Old Wed, Aug-09-2017, 12:31:50 AM   #1
demolitionskunk
demolitionskunk's Avatar
Reputation: 0 demolitionskunk is on a distinguished road
Default 2006 model year subframes
I've heard that for the 2006 production year, BMW gave the M3 the same double floor as the vert so it doesn't get cracks at the subframe mounts.
Has anyone else heard this? Is it true?
Jump to top demolitionskunk is offline   Reply With Quote
Old Wed, Aug-09-2017, 12:48:24 AM   #2
norcal420
mass nerder
norcal420's Avatar
Reputation: 0 norcal420 is on a distinguished road
Default Re: 2006 model year subframes
I have not heard that but I have heard that the E46 M3 failure rate on subframes is about 8% overall.
Jump to top norcal420 is offline   Reply With Quote
Old Wed, Aug-09-2017, 01:04:50 AM   #3
demolitionskunk
I just found this thread where someone says (near the bottom of the page) the '06 M3 has the vert subframe.
https://www.reddit.com/r/BMW/comment...rcement_heres/
Hopefully it's true...
Old Wed, Aug-09-2017, 01:07:16 AM   #4
demolitionskunk
Unfortunately, I discovered my '02 coupe was part of that 8% just before I sold it.
Old Wed, Aug-09-2017, 01:37:14 AM   #5
STAATS
STAATS's Avatar
I think that James at Redish Motorsport has discussed this "myth" about the 'vert floor before... I don't think it is any thicker I think there is some additional plastic inserts in the sandwich which he postulates are supposed to be "dams" for when you use the BMW Structural Foam.
I do think I read somewhere that the later years (05 and 06 I think) did recieve the 'vert floor... So I think the 06 does have the 'vert floor but it is not immune to the subframe issue.
Google some of the videos from Redish Motorsport on this or have a look at some of the technical breakdowns of the issues by VinceSE2 and you will see no E46 is immune or "fixed" from factory...
STAATS
Old Wed, Aug-09-2017, 01:45:51 AM   #6
lmattiso
lmattiso's Avatar
Reputation: 0 lmattiso is on a distinguished road
All the floors are the same except BMW moved a couple of the spot welds around. Not sure what year that happened. STAATS is correct, the only change was the plastic dams which provide no additional structural support. The vert has an additional bulkhead welded on but the subframe itself is identical. Reddish does go over that in one of his teardown videos.
Sent from my Pixel using Tapatalk
Jump to top lmattiso is offline   Reply With Quote
Old Wed, Aug-09-2017, 04:52:16 PM   #7
Slowmobile
Na Na Na Na Na Na Na Na
Reputation: 0 Slowmobile is on a distinguished road
Can't be that low...
Legen... Wait For It... ///M
Jump to top Slowmobile is offline   Reply With Quote
Old Wed, Aug-09-2017, 05:08:11 PM   #8
Mr. Wolfe
Anti-Bling
Mr. Wolfe's Avatar
It's not. People just don't know how to check them. You cannot check the cracks without removing the subframe.
Mr. Wolfe
Old Wed, Aug-09-2017, 06:16:49 PM   #9
2006E46M3fan
2006E46M3fan's Avatar
Have an 06, had a small crack. Now reinforced.
Jump to top 2006E46M3fan is offline   Reply With Quote
Old Wed, Aug-09-2017, 06:22:03 PM   #10
ThrowinShapes
ThrowinShapes's Avatar
Reputation: 0 ThrowinShapes is on a distinguished road
Mr. Wolfe
*And borescope the tops of the receiver spot welds.
[06' AW/Cinnamon] [6MT] [Slicktop] [Manual Seats]
Journal - Update 2017-02-28
FS: Center Console | US Headers / Rear O2 | Rent: SIR B90-BMW Rear Wheel Bearing Tool
Jump to top ThrowinShapes is offline   Reply With Quote
Discussing 2006 model year subframes in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
