Old Fri, Aug-11-2017, 08:40:19 PM   #1
breadvan
Default Another "Which header is this?" Welds much better than Supersprint
Old Fri, Aug-11-2017, 08:44:11 PM   #2
kaiv
SoCal S54 specialist :P
kaiv's Avatar
France
Default Re: Another "Which header is this?" Welds much better than Supersprint
Nice clickbait title. To the best of my knowledge there isn't any documented Supersprint header failure. Not sure how it could get "much better" than that.
E46 ///M325i Touring journal
Old Fri, Aug-11-2017, 08:48:13 PM   #3
breadvan
No one mentioned anything about SS failures. Rather, I simply pointed out their inconsistent weld quality when comparing them to the other headers. Since you did bring up failures you've been around long enough to know that there have been several instances where Supersprint header bungs have broken off. And as an fyi I actually have a Supersprint header on my car for probably 20,000 trouble-free miles.
Old Fri, Aug-11-2017, 09:21:49 PM   #4
ECB
ECB's Avatar
Reputation: 0 ECB has disabled reputation
The more important question is do they fit. All the SS products I've had on my m3 and m5 have fit perfectly. The headers I had on the m3, which were not ebay but a known brand, I had to send back because they didn't fit. SS is a quality product.
2004 Jet Black/Black Nappa/6 spd
Maximum PSI turbo/Aquamist HFS-3/Rogue Sect 2 with exhaust cutout/Eisenmann Race Muffler/Rogue SSK
Koni Yellows/H&R Springs/Strut Hat Swap/Square 18's/Rear 12mm Spacers/BSW Speakers and Sub
Jump to top ECB is offline   Reply With Quote
Old Fri, Aug-11-2017, 10:07:24 PM   #5
2006E46M3fan
2006E46M3fan's Avatar
So where did you buy them? And what's your ebay account? Lol
Jump to top 2006E46M3fan is offline   Reply With Quote
Old Fri, Aug-11-2017, 10:56:22 PM   #6
Joefresh
Joefresh's Avatar
Reputation: 0 Joefresh is on a distinguished road
You are right to a point. Without nerding out about stainless tig welding the blues and golds you get are more from heat VS. travel speed. Not necassrily an inferior weld.
Once the stainless turns dull, greyish, or even black and burnt you have then changed the metals composition.
To me the welds posted look like they were deoxidized to remove any coloration.
They also look like they were welded on the cold side so possibly poor fusion. If they did not back purge the inside they could also be total junk.
Sincerely
-An aerospace tig welder.
check out my artwork
www.instagram.com/TOADesign
Jump to top Joefresh is offline   Reply With Quote
Old Fri, Aug-11-2017, 10:57:37 PM   #7
mrfuzzybagels
(❍ᴥ❍ʋ)
mrfuzzybagels's Avatar
Reputation: 0 mrfuzzybagels is on a distinguished road
They kinda look like they're sprayed with header paint
Jump to top mrfuzzybagels is offline   Reply With Quote
Old Sat, Aug-12-2017, 12:19:09 AM   #8
breadvan
My SS headers fit like a glove so yeah, no worries on that front. SS is definitely a well-respected company.
They aren't mine. I am searching for new headers just because I like to tinker and experiment. Life is short, have fun!
Sincerely
It's great to hear from someone who does this for a living everyday. I will see if I can track down pictures of the welds on the inside. I am also itching to see what the collector looks like as well.
Definitely not header paint lol. That's good ol' bare stainless steel, most likely a quality grade.
Old Sat, Aug-12-2017, 12:52:09 AM   #9
STAATS
STAATS's Avatar
You can see the HAZ (Heat Affected Zone) in the second and third picture and without being able to inspect them in person it looks like they have been wire brushed after welding as you can still see the shadow of the HAZ (which is normally where your "coloured" zone would be)... there is always some amount of colouration and the colour of the colouration in the HAZ is how you tell if the composition has changed... the pure presence of a colouration in the HAZ is not an indication it has been comprimised it depends on the colour (which also depends on which alloy it is... ie 316L vs say a Duplex Stainless Steel, which this won't be but as an example).
As they are headers it will either be a 304SS or a 316SS... 316 would be the preferable option as it has better corrosion resistance then 304 especially in salty environments (ie any cold snowy european country where they salt the roads when they get icy or coastal areas in the US)... to illustrate how important the difference is between 304 and 316, 304 is banned on all offshore Oil and Gas facilities I have ever worked on, due to its poor corrosion resistance in salty conditions... But even with that, the difference between 304 and 316 is not enough that you will be able to tell from a picture... and I would be surprised if it is any other grade of Stainless Steel than those...
STAATS
Old Sat, Aug-12-2017, 01:41:13 AM   #10
breadvan
Now this leads me to ask why the welds (MIG?) on the factory BMW OE Euro headers look so crummy. I know the welds are probably very strong but I would imagine BMW would have a robotic tig welding system easily at their disposal. Welders please chime in.
Discussing Another "Which header is this?" Welds much better than Supersprint in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
