Old Fri, Aug-11-2017, 11:52:14 PM   #1
Acalyst
Reputation: 0 Acalyst is on a distinguished road
Default Where is this hose
Hey guys, a mechanic took a look at my car and said my plenium drain hose was disconnected... What does that mean, what does that hose do and is the reason for my vaccum leak?
Jump to top Acalyst is offline   Reply With Quote
Old Fri, Aug-11-2017, 11:59:49 PM   #2
Default Re: Where is this hose
Could be. There are several lines coming off the intake box - not sure which he means - probably not the one from the valve cover to airbox, but could be the one underneath?
/// 2004 SilberGrau M3 Coupe 6MT slicktop manual seats no nav____________________JOURNAL
Evolve-R Alpha N Evolve CSL CF Airbox Eventuri Scoop Supersprint V1 stepped SS V1 S pipe + 200 cell HFC OE sect 2 SS Sport BMW Motorsport 4.10 Besian RE pullies/fan delete WPC rod bearings TMS Camber & Subf plates RE Trans Mounts AKG poly SUB/DIFF SDW RTAB ZHP knob + UUC DSSR GroundControl S/A (Koni/Eibach 440/550) + tall RSMs OE CSL trunk APEX 75mm Studs Sportline 8S 18"x8.5/9.5" MPSS 245/275 ss brake/clutch lines Pioneer DEH-80PRS Eclipse PA5422 CDT HD-6 + WS-100i CDT EX-530 8" Kicker
Old Sat, Aug-12-2017, 02:30:45 PM   #3
FerrisX
Reputation: 0 FerrisX is on a distinguished road
There is an oil return hose on the bottom of the plenum. That drains any oil collected from the crankcase vent back into the oil pan. He probably meant that, it's a a fairly small hose but would be a vacuum leak.
Jump to top FerrisX is offline   Reply With Quote
Old Sat, Aug-12-2017, 07:29:25 PM   #4
PITT M3 RR
PA
PITT M3 RR's Avatar
If the oil drain hose is off, then yes that's a massive vac leak. Its about a 1/4 hole. Remove the intake elbow and box then reach under there to push it back on.
S54 E36 BUILD
Discussing Where is this hose in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
