Closed Thread
Old Thu, Jan-24-2008, 03:04:14 AM   #21
tom @ eas
tom @ eas's Avatar
Reputation: 0 tom @ eas is on a distinguished road
Originally Posted by Androoos View Post
Tom,
I have some questions before placing an order:
1. Are you going to have a DIY up on your site showing install of the radio interface unit, complete with removal of the dash trim and factory head unit? It would be very helpful. I'm nervous when it comes to messing with the dash, based on past experience with non-BMWs.
Yes - or we have instructions we can send to you now. Since you have NAV - the monitor is not touched.
2. I want to clarify, the radio interface model is definetely compatible with the Business CD in a 2002 M3, nav is not required?
On NAV-equipped radios, the tuner is in the trunk. the monitor is only a monitor. You'll need the trunk interface kit in order to equipped the DICE to your M3.
3. Is there a specific way to route the cables so that everything fits behind the dash and the dock connector runs through the hole into the glovebox? The cable bundle looks pretty bulky, that's why I'm asking. I haven't had the head unit out of this car yet (can you tell?) so I don't know how much space is back there.
Thanks in advance for your help - and look for an order from me soon. I think this is the answer to my dreams!
We have tutorials at the following links:
http://www.europeanautosource.com/su...nter/index.php
Let me know if you have any further questions.
Tom G. | european auto source (eas)
email: tom@europeanautosource.com web: www.europeanautosource.com tel 866.669.0705 ca: 714.369.8524 x22
GET DAILY UPDATES ON OUR BLOG FACEBOOK YOUTUBE FLICKR INSTAGRAM
Jump to top tom @ eas is offline
Old Wed, Jan-30-2008, 09:42:07 PM   #22
hoonk
hoonk's Avatar
Reputation: 0 hoonk is on a distinguished road
I have a dice unit a couple of years old and it has always suffered with the "little volume dip" at the beginning of each song. It seems this occurs when the text info is transmitted to the nav screen. I have tried the reboot/installation procedure multiple times and finally gave up. I flipped a couple of the dip switches on the side of the dice and this gives me music with no "little volume dip" but no text on the nav screen.
My question is : does this new silverline dice unit solve the "little volume dip"
Thanks
Jump to top hoonk is offline
Old Thu, Jan-31-2008, 01:08:36 AM   #23
rukidinme
Reputation: 0 rukidinme is on a distinguished road
Default Problems - Nav - ipod - Silverline
Tom,
I just installed the Silverline unit I ordered from you. I have a 2005 M3 with Navigation. I cannot get the radio controls to control the ipod. If I set both the dip switches to ON, I can get the ipod to work, but not with switches in any other position. I disconnected the battery cables, etc., but no change. I am using a ipod classic 160g with the most recent update. I also reset the ipod by holding the menu and center button.
Please let me know what I am doing wrong.
Jump to top rukidinme is offline
Old Thu, Jan-31-2008, 05:27:38 PM   #24
tom @ eas
tom @ eas's Avatar
Thanks
Yes - this was actually covered in the prior version in a firmware update.
Old Thu, Jan-31-2008, 05:29:30 PM   #25
tom @ eas
tom @ eas's Avatar
Originally Posted by rukidinme View Post
Tom,
All 4 DIP switches should remain in the OFF position (UP). Perform the following steps exactly to reinitialize the system:
1. Disconnect iPod from cable
2. Remove battery cables, negative first
3. Touch battery cable terminals together (away from battery) for +5 seconds, a small spark is normal as this is stored power draining from the system.
4. Allow cables to remain disconnected for about 5-7 minutes
5. Reconnect battery cables onto battery, negative last.
6. Reboot iPod by pressing on MENU and CENTER buttons for +5 seconds and then reconnecting to the DICE cable after the reboot process is completed.
This should get you up and running, if not - contact me directly and we'll troubleshoot further.
Old Mon, Feb-18-2008, 12:20:42 AM   #26
mmdpkaaa
Reputation: 0 mmdpkaaa is on a distinguished road
i have an e46 M3 convertible with factory widescreen NAV. Is it possible to just install all this equipment (including the ipod) in the trunk and not have to route any wires through to the front of the car?
Jump to top mmdpkaaa is offline
Old Mon, Feb-18-2008, 06:57:37 PM   #27
tom @ eas
tom @ eas's Avatar
Absolutely - since all control is performed via the steering wheel/radio buttons, placement of the iPod is no longer an issue.
Old Mon, Feb-18-2008, 07:20:13 PM   #28
mmdpkaaa
how does it connect to the steering wheel from the trunk? sorry im a novice when it comes to these things...
Old Mon, Feb-18-2008, 08:07:35 PM   #29
tom @ eas
tom @ eas's Avatar
The DICE will use the CD Changer connections in the trunk, which is controlled by the radio and/or steering wheel. Since you are using factory wiring and we are emulating the factory CD Changer - these options are readily available.
Old Mon, Feb-18-2008, 08:10:00 PM   #30
mmdpkaaa
gotcha. so which is better, the dice or the intravee II?
Closed Thread
▀▄, dice, eas, integration, ipod, kit, official, q or a, silverline, thread
[eas] Official DICE iPod integration kit Q/A thread tom @ eas Audio/In Car Entertainment (I.C.E.) 1009 Wed, Sep-07-2011 04:36:09 PM
▀▄ eas | DICE SILVERLINE iPod Integration Kits now available for BMW tom @ eas Parts for Sale/Wanted 20 Mon, Aug-18-2008 05:00:58 PM
▀▄ eas | ** NEW RELEASE ** DICE Universal RDS iPod Integration kit for BMW tom @ eas Parts for Sale/Wanted 8 Mon, Jul-14-2008 05:41:44 PM
▀▄ eas | DICE SILVERLINE - An open letter to our valued customers.... tom @ eas Audio/In Car Entertainment (I.C.E.) 0 Tue, Jan-15-2008 11:09:22 PM
▀▄ eas | DICE SILVERLINE iPod Integration Kits now available for BMW tom @ eas M3Forum Sponsor Announcements and Specials 0 Tue, Jan-08-2008 05:02:31 PM
Discussing ▀▄ eas | Official DICE SILVERLINE iPod Integration Kit Q/A Thread in the Audio/In Car Entertainment (I.C.E.) Forum - Place to discuss sights and sounds. at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
