Old Wed, Jul-19-2017, 07:10:11 PM   #31
zaharias
Greece
Default Re: Suspension - Koni Yellow (what springs & settings?) E46 M3
Originally Posted by Gary Powers View Post
I replaced my AC Schnitzer shocks with koni yellows and run them with my old AC Schnitzer springs. I initially had them at the softest setting and it was too underdamped, so I went up 2 clicks and this setting feels about right. It's still a pretty stiff ride, but the handling is incredible. I'm also running GC camber plates with -2.3 degrees in the front. I'm considering getting softer springs since I daily my car, but I'm happy with it for now.
Many thanks mate!!
That's what my setup is and what I plan to do!!
Jump to top zaharias is offline   Reply With Quote
Old Wed, Jul-19-2017, 08:17:47 PM   #32
Do you mean 2 full turns? There are no clicks. Also, 2 turns is a lot - would maybe do that with 650lb rates (shouldn't go heavier than that on Koni yellows). I can't imagine the ACS springs were that much stiffer than stock. You set your shock rebound to your spring rates.
/// 2004 SilberGrau M3 Coupe 6MT slicktop manual seats no nav______________________JOURNAL
-Evolve-R Alpha N Evolve CSL CF Airbox Eventuri Scoop Supersprint V1 stepped SS V1 S pipe + 200 cell HFC OE sect 2 Supersprint Sport BMW Motorsport 4.10 Besian RE pullies/fan delete WPC rod bearings
-TMS Camber & Subf plates RE Street Trans Mounts AKG poly SUB/DIFF SDW RTAB ZHP knob + UUC DSSR GroundControl S/A (Koni/Eibach 440/550) + tall RSMs
-OE CSL trunk APEX 75mm Studs Sportline 8S 18"x8.5/9.5" MPSS 245/275 ss brake/clutch lines
-Pioneer DEH-80PRS Eclipse PA5422 CDT HD-6 + WS-100i CDT EX-530 8" Kicker
Old Wed, Jul-19-2017, 10:30:09 PM   #33
Gary Powers
Taking the long way home.
Gary Powers's Avatar
Reputation: 0 Gary Powers is on a distinguished road
Sorry, didnt mean clicks. Just 2 increments higher than softest. ACS springs are actually quite stiffer than stock. The ride is significantly lower and stiffer compared to a stock m3.
'03 E46 M3
Jump to top Gary Powers is offline   Reply With Quote
Old Thu, Jul-20-2017, 03:51:17 AM   #34
EricSMG
40 something
The Konis are infinitely adjustable so how did you measure two increments?
Old Thu, Jul-20-2017, 05:28:03 AM   #35
Also thought I'd mention that I found many people saying that ACS springs were made by Eibach for what it's worth. Never could find the rates.
Old Thu, Jul-20-2017, 11:51:54 AM   #36
zaharias
Greece
Correct.
I consider them soft springs I think softer than Eibach.
Old Thu, Jul-20-2017, 04:18:21 PM   #37
Gary Powers
Two 1/4 turns.
'03 E46 M3
Old Sat, Aug-05-2017, 04:59:00 AM   #38
zaharias
Greece
On Monday I will get these installed.
Settings for the rear
Old Sat, Aug-05-2017, 12:16:46 PM   #39
Maybe you can find out who made the springs for ACS? Could be H&R, for example. You might be able to figure out srping rates from there.
Eibachs are the best aftermarket spring maker, imo, so you couldnt go wrong getting a set to match with new Konis, then run the konis full soft, tightening them a quarter turn every 5k-10k as they age. My suggestion.
I think you're being a little aggressive in you're rate of turning those up! I went from full soft to 1/2 turn off full soft over 140,000 miles of use, to keep them feeling the same! At your rate I would have been at full stiff 3 times over!
Old Sat, Aug-05-2017, 03:28:33 PM   #40
Off the shelf Konis lasted you 140k?! I was thinking I'd replace at about 60k, of course I don't drive it much, so that would last a long time for me personally. Shocks usually lose most of their effectiveness after the first 10k no?
Discussing Suspension - Koni Yellow (what springs & settings?) E46 M3 in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
