Old Wed, Aug-09-2017, 03:23:56 PM   #1
Oldylr
Reputation: 0 Oldylr is on a distinguished road
Default Rod bearing check
Can someone run a VIN to see? If so, PM me, thanks guys!
Jump to top Oldylr is offline   Reply With Quote
Old Wed, Aug-09-2017, 03:54:17 PM   #2
warpig12354
Reputation: 0 warpig12354 is on a distinguished road
Default Re: Rod bearing check
You can contact your dealer.
2003 M3 CB 6MT | Rogue Engineering | Michelin | Beisan | Dinan | AKG | TMS | BBS | Bilstein | BimmerWorld | GroundControl | PFC | CPI
Jump to top warpig12354 is offline   Reply With Quote
Old Wed, Aug-09-2017, 04:06:36 PM   #3
Oldylr
Oh wow, thanks!
Old Wed, Aug-09-2017, 05:54:42 PM   #4
Dr M3an M3
GroupBuyingPower@outlook. com
Dr M3an M3's Avatar
Often there (should) be a punched out stamp on the driver's door seal area on the car that shows what recall work has been performed. Depending on who did the work, it might not be there. Calling the dealer is your best bet.
IG: DrM3anM3
Mods: Karbonius CSL Airbox, OE CSL Snorkel w/ working Flap, OE Map Sensor + OE Air Rail, CSL Engine management with CSL converted DME, Supersprint V1 Stepped Headers w/ Oversized Catless section 1, SS Resonated X-Pipe section 2, RE El Diablo Muffler, WPC treated rod-bearings, VinceBar (weld) + Redish Plates, Full Beisan VANOS lockdown, BBS LMs w/ PSS, Streamline CSL Bumper, CSL style CF diffuser, Vorsteiner CF CSL Bootlid, CSL SMG Engine DME tune, CSL '255' SMG DME tune, .
Active Group-Buys (PM if Interested): OE CSL Bootlids, CSL Bumper, OE CSL Wheels, Supersprint Headers/Exhaust MEGA thread, CSL Airbox, Brembo, Cams/Pistons...and more to come!
Old Wed, Aug-09-2017, 07:09:02 PM   #5
arkow
Reputation: 0 arkow is on a distinguished road
is this the recall rod bearings? if i had them done am i good? or should i replace them anyway?
Jump to top arkow is offline   Reply With Quote
Old Wed, Aug-09-2017, 07:13:43 PM   #6
Dr M3an M3
Dr M3an M3's Avatar
How many miles are on your car? Rod-bearings are a wear-and-tear item. Eventually they will need to be replaced, regardless of if they were swapped during the recall or not. When they will need to be replaced will depend on how many miles (and thus wear) are on them since being installed (whether original or recall replaced). The best way to monitor their health is via a Blackstone Oil Analysis. The kit is free, the cost to run the analysis is cheap ($25-$35) and the benefit is enormous, even if it is just for peace-of-mind. Best thing to do if you are unsure, is plan to have an oil analysis done during your next oil change. Just request the free kit ahead of time.
IG: DrM3anM3
Old Wed, Aug-09-2017, 07:21:03 PM   #7
arkow
I have 130k miles and they were replaced long time ago so i'm due. Does the oil has to be relatively new or older oil will be ok? i have a bottle of my last oil change and was wondering if i can use that or should i wait till next replacement to send that over to blackstone? I have the kit from blackstone already..
Old Wed, Aug-09-2017, 07:32:00 PM   #8
Dr M3an M3
Dr M3an M3's Avatar
Have a read here, this will answer your questons:
https://www.blackstone-labs.com/faq.php
IG: DrM3anM3
Old Wed, Aug-09-2017, 07:44:43 PM   #9
arkow
Great, thank you.
Old Fri, Aug-11-2017, 11:48:09 AM   #10
Oldylr
Called the dealer, they won't give me the service history of the car, only if it had been serviced there. They checked on recall status but said that they couldn't send me anything due to some privacy act.
Discussing Rod bearing check in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
