Old Sat, Jul-29-2017, 07:48:41 PM   #1
JitteryJoe
Default Steering column gauge pod power source
Is there a generally used spot to grab power for a steering column gauge pod? I'm mounting mine, have the steering wheel off as well as the kick panel. There are a lot of wires under there. Is there a well-known location people are grabbing power for the gauges?
Thanks!
Joe
Old Sat, Jul-29-2017, 07:54:25 PM   #2
M_Parallel
Mr. OEM
M_Parallel's Avatar
Netherlands
Default Re: Steering column gauge pod power source
Comb connector box. (Almost) any color wire you need. Just push in a new spade connector.
Old Sat, Jul-29-2017, 08:59:38 PM   #3
PITT M3 RR
PA
PITT M3 RR's Avatar
I use the wires directly from the ignition tumbler. Red for + at all times, green for + in run and start.
S54 E36 BUILD
Old Sat, Jul-29-2017, 09:43:51 PM   #4
JitteryJoe
Thank both of you!
Old Sun, Apr-22-2018, 02:00:09 AM   #5
JitteryJoe
Quick question. I've got all the wiring in place. I have 2 gauges mounting on the steering column in a RallyRoad gauge pod. One gauge has Oil pressure and Oil temp. The other has Water temp and Volts. Both digital readouts. I'm thinking oil on the left and water on the right. Since it would be a bit of a pain to swap later, any thoughts? Not the biggest decision I've had to make but if there is a "standard" placement then I'd just assume do it right.
Thanks!
Joe
Old Sun, Apr-22-2018, 02:59:36 AM   #6
PITT M3 RR
PA
PITT M3 RR's Avatar
I’d do oil on left too
S54 E36 BUILD
Discussing Steering column gauge pod power source in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
