Old Sat, Aug-12-2017, 07:28:54 AM   #1
omitecht
Om3rrr
Reputation: 0 omitecht is on a distinguished road
Default Unusual Cam Lobe wear? What's the deal?
Doing a valve adjustment and I noticed that the cam lobes are wearing out In a weird pattern. Any ideas. 06 with 88k miles
Jump to top omitecht is offline   Reply With Quote
Old Sat, Aug-12-2017, 07:30:37 AM   #2
omitecht
Om3rrr
Default Re: Unusual Cam Lobe wear? What's the deal?
Also the tips of the rocker arms are brown and it's not oil.
Old Sat, Aug-12-2017, 07:45:35 AM   #3
L0ADED
L0ADED's Avatar
Normal wear. Seen this on a few S54s. If scored part of the lobe doesn't catch with a fingernail, then it should be fine.
Old Sat, Aug-12-2017, 08:48:12 AM   #4
omitecht
Om3rrr
Thanks, I just thought it was weird since I haven't seen it in any other e46s
Old Sat, Aug-12-2017, 01:08:41 PM   #5
idntknow2005
idntknow2005's Avatar
Reputation: 0 idntknow2005 is on a distinguished road
I have a stock cams with 33k miles on them that I wouldn't mind selling
2001 E46 ///M3 - LSB+ on Cinnamon - Full Restoration "Brought back from the dead"
Jump to top idntknow2005 is offline   Reply With Quote
Old Sat, Aug-12-2017, 09:32:13 PM   #6
exodus454
Reputation: 0 exodus454 is on a distinguished road
Mine has similar scoring on the lobes and rockers, apparently isn't a huge issue if they can't be felt, does bother the hell out of me though. Your engine also looks a HELL of a lot less varnish stained than mine is.
I always thought it could be some sort of dry start wear from poor quality oil or after sitting for awhile. Mine hasn't gotten any worse in 40k.
05 ZCP - 6MT >> CPI Stepped Headers - Magnaflow cats & 1 Cherrybomb - Meisterschaft Titanium - CSL software - Eibach pro kit - 15mm rear spacers - BW studs - GC Hybrid FCABS - BW Spherical RTABS - TMS front bar
Manual Leveling - Factory Xenon - Nightbreakers - ZKW-R lenses
Jump to top exodus454 is online now   Reply With Quote
Old Sun, Aug-13-2017, 03:17:29 AM   #7
E46_USMC
E46_USMC's Avatar
Reputation: 0 E46_USMC is on a distinguished road
Hey guys, I'm the one that spotted this while doing his valve adjustment. It just seemed odd to me, as I don't recall that kind of wear on the other cars I've performed valve adjustments on. The car had "low" mileage on it at just a bit over 80k.
Jump to top E46_USMC is offline   Reply With Quote
Discussing Unusual Cam Lobe wear? What's the deal? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
