Old Fri, Jul-28-2017, 06:25:51 PM   #1
entendu
Reputation: 0 entendu is on a distinguished road
Default Coolant leak
Started up today and got the coolant dummy light. Drove to my appointment and the light went off 2-3 minutes into it. Lifted the hood after and found this:
Confirmed it's coolant. The upper tank looks fine, upper hoses ok. Possibly the sensor o-ring?
2003 6mt, 44k miles.
Jump to top entendu is offline   Reply With Quote
Old Fri, Jul-28-2017, 09:07:25 PM   #2
redline8000
M-Power Hungry!
redline8000's Avatar
Reputation: 0 redline8000 is on a distinguished road
Default Re: Coolant leak
Yea, it could be your lower hose coolant temp sensor or it also could be your water pump (worst case scenario). I would dry off the wet areas, start the car rev engine a little, maybe have someone rev it and you look to see where the coolant leak is coming from. I would never drive to my destination if I see the low coolant light on these cars. Overheat the engine just a little bit and you could blow the head gasket. Not a cheap thing to fix on this car by any stretch of the imagination.
GL with her. BTW, if you have not completed a full cooling system overhaul then may be a good time to do so.
“Everything is determined…by forces over which we have no control. It is determined for the insect as well as for the star. Human beings, vegetables, or cosmic dust—we all dance to a mysterious tune, intoned in the distance by an invisible piper.”
—Albert Einstein --- Quoted in interview by G.S. Viereck , October 26,1929. Reprinted in “Glimpses of the Great”,1930.
Jump to top redline8000 is offline   Reply With Quote
Old Fri, Jul-28-2017, 09:09:58 PM   #3
Drewster
Drewster's Avatar
I'd put money on coolant temp sensor O-ring. Otherwise, hopefully it's not something that's cracking/ ready to blow
Old Fri, Jul-28-2017, 09:14:23 PM   #4
I'd remove the fan and shroud and get a better look. Or take it to an Indy.
/// 2004 SilberGrau M3 · Coupe · 6MT · slicktop · manual seats · no nav______________________JOURNAL
-Evolve-R Alpha N · Evolve CSL CF Airbox · Eventuri Scoop · Euro Headers · Euro cat sect 1 · Dinan sect 3 · BMW Motorsport 4.10 · Besian · D/A pullies/fan delete · WPC rod bearings
-TMS Camber & Subf plates · RE Street Trans Mounts · AKG poly SUB/DIFF · SDW RTAB · ZHP knob + UUC DSSR · GroundControl S/A (Koni/Eibach 440/550) + tall RSMs
-OE CSL trunk · APEX 75mm Studs · Sportline 8S 18"x8.5/9.5" · MPSS 245/275 · ss brake/clutch lines
-Pioneer DEH-80PRS · Eclipse PA5422 · CDT HD-6 + WS-100i · CDT EX-530 · 8" Kicker
DD/Beater: 1999 Civic LX - Kenwood x998 · PPI 1600.4 · CDT HD-6 + HD-100 · CDT EX-530 · Clarion 10"
Old Fri, Jul-28-2017, 09:58:16 PM   #5
Move_Over
Reputation: 0 Move_Over is on a distinguished road
My coolant sensor o ring was leaking this week, just used a fuel injector O ring and quit leaking. Have a friend plug up your hole while you quick swap O rings. Pretty sure there is a DIY thread on here some where with the ACE hardware o ring part number. Or, BMW part number is 13621743299 - found here.
https://www.ecstuning.com/b-genuine-...YaAgVoEALw_wcB
Little FYI - local dealer told me they could not sell me JUST the O ring, tried to sell me the whole sensor to the tune of 71 dollars. Don't let them pull a fast one on you.
Jump to top Move_Over is online now   Reply With Quote
Old Sat, Jul-29-2017, 12:30:13 AM   #6
entendu
Oooo where's that? I ordered one but it won't be here till monday.
Old Sat, Jul-29-2017, 02:26:05 AM   #7
m3e46freak
M3 Freq
m3e46freak's Avatar
Reputation: 0 m3e46freak is on a distinguished road
Germany
The o-rings are shit. I'd put my bet there also
Rock Hard Abs Racing
KWV2!
18X10 CCW CLASSIC!
CPI Headers!
RESONATORS AND SUPERSPRINT!
DINAN!
FRANK!! 311RWHP-260Torque
m3e46freak@yahoo.com for outside contacting
ebay/craigslist verified 100% FEEDBACK
m3forum 96% FEEDBACK
m3post/e46fanantics Great FEEDBACK
zpost/bimmerforum Great FEEDBACK
Jump to top m3e46freak is offline   Reply With Quote
Old Sat, Jul-29-2017, 04:02:29 AM   #8
Move_Over
https://www.bimmerforums.com/forum/s...g-for-59-cents
http://www.acehardware.com/product/i...uctId=59901736
Should be the same.
Old Sat, Jul-29-2017, 04:35:01 AM   #9
entendu
Ty guys. Will report back after I change the oring out.
Old Thu, Aug-10-2017, 09:39:37 PM   #10
entendu
Swapped the o-ring, but still leaking Slow leak, maybe 1/2 gallon per week.
Now I have a choice -- take it to an indy, or buy a pressure tester and take over my garage for a while.
I am mechanically inclined but I've never done coolant system work, just easy oil/brakes/rotors stuff. Should I bother trying to tackle it myself, or am I just going to get into a bigger mess?
Discussing Coolant leak in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
