Old Thu, Aug-03-2017, 07:25:22 PM   #11
TheJDub-E36
TheJDub-E36's Avatar
Reputation: 0 TheJDub-E36 is on a distinguished road
Default Re: Potential Radiator Enhancements
Originally Posted by HoonCrepe View Post
Okay so stock overflow hose. I have a replacement one already that I bought off amazon because next day shipping when I was itching to fix it. Maybe I should go to bmw to get the stock one though. A stewart water pump. Stock thermostsat. Anything else?
Check the overflow tank for any cracks or signs of leaking, coolant level sensor, and auxiliary fan switch are the only other things to check.
The hose you got on Amazon is probably fine.
Jump to top TheJDub-E36 is online now   Reply With Quote
Old Thu, Aug-03-2017, 07:27:56 PM   #12
HoonCrepe
Reputation: 0 HoonCrepe is on a distinguished road
Alright cool. I was actually looking at aftermarket overflow tanks as well to clean up the look of the engine bay a little bit. Thank you for all your information. I just have to figure out where all those things are now.
Jump to top HoonCrepe is offline   Reply With Quote
Old Thu, Aug-03-2017, 07:33:06 PM   #13
TheJDub-E36
once you start taking everything out it's really easy to get it all back together, I got both the Mishimoto radiator and overflow tank new from my friend for a crazy good deal but they're not what I would call an upgrade, it was just a good deal
Just a heads up It's a nightmare to bleed this radiator:/ I had to take the driver side hose off and fill it from there to get most of the air out.
Old Thu, Aug-03-2017, 07:38:33 PM   #14
HoonCrepe
Okay so just judging from your pictures, that is the same radiator that I have. And now I have even more questions. So when I had the overflow hose blow out it was actually on the way too work and I heard a hissing after I parked the car. I saw the issue and I cut the damaged part of the hose and re attached it. Then I filled the overflow tank with distilled water once the car had cooled down. It then proceeded to overheat on the ride home or at least come really close to overheating on the ride home. When I popped the hood there was no more leaking and no hissing and no obvious signs of leaks besides the massacre that had occurred in the morning. So, how exactly do you bleed this system once I reinstall it?
Old Thu, Aug-03-2017, 07:44:35 PM   #15
TheJDub-E36
You probably had some air in the system, there's a lot of great posts on here so I would start by searching but this video covers basically everything on the cooling system for our cars
Old Thu, Aug-03-2017, 07:50:25 PM   #16
HoonCrepe
https://youtu.be/F_ETVawLBtA
Dude, Nice!!!! Thank you!!
Old Thu, Aug-03-2017, 07:58:07 PM   #17
TheJDub-E36
No worries, good luck on the process!
Old Thu, Aug-03-2017, 10:09:52 PM   #18
bluptgm3
Default Potential Radiator Enhancements
Keep in mind that the ~$200 Stewart has the same life expectancy as the stock pump, as it contains the same size bearings. Ask me how I know. Additionally, Stewart recommends their pumps NOT be under driven, I don't know if that is a general statement that includes the 88-8010-330.
Old Thu, Aug-03-2017, 11:09:26 PM   #19
Originally Posted by bluptgm3 View Post
Keep in mind that the ~$200 Stewart has the same life expectancy as the stock pump, as it contains the same size bearings. Ask me how I know. Additionally, Stewart recommends their pumps Not be under driven, I don't know if that is a general statement that includes the 88-8010-330.
With a lifetime warranty and 100k+ mi expectancy who cares? Itís the better pump.
Old Thu, Aug-03-2017, 11:44:05 PM   #20
bluptgm3
LOL!!! The warranty is limited 1 year, I tried that.
Discussing Potential Radiator Enhancements in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
