation? If they're too incompetent to recommend an oil, what makes you think they're competent to recommend a filter?
while you may not have any problems running spark plugs for 100,000 miles in some BMWs, this does not mean the plugs will not be worn, or that that wear is not affecting engine performance. In other words, for optimum engine performance, most BMWs want spark plugs every 30,000-to-60,000 miles.
In other words, "there might be a problem, therefore there is a problem." Interesting logic.
M cars except the US specification S50/S52 powered E36 variants want plugs about every 15,000 miles.
Really? Why?
Stay away from platinum plugs in BMWs. These don’t last as long as the regular Bosch copper or silver plugs and NGK plus, and have been known to fail in other ways. The regular old Bosch Platinum single electrode plug is, however, a very good choice for cars OTHER THAN BMWs.
Sounds like this is referring to the 4-tip platinum plugs. If it isn't, I have no idea what it means. Platinum plugs last a LOT longer than copper plugs at the expense of spark strength for a given amount of energy. That's the whole point.
Air Filter
Stock paper element, check every 15,000 miles, tap out dirt, replace if necessary, standard interval 30,000 miles, use Original BMW filters or aftermarket filters such as Knecht, MANN, Mahle, or Bosch
K&N oiled cotton gauze filters, clean every 15,000 to 30,000 miles depending on condition, use only K&N approved cleaner and oil, and follow K&N cleaning procedures
No mention of severe service or climate as with the engine oil recommendations? Why not?
Valve Adjustment
Perform every 15,000 to 20,000 miles where applicable
When was the last time you saw a reasonably well maintained BMW engine that had clearances that were out of spec in that interval? The only ones I've seen were barely out of spec (if at all) after 3-4 times that mileage.
The factory coolant change interval used to be every two years. It is now every four years.
And you think there was no reason for that? At all?
Jump to top HofmeisterKinky is offline   Reply With Quote
bmw, intervals, part, real, service
Service intervals? acorreiajr E46 M3 (2001-2006) 3 Mon, Jan-10-2005 05:18:52 AM
Service Intervals DougMc E46 M3 (2001-2006) 3 Mon, Sep-08-2003 07:00:14 PM
Service Intervals droptop E46 M3 (2001-2006) 0 Tue, Aug-19-2003 03:49:28 PM
service intervals Jason B E36 M3 (1992-1999) 3 Sat, Jun-14-2003 10:59:35 PM
Discussing Real BMW Service Intervals, Part 1 in the General BMW Discussion Forum - Place to discuss all things BMW. And a place for E30, E36, and E46 owners to get to know each other! BMW News at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
