Old Sat, Jul-22-2017, 07:32:09 PM   #11
S4Sprint
Reputation: 0 S4Sprint is on a distinguished road
Default Re: 97 bmw m3 p0430
How cheap is the injector rebuilding?
Jump to top S4Sprint is offline   Reply With Quote
Old Sat, Jul-22-2017, 08:11:53 PM   #12
englishtom1596q
englishtom1596q's Avatar
Originally Posted by dallasbrandt View Post
Just a shot in the dark, but how about "rebuilding" the injectors. This I mean by replacing the little filters and external seals on the injectors. Super cheap and quite easy, maybe you got a clog and causing a running issue.
It made my M3 run better, and I had no symptoms, I just wanted to do it.
Now that I know this, it will be where I start on any running condition because it is cheap and easy... as well as spark plugs
That would be picked up on upstream O2 sensors, not downstream. Downstream sensor measure how well the Cats are doing their jobs. Upstream control fuel/air ratio via injector duty cycles.
Old Sat, Jul-29-2017, 01:20:18 AM   #13
Jawse36
Jawse36's Avatar
Reputation: 0 Jawse36 is on a distinguished road
Generally speaking, catalyst efficiency codes are indicative of catalyst failure. Unfortunately this prob means replacement of the catalyst is necessary. If that's the case, look aftermarket because a factory catalyst will cost an arm and a leg.
Jump to top Jawse36 is offline   Reply With Quote
Discussing 97 bmw m3 p0430 in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
