Old Fri, Aug-11-2017, 06:11:29 PM   #11
nbriggs1988
Reputation: 0 nbriggs1988 is on a distinguished road
Default Re: Rod bearing check
You might be able to see if it's been done by checking and pulling a Carfax report on your car. It's not a definitive guarantee that it will show/not show on the report, but generally work done by a dealer is reported and shows up on the Carfax. Hope this helps.
P.S. if you PM me, I can check for you
Sent from my HTC 10 using Tapatalk
Jump to top nbriggs1988 is offline   Reply With Quote
Old Fri, Aug-11-2017, 09:00:25 PM   #12
Good
@GOOD_M3
Good's Avatar
What year is your M? Be sure to take a sample and send it off to Blackstone. Will only cost you $28 total (Free shipping).
2006 M3 Competition | Silver Grey Metallic
Modifications:
- Complete SuperSprint Exhaust: Stepped V1 Headers, Race Catted Sec 1, Resonated X-Pipe Sec 2, Sport (Gen 2) Sec 3.
- Karbonius CSL Airbox (Alpha N) w/ Flap and Oil Catch Can
- KW V2 w/ Ground Control Camber Plates
Preventative:
- Vanos Beisan Lockdown~ Upper Guide Chain, Solenoid Coil Pack, Oil Pump Disk
Jump to top Good is online now   Reply With Quote
Old Fri, Aug-11-2017, 09:06:06 PM   #13
Oldylr
Reputation: 0 Oldylr is on a distinguished road
2005, I just got the sample bottle to send to Blackstone. Hoping to do an oil change in the next week or so to send off as well.
Jump to top Oldylr is offline   Reply With Quote
Old Fri, Aug-11-2017, 10:19:43 PM   #14
Good
@GOOD_M3
Good's Avatar
Smile Re: Rod bearing check
There was no Rod Bearing recall for your M. You have one of the later models which did not apply to the recall. The only recalls that apply to your year are the following:
10/01/2009 - Rear Axle Carrier Class Action Settlement
06/01/2009 - Telematics Control Unit (TCU) Reactivation
07/01/2007 - Telematics(R) Control Unit
12/01/2006 - SMG Control Unit Reprogramming
03/01/2006 - Reactivating Telematics Control Unit
08/01/2005 - IHKA Module Recoding
07/01/2005 - Rollover Sensor Replacement
10/02/2009 - DME Programming For Catalyst Conversion
10/01/2007 - DME Programming for OBD Communication
Then of course there are 6 airbag recalls that occurred in 2014, 2015 and 2016.
Hope this helps!
Modifications:
Preventative:
Old Fri, Aug-11-2017, 10:24:22 PM   #15
Oldylr
Oh great! The dealer said the only outstanding recall showing was the drivers airbag which they had in stock and would take about an hour to replace.
Old Fri, Aug-11-2017, 10:39:03 PM   #16
The dealer won't tell you what recalls have been done due privacy, but will tell you what recall needs to be done.
It's beautiful logic
/// 2004 SilberGrau M3 Coupe 6MT slicktop manual seats no nav no xenon no anything JOURNAL
Evolve-R Alpha N Evolve CSL CF Airbox Eventuri Scoop Supersprint V1 stepped 63mm SS V1 S pipe 63mm + 200 cell HFC OE sect 2 60mm SS Sport 60mm BMW Motorsport 4.10 Besian RE pullies/fan delete WPC rod bearings TMS Camber & Subf plates RE Trans Mounts AKG poly SUB/DIFF 95a SDW RTAB ZHP knob + UUC DSSR GroundControl S/A (Koni/Eibach 376/440) + tall RSMs OE CSL trunk APEX 75mm Studs Sportline 8S 18"x8.5/9.5" MPSS 245/275 Brembo 996 36/40 345mm Textar Pioneer DEH-80PRS Eclipse PA5422 CDT HD-6 + WS-100i CDT EX-530 8" Kicker
Old Sun, Aug-13-2017, 04:05:50 PM   #17
bimmerfan08
bimmerfan08's Avatar
How did you manage to get free shipping through Blackstone? The kits are shipped free from Blackstone but the return shipping is on the customer.
Old Sun, Aug-13-2017, 07:16:49 PM   #18
ThunderMoose
Your dealer is full of crap. But they generally are. You can call around to different dealerships and eventually one will not be a dick and look it up.
#67 2017 NASA TX TT3 Champion
Old Mon, Aug-14-2017, 08:48:18 PM   #19
rhythim
Career parts guy
Reputation: 0 rhythim is on a distinguished road
They've actually gone to where they're paying for shipping now. If you email them, they'll send you new postage-paid labels to stick on your containers. Got a couple of them last month.
Jump to top rhythim is offline   Reply With Quote
Discussing Rod bearing check in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
