Old Sat, Jun-24-2017, 06:43:16 AM   #21
Default Re: Suspension - Koni Yellow (what springs & settings?) E46 M3
I think CSL springs and konis (or Bilsteins like a memeber here has done) on full soft would be a smashing combo!
/// 2004 SilberGrau M3 Coupe 6MT slicktop manual seats no nav______________________JOURNAL
-Evolve-R Alpha N Evolve CSL CF Airbox Eventuri Scoop Euro Headers|sect 1 BMW Motorsport 4.10 Besian D/A pullies/fan delete WPC rod bearings
-TMS Camber & Subf plates RE Street Trans Mounts AKG poly SUB/DIFF SDW RTAB ZHP knob + UUC DSSR GroundControl S/A (Koni/Eibach 440/550) + tall RSMs
-OE CSL trunk APEX 75mm Studs Sportline 8S 18"x8.5/9.5" MPSS 245/275 ss brake/clutch lines
-Pioneer DEH-80PRS Eclipse PA5422 CDT HD-6 + WS-100i CDT EX-530 8" Kicker
Old Sat, Jun-24-2017, 08:19:04 AM   #22
nbriggs1988
Reputation: 0 nbriggs1988 is on a distinguished road
Thanks guys, guess I'll stick with stock unless I can find a set of CSL springs for a reasonable price
Sent from my HTC 10 using Tapatalk
Jump to top nbriggs1988 is offline   Reply With Quote
Old Sat, Jun-24-2017, 12:06:04 PM   #23
zaharias
Greece
Hard to find used! And new are a bit expensive.
Stock or Eibachs (if you want it a tad lower).
Jump to top zaharias is offline   Reply With Quote
Old Wed, Jul-05-2017, 04:18:38 AM   #24
IronJoe
IronJoe's Avatar
Reputation: 0 IronJoe is on a distinguished road
Finished my install. Here's Koni adjustables paired with Tein s-tech springs. I'm pretty happy with the ride, compliant for a daily while providing a nice drop. No rubbing anywhere.
E30 M3 cabriolet build
Cosmos Black E36 M3 Sedan
Topaz Blue E46 M3 build journal
Jump to top IronJoe is offline   Reply With Quote
Old Wed, Jul-05-2017, 04:51:23 AM   #25
mrfuzzybagels
(❍ᴥ❍ʋ)
mrfuzzybagels's Avatar
Reputation: 0 mrfuzzybagels is on a distinguished road
Nice. What wheels are those? VMR v703? Wheel and tire sizes? I've been wanting to switch to a darker wheel lately.
Jump to top mrfuzzybagels is offline   Reply With Quote
Old Wed, Jul-05-2017, 05:02:14 AM   #26
IronJoe
IronJoe's Avatar
Yessir V703 in gunmetal. 18x8.5 et35 front 18x9.5 et22 rear. 235/40 and 265/35, respectively. Nothing too extreme for a daily.
To contribute to the thread: I set the Konis at full soft after recommendations here. No complaints.
Old Mon, Jul-17-2017, 05:22:37 PM   #27
zaharias
Greece
Recieved my Konis today.
Taking them out of the box Koni has set them to full soft?
Old Mon, Jul-17-2017, 06:21:46 PM   #28
Probably, but I would just make sure my self. The fronts are really easy. You have to completely compress the rears before turning them. My trick to to stick the top of the shaft upside down in a vice (with rubber jaw covers) and then use my body weight to compress the shock body, then turn - just remember you're upside down when determining whether to determine to turn clock or counter-clockwise. I don't remember off the top of my head, but the white knob that comes with the shocks will tell you.
Old Mon, Jul-17-2017, 09:20:21 PM   #29
zaharias
Greece
Thanks Tyler!!
Yes fronts are easy.
I was mostly asking for the rears.
I will sure check them before installation.
Also found this video.
Old Tue, Jul-18-2017, 09:42:08 PM   #30
Gary Powers
Taking the long way home.
Gary Powers's Avatar
Reputation: 0 Gary Powers is on a distinguished road
I replaced my AC Schnitzer shocks with koni yellows and run them with my old AC Schnitzer springs. I initially had them at the softest setting and it was too underdamped, so I went up 2 clicks and this setting feels about right. It's still a pretty stiff ride, but the handling is incredible. I'm also running GC camber plates with -2.3 degrees in the front. I'm considering getting softer springs since I daily my car, but I'm happy with it for now.
'03 E46 M3
Jump to top Gary Powers is offline   Reply With Quote
Discussing Suspension - Koni Yellow (what springs & settings?) E46 M3 in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
