Old Sat, Aug-12-2017, 08:19:29 PM   #1
schoonerm3
Reputation: 0 schoonerm3 is on a distinguished road
Ireland
Default Is my odometer clocking the wrong mileage with a 4.1 ratio diff?
My friend mentioned this to me a few days ago. And now I am wondering if I have sped up the way the car records the mileage?
Can it be recalibrated?
Jump to top schoonerm3 is offline   Reply With Quote
Old Sat, Aug-12-2017, 09:30:43 PM   #2
Default Re: Is my odometer clocking the wrong mileage with a 4.1 ratio diff?
No impact. The speedometer and odometer uses the ABS sensors (on the wheel hubs) to measure speed/distance.
Old Sat, Aug-12-2017, 10:56:47 PM   #3
Slowmobile
Na Na Na Na Na Na Na Na
Reputation: 0 Slowmobile is on a distinguished road
now if you went up in wheel size... then that's another story I would assume
Legen... Wait For It... ///M
Jump to top Slowmobile is offline   Reply With Quote
Old Sat, Aug-12-2017, 11:06:14 PM   #4
johnewhite
USMC-Vet ProCivEng
johnewhite's Avatar
Reputation: 0 johnewhite will become famous soon enough
Speed is a direct function of the diameter of the tires.
Jump to top johnewhite is offline   Reply With Quote
Old Sat, Aug-12-2017, 11:54:47 PM   #5
ThunderMoose
I am pretty sure speed is measured by a pitot tube hidden in the front bumper.
#67 2017 NASA TX TT3 Champion
Old Sun, Aug-13-2017, 12:11:57 AM   #6
johnewhite
USMC-Vet ProCivEng
johnewhite's Avatar
You mean like the FM3?
Old Sun, Aug-13-2017, 03:09:33 PM   #7
schoonerm3
Ireland
Cool. Thanks fellas. Does that mean if your wheel speed sensors are not working then your not recoding mileage??
Discussing Is my odometer clocking the wrong mileage with a 4.1 ratio diff? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
