Old Wed, Aug-09-2017, 12:05:10 AM   #1
donmonfon
Reputation: 0 donmonfon is on a distinguished road
Default 1995 M3, Tail Light Nut Stuck
Hello I recently had a tail light failure code pop up, and of course the passenger running lights were bad. So I got new ones but they still didn't work. So I changed sockets, and still nothing. So I am trying to take out the entire housing itself to see if there's something wrong with it, but I can't get one of the nuts off. I got the 3, others off, and the electrical connector, but this nut keeps spinning, but doesn't go anywhere. If anyone has a solution or idea, please let me know! Thanks!
Sent from my SAMSUNG-SM-G900A using Tapatalk
Jump to top donmonfon is offline   Reply With Quote
Old Wed, Aug-09-2017, 12:06:24 AM   #2
donmonfon
Default Re: 1995 M3, Tail Light Nut Stuck
Here's a photo of the nut, the washer it's attached to just spins, even if I try to stop it with a flathead screwdriver.
Old Wed, Aug-09-2017, 02:34:58 AM   #3
LuckyM301
LuckyM301's Avatar
Reputation: 0 LuckyM301 is on a distinguished road
Get some vice grips on the stud and use a wrench to get the nut loose until you can thread it off by hand
Sent from my SAMSUNG-SM-G890A using Tapatalk
Jump to top LuckyM301 is offline   Reply With Quote
Old Wed, Aug-09-2017, 11:41:54 AM   #4
M_Parallel
Mr. OEM
M_Parallel's Avatar
Netherlands
The washer is part of the screw iirc. Does the thread also spin? In that case the plastic piece this thread normally is secured to, is broken. Then you may as well try and pull it out.
Old Wed, Aug-09-2017, 01:50:29 PM   #5
Double E
Double E
Reputation: 0 Double E is on a distinguished road
+1 Vice grip that f'er and then open end wrench on it.
'97 M3/2/5. Hellrot on Black ...and a racecar.
Jump to top Double E is offline   Reply With Quote
Old Wed, Aug-09-2017, 04:17:09 PM   #6
betrezra
The stud could be spinning inside the plastic housing..... you will have to put an open end on the nut.... and hold the stud with a vise grips..... to get it loose.... try not to damage the threads whil'st doing so ;1)
E36M3
Old Wed, Aug-09-2017, 04:27:14 PM   #7
M_Parallel
Mr. OEM
M_Parallel's Avatar
Netherlands
Which will happen.
I would take a dremel and make a small slit at the end of the thread, then you can take a flatblade screwdriver to stop the thread from spinning, and will make sure the thread won't be damaged.
Old Wed, Aug-09-2017, 06:58:27 PM   #8
donmonfon
No, the stud is not spinning which is weird.
Old Wed, Aug-09-2017, 06:58:57 PM   #9
donmonfon
I'll definitely try that today. Thanks!
Old Wed, Aug-09-2017, 07:42:38 PM   #10
LuckyM301
LuckyM301's Avatar
If your worried about the threads put a rag or something between the vise and stud
Discussing 1995 M3, Tail Light Nut Stuck in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
