Old Sun, Aug-13-2017, 01:22:13 AM   #1
STAATS
STAATS's Avatar
Default On Demand (ie switch activated) Speed Limiter
Bit of a left field question here and I doubt anyone is going to jump up straight away with the answer but I will try anyway...
One of the events I intend to enter has 130kph speed limit for cars which only have a 4pt Half Cage (unrestricted for cars with a 6pt Full Cage)... I am going the 4pt Half Cage route as I plan to keep this car on the road and our regulations here are such that you can have a fully licensed car with a half cage but you need this very restrictive road permit if you have a full cage, and hence a route i don't want to go down...
From factory our car already has a 250kph speed limiter (which we normally remove)... but I wanted to know if it was instead possible to reduce the speed limiter to 130kph (which I imagine is easily possible by changing some settings) BUT be able to switch between speed limited and unspeed limited say using the "Sports" button or some other externally installed switch?
As all of the other events I enter will not have this speed limit... Obviously one solutions would be to have two tune files and swap between them... which is I guess what I will do if I can't find a more agreeable solution... but obviously switching on the fly would be preferable...
STAATS
Old Sun, Aug-13-2017, 12:44:33 PM   #2
Biosphere
Reputation: 0 Biosphere is on a distinguished road
Norway
Default Re: On Demand (ie switch activated) Speed Limiter
you can buy mss54 flasher then you can have diffrent maps selection (speed limit) choosen
Jump to top Biosphere is offline   Reply With Quote
Old Sun, Aug-13-2017, 01:08:44 PM   #3
Mssmapper supports using the cruise control resume speed button as a pit lane speed limiter for as long as you hold it.
Or you could use mapper to run multiple maps with different speed limits and switch between them on the fly.
Old Mon, Aug-14-2017, 12:12:13 AM   #4
STAATS
STAATS's Avatar
This seems like a perfect solution for what I am looking to do... just a few questions as the website wasn't explicitly clear on a few things...
1) Can you still use the Cruise Control function? I am imagining that the map switching with the Cruise + / - buttons works when the Cruise Control is off and then when you turn Cruise Control on the CC takes over those buttons again? (or something to that effect, as obviously I won't need Cruise Control on the track but I will use it on the street)
2) It says you need a MSS54HP(CSL) ECU... Now I have/had a MSS54 ECU but I have had it modified by TTFS to be "CSL-spec" which I am pretty sure is just upgrading some of the "chips" on the board and NOT adding the H-bridge for flap function... As a result I will be able to run CSL software (well without the flap but yer) so would this ECU be able to use the MSSMapper software and tune switching functions?
Thanks in advance guys... honestly didn't believe there would be such a readily available and seemingly simple solution to my problem on this one hahah
STAATS
Old Tue, Aug-15-2017, 11:21:50 AM   #5
1) Yes-- when cruise control is on (cluster light on), then the steering wheel controls do cruise control. When CC is off (cluster light off), they control MSSMapper.
2) AFAIK, you can't CSL convert without converting your ECU to an HP, so you should be good to go.
Old Tue, Aug-15-2017, 12:12:12 PM   #6
STAATS
STAATS's Avatar
Awesome these are the answers I want to hear
One last question I didn't think of until later. Can this be used with maps provided by Evolve? As you would need to use the MSSFlasher interface to load on the multiple maps instead of using the Evolve-R interface.... If the answer to this question is yes then I think MSSTuning has another customer
STAATS
Old Tue, Aug-15-2017, 02:02:36 PM   #7
Assuming your tune isn't from the period in which they were encrypting it (which I believe they'll removed for free, if it was, if you email them), you could pull the Evolve tune using MSSFlasher or BMWFlash and load it into MSSMapper that way.
Old Wed, Aug-16-2017, 12:54:22 AM   #8
STAATS
STAATS's Avatar
Thanks so much man. This has been extremely helpful
For anyone that digs up this thread in the future looking to do the same or a similar thing here are the useful links to save you some time and digging:
Paffy's post about developing MSSMapper: http://www.m3forum.net/m3forum/showthread.php?t=496440
MSSTuning website to source MSSMapper and MSSFlasher: http://www.msstuning.com/
STAATS
Discussing On Demand (ie switch activated) Speed Limiter in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
