Old Thu, Jul-27-2017, 11:01:44 PM   #1
MaynardZed
MaynardZed's Avatar
Reputation: 0 MaynardZed is on a distinguished road
Default S52 sticking lifter?
So finally got a replacement S52 put in may race car after blowing mine in May. The head on this replacement engine had to be rebuilt because it ended up having 6 bent valves (dishonest seller). Seemed to run fine up and down the street near the shop after the rebuild.
Dyno'd it for classing purposes and it comes in a little low on torque compared to my old engine. 233hp/208tq vs 237hp/230tq on my old engine. Also it sounds like it's missing sometimes intermettently. Repeated compression check like 3 times, all 6 come in around 134psi give to take a few lbs. Plugs look good and the same in all 6 holes too. Did the coil swap drill also. Best we can figure is a lifter/follower is sticking / collapsing? Maybe not opening all the way? Ran a tad rich like 11/1 A/F while on dyno.
Our current consensus it to go ahead and run it, thinking maybe its a sticking lifter / follower?, hoping it needs a little break in? Maybe add a little ATF to the oil?
Any thoughts?
1999 BMW E36 M3
Ground Control Race Suspension
Full Cage - Flatout Motorworks
OMP Full Containment Race Seat
S52 with bolt ons 237 rwhp (DynoJet)
2600lbs empty
Jump to top MaynardZed is offline   Reply With Quote
Old Fri, Jul-28-2017, 12:27:00 PM   #2
Double E
Double E
Reputation: 0 Double E is on a distinguished road
Default Re: S52 sticking lifter?
Vanos issue?
'97 M3/2/5. Hellrot on Black ...and a racecar.
Jump to top Double E is offline   Reply With Quote
Old Fri, Jul-28-2017, 02:46:47 PM   #3
mpwrcpe
The Throbbing Gristle
Reputation: 0 mpwrcpe is on a distinguished road
Tom, 134 PSI seems a bit low no? Was the motor warm? I would think you should see at least 150 on that motor.
///'95 Avus M3 S54B32 - Stripped, caged @ 2681#
///'90 Calypso 325ic (70K miles)
///'72 Chamonix 2002 (Restoration project)
///'87 Alpine 535is
'15 Touareg TDI (Race car hauler)
Jump to top mpwrcpe is offline   Reply With Quote
Old Sat, Jul-29-2017, 04:03:44 AM   #4
MaynardZed
MaynardZed's Avatar
Originally Posted by Double E View Post
Vanos issue?
Makes some sense, could explain loss of torque yet peak hp close to normal?
Agreed. Motor not fully warm but not totally cold either. Didn't check temp gauge unfortunately. Dyno shop only a few miles from race shop. Probably about 30-40 minutes after last dyno run. Checked compression while on trailer still.
Update: Yesterday here at home I let car idle to fully warm. Purrs like kitten at idle. Rev too 2000, 3000, 4000 and hold for 20 seconds each time, after 3000 it sputters and stalls after letting off throttle. Repeated the process and its fine each time.
1999 BMW E36 M3
2600lbs empty
Discussing S52 sticking lifter? in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
