Old Fri, Aug-11-2017, 08:23:22 PM   #1
NolliM3
NolliM3's Avatar
Default Wipers Crash
Ever since I changed my cowling, my wipers crash at the highest speed...other speeds are okay. So, I am wondering how they should be on the windshield. Here is how I currently have them as well as I rarely need the highest speed but those times when there is heavy pour down I wish they work at the highest settings. I figured they should look at the same level and here are pics to show how they are now.
View from driver side
View from Passenger side
Old Fri, Aug-11-2017, 09:27:40 PM   #2
Sammyzuko
Registered User & Abuser
Sammyzuko's Avatar
Reputation: 0 Sammyzuko is on a distinguished road
They crash how? Into each other?
The drivers side wiper should be slightly more vertical I believe. I can't recall the wiper lengths, but I use the passenger length (20"?) for both.
Jump to top Sammyzuko is offline   Reply With Quote
Old Fri, Aug-11-2017, 09:41:43 PM   #3
haus
haus's Avatar
Default Re: Wipers Crash
Here are mine. Forgive the dust/dirt, the M3 had to spend a few nights outside while the Lexus got new shocks.
'97 Cosmos (1 of thousands)
Old Fri, Aug-11-2017, 10:06:56 PM   #4
Sammyzuko
Sammyzuko's Avatar
Hmmm.....my driver side wiper gets hung up on the hood if I put it down as far as yours. Maybe my hood needs adjusting.
Old Sat, Aug-12-2017, 02:04:28 AM   #5
M_Parallel
Mr. OEM
M_Parallel's Avatar
Netherlands
Driver's side wiper definitely looks too low.
The TIS should have a diagram with exact positioning, just as a diagram for the jet's spray pattern.
Old Sat, Aug-12-2017, 03:10:13 AM   #6
bluptgm3
As I recall Bentley has dimensions. Your drivers side is way low, it should be just about horizontal. E36 wipers are a 20 inch blade passenger side and a 21 inch blade drivers side. Blades on my 3 E36s (two sedans and s coupe) are not even close to touching even if mis- rigged.
Old Sat, Aug-12-2017, 11:06:11 AM   #7
M_Parallel
Mr. OEM
M_Parallel's Avatar
Netherlands
Here's the TIS article for correct wiper arm placement
http://workshop-manuals.com/bmw/3_se...rms/page_2401/
Also saw this. Never knew BMW had a tool to twist the wiper arm to set correct contact angle
http://workshop-manuals.com/bmw/3_se...on_windshield/
Old Sat, Aug-12-2017, 09:47:43 PM   #8
NolliM3
NolliM3's Avatar
When passenger side launches, the driver side can't get out of the way fast enough.
Thank you...yours seem too high to me though based on what Parallel shared.
Just super awesome Parallel...thank you...never thought of checking TIS.
Old Sat, Aug-12-2017, 10:58:39 PM   #9
NolliM3
NolliM3's Avatar
After checking measurement, the passenger side is 4ins too high and the driver side is 4ins too low.
Old Sat, Aug-12-2017, 11:28:28 PM   #10
M_Parallel
Mr. OEM
M_Parallel's Avatar
Netherlands
4"!? That seems a bit much. Thought more like 4cm.
Discussing Wipers Crash in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
