Old Mon, Jan-02-2012, 07:21:04 AM   #1
Captai
Reputation: 0 Captai is on a distinguished road
Default Thoughts on the CSL tire size
I'm thinking of putting 245 in the front and 265 in the rear of the 19inch 8.5 and 9.5 CSL rims. Anybody have any input on these tire sizes?
Jump to top Captai is offline   Reply With Quote
Old Mon, Jan-02-2012, 01:27:24 PM   #2
krc328ic
krc328ic's Avatar
Reputation: 0 krc328ic is on a distinguished road
Default Re: Thoughts on the CSL tire size
I'm running same up front but 275's in the rear.
Jump to top krc328ic is offline   Reply With Quote
Old Mon, Jan-02-2012, 02:34:28 PM   #3
405
Reputation: 0 405 is on a distinguished road
i run a 265 in the rear and i like it more than the 275 i had before. it felt like too much tire with the 275's on a 9.5. i also switched to 235 in the front and i like it much more than the 245 also. i think next time around i may even try 255's in the rear. there is such a thing as having too much tire and imo 275's are a lot on this car.
-2007 Porsche 997.1 GT3 - Carrara White / Black (Current)
-2002 Porsche 996 Turbo X50 RUF RTurbo Clone - Carrara White / Natural Brown (Gone)
-1996 Porsche 993 RS Clone - Guards Red / Black (Gone)
-2002 BMW E46 M3 - Laguna Seca Blue / Black (Gone)
-2002 BMW E46 M3 - Imola Red / Imola Red (Gone)
Jump to top 405 is offline   Reply With Quote
Old Mon, Jan-02-2012, 04:51:50 PM   #4
mousemaster
mousemaster's Avatar
Reputation: 0 mousemaster is on a distinguished road
The closer the tire width is from front to rear, the less the car will understeer. The factory stagger is 30mm. Taking 10 mm away from that difference will help some.
The car does not lack for rear traction, even with the traction control off. If you are a street driver only, this issue doesn't matter that much since the car is great on the street. If you wish to drive on the track the stagger becomes a bit of a handicap, hence the need to reduce the stagger.
Jump to top mousemaster is offline   Reply With Quote
Old Mon, Jan-02-2012, 04:55:57 PM   #5
EricSMG
40 something
The problem with the 265/30/19 is that it's way too short for street use in my opinion (as is the 275/30). I mean really short, as in almost no sidewall at all.
With those wheel sizes I'd do either 225/255 or 245/255.
2004 E46 M3 6MT SG/Black
Old Mon, Jan-02-2012, 05:56:17 PM   #6
DanAvoN7
Reputation: 0 DanAvoN7 is on a distinguished road
The CSL tire size is 235/35/19 front and 265/30/19 rear. I run this setup with my 19" street wheels and love it. The wheels are 19x8.5 front and 19x10 rear. This setup handles great and feels "crisper" than the 245/35/19 front and 275/30/19 rear that I previously ran. I feel that this is a great balance for all around performance. A wider rear tire really isn't needed unless traction in a straight line is a problem, ie you have forced induction
04 BMW M3 6spd - Alpine White/Black
Apex ARC-8 w/ Hankook Z214, Apex ARC-8 w/ BFGoodrich R1, MCS 3-way Coilovers, GC Race Camber Plates, PFC BBK, Turner Camber Arms, Turner Sway Bars, Turner Subframe bushings, Turner Solid Diff Bushings, Turner Solid RTAB, Turner Solid Control Arm bushings, Treehouse Racing FCAB, Reinforced Subframe, OS Giken LSD, Rogue Engineering Transmission Mounts, SGT Headers, SGT Section 1, AFE Stage 2 Intake, EPIC Tune, Dinan Exhaust, Bimmerworld Airdam/Splitter/Dive Planes, Bimmerworld V2 Wing, TC Design Roll Cage, Racetech RT4119, Scroth Profi 2 Harness
NORCAL Rod Bearing/Vanos/Valve Adjustment/Inspections Member Feedback
Jump to top DanAvoN7 is offline   Reply With Quote
Old Mon, Jan-02-2012, 07:20:30 PM   #7
Captai
alright thanks for the input guys! happy new year!
Old Mon, Jan-02-2012, 09:11:26 PM   #8
Foo2rama
2004 E46 M3
Foo2rama's Avatar
Reputation: 0 Foo2rama is on a distinguished road
Sry I live in socal... Too many P cars around, we need the width in the rear so that we stand out a bit
2004 Mystic Blau Imola Rot ///M3 Coupe Manual converted from SMG in Dec 2017
Jump to top Foo2rama is offline   Reply With Quote
Old Mon, Jan-02-2012, 09:36:32 PM   #9
cncmastr
M-Texture Alcantara
cncmastr's Avatar
Reputation: 0 cncmastr is on a distinguished road
What about 235 in the front and 265 in the rear on OEM ZCP wheels, with a 5mm spacer in the front? Wouldn't that bring the front spacing closer to a CSL spec'd car? Don't they have a wider front track than a non-CSL?
2006 Interlagos Blue BMW ///M3 | ZCP | Xenon | Nav | Premium | M Texture Alcantara | Euro Headers & Cats | TTFS | CSL Airbox w/Flap | Shrick 288/280 - 350whp 275wft-lbs
Collection of my DIY Guides here
Personal Blog
http://www.obsessedmotorsport.com/blog
Jump to top cncmastr is offline   Reply With Quote
Old Mon, Jan-02-2012, 11:06:13 PM   #10
///M_Achilles
"Visor down for business"
///M_Achilles's Avatar
Reputation: 0 ///M_Achilles is on a distinguished road
OP, the 245/265 should offer a nice balance. Have you checked the difference in diameters with OEM? Not so sure if increasing the error of the speedometer is an issue for you. At any rate, 245/265 is the same set-up for the 1M and e9x M3, so give it a try in your e46. I ran 235/35 and 265/30 on oem 19's and aside from the VERY little sidewall support, I enjoyed the upgrade tire size.
2005 Carbon Black Metallic ///M3 SOLD
My Journal
2012 Porsche Cayman R
Jump to top ///M_Achilles is offline   Reply With Quote
Discussing Thoughts on the CSL tire size in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
