Old Sat, Aug-12-2017, 03:10:24 PM   #1
Paulo M
Default Comparison test of BBK for the E9x M3 - Surprising results!!!
If you haven't seen it yet, interesting read. Brembo didn't do so well,...thoughts?
Originally Posted by Boss330 View Post
German magazine Auto Bild Sportscars did a test of BBK for the E92 M3 in their latest issue (12/2014).
The finishing order was as follows:
1. Stoptech
2. PFC
3. AP Racing
4. BMW original brakes
5. K-Sport (8 pot)
6. Brembo GT kit
The most surprising, to the editors as well, was how bad the Brembo kit did in this test!
From 200km/h - 0 it used 1,9m more than the stock brakes...
From 250km/h - 0 it used 8m more than the stock brakes and a whopping 25m longer than the best BBK!!!
The test was done very meticulously and new Michelin Cup2 tires was fitted for every BBK they tested. And every BBK manufacturers procedures for bedding the brakes was followed to the point.
Each test parametre was tested 20 times (so 200-0 was done 20 times for every BBK).
The test is done with the compounds supplied by the BBK manufacturer and as approved by the TÜV for the kits. Just like what a consumer would get when buying a BBK from the suppliers.
AP Racing and K-Sport both use the Pagid RS29 brake pads.
The test was done at the DEKRA test centre with a independent brake and tuning specialist present.
  • With the Brembo they write that the pressure point was inconsistent and after installation and bleeding the brake pedal was very low. After rebleeding the pressure point was still inconsistent and often required a double braking action to restore the pressure point.
  • AP Racing has a very consistent pressure point.
  • The K8 suffered from severe vibrations after some use. It's also heavier than stock brakes.
  • PFC is 10kg lighter than the stock brakes! Has a consistent and short pedal travel as well as being easy to modulate.
  • Stoptech has short and consistent pedal travel and the best modulation. Highest deceleration and no fade.
EDIT:
Video posted on their FB page:
https://www.facebook.com/video.php?v=890428987647521
UPDATE 20. january 2015:
In the last issue of Auto Bild Sportscars there was a letter in the "Readers letters" section that took up the BBK test.
The editor replied that they assumed that "Brembo had delivered the wrong kit which was the reason behind the disastrous results" and the they would do a new test with the proper Brembo BBK that would be published later.
BREMBO BBS DIXIS
Old Sat, Aug-12-2017, 03:16:13 PM   #2
TheM
Reputation: 0 TheM is on a distinguished road
Default Re: Comparison test of BBK for the E9x M3 - Surprising results!!!
I don't understand this test at all. They should all be capable of activating the ABS and therefore have similar stopping distances. Is there is a delay in pad pressure application perhaps? What am I missing here?
2002 M3 SteelGray/Cinnamon, TCKline, Besian, ACT clutch
A pair of Ducatis
Jump to top TheM is offline   Reply With Quote
Old Sat, Aug-12-2017, 03:37:10 PM   #3
mcfreid
Reputation: 0 mcfreid is on a distinguished road
Seems like the test measures more HOW DIFFICULT it is to achieve the same (in theory) stopping distance with each brake kit. 'still quite interesting.
Jump to top mcfreid is online now   Reply With Quote
Old Sat, Aug-12-2017, 04:02:38 PM   #4
Fhcrubarb
Fhcrubarb's Avatar
Reputation: 0 Fhcrubarb is on a distinguished road
I remember this test. It's important to keep in mind that they used brake pads supplied by each manufacturer, most likely varying in compound. The true test would be to use the same pad for all of the calipers.
Also, this is a simple go fast and slow down test. Most BBK's are designed for track time not for stopping fast in rush hour traffic.
Jump to top Fhcrubarb is offline   Reply With Quote
Old Sat, Aug-12-2017, 04:22:27 PM   #5
m3e46freak
M3 Freq
m3e46freak's Avatar
Reputation: 0 m3e46freak is on a distinguished road
Germany
^ Exactly, use the same pad for each test.
If you want to test the caliper and rotor, otherwise... time wasted, in my opinion. I have HAWK HPS squeal pads lol, on my wagon and those ****ers stop.
Rock Hard Abs Racing
KWV2!
18X10 CCW CLASSIC!
CPI Headers!
RESONATORS AND SUPERSPRINT!
DINAN!
FRANK!! 311RWHP-260Torque
m3e46freak@yahoo.com for outside contacting
ebay/craigslist verified 100% FEEDBACK
m3forum 96% FEEDBACK
m3post/e46fanantics Great FEEDBACK
zpost/bimmerforum Great FEEDBACK
Jump to top m3e46freak is offline   Reply With Quote
Old Sat, Aug-12-2017, 05:26:34 PM   #6
breadvan
AP Racing and Brembo are the kings of brake products so it doesn't bother the vast majority of serious race teams that continue to trust the top dogs. There is no refuting that fact.
This test is objectively flawed and doesn't prove much.
Old Sat, Aug-12-2017, 06:28:10 PM   #7
Brian N
wubalubadubdub
Brian N's Avatar
There was a thread started on this when the test came out. I know most people hated this test but for me it's useful. Since I plan on buying a bbk and using it like it is out of the box. I still wouldn't get a Stoptech kit because of knock back issues though and would avoid K sport as well.
-My Journal-
Old Sat, Aug-12-2017, 07:04:07 PM   #8
HassanEido
HassanEido's Avatar
Lebanon
My take on brakes:
- stock brakes are damn good. Fade can be fixed with pads, fluid and plates.
-BBKs are about looks and heat management. Bigger brake hardware ->better heat management.
-Brake pads make the most difference as they work for different temps.
-PFCs are a no brainer.
Mods:
-Custom CF airbox
-Cat Cams 280 272.
-Custom dyno tune
364.1 whp 287.8 wtq
Discussing Comparison test of BBK for the E9x M3 - Surprising results!!! in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
