Old Thu, Jun-22-2017, 02:36:42 AM   #11
MrCooperS
Reputation: 0 MrCooperS is on a distinguished road
Default Re: Suspension - Koni Yellow (what springs & settings?) E46 M3
This is a great thread. I currently have the Eibach Pro springs on stock suspension. Once my suspension wears out, I'm considering the Koni yellows. Would this be a good combination for street and autocross? What setting would be good for 50/50 street/autocross?
Jump to top MrCooperS is offline   Reply With Quote
Old Thu, Jun-22-2017, 03:57:23 AM   #12
Yes Mr. Cooper. Maybe 3/4 turn F and 1 turn rear. You don't want the rebound too slow (stiff) and not be ready (full travel) for the next compression.
Honestly, if the Konis are brand new, you could even start at full soft and turn them as they age. The eibach pro kit isn't that high of a spring rate nor does it lower the car that much.
/// 2004 SilberGrau M3 Coupe 6MT slicktop manual seats no nav no xenon no anything JOURNAL
Evolve-R Alpha N Evolve CSL CF Airbox Eventuri Scoop Supersprint V1 stepped 63mm SS V1 S pipe 63mm + 200 cell HFC OE sect 2 60mm SS Sport 60mm BMW Motorsport 4.10 Besian RE pullies/fan delete WPC rod bearings TMS Camber & Subf plates RE Trans Mounts AKG poly SUB/DIFF 95a SDW RTAB ZHP knob + UUC DSSR GroundControl S/A (Koni/Eibach 376/440) + tall RSMs OE CSL trunk APEX 75mm Studs Sportline 8S 18"x8.5/9.5" MPSS 245/275 Brembo 996 36/40 345mm Textar Pioneer DEH-80PRS Eclipse PA5422 CDT HD-6 + WS-100i CDT EX-530 8" Kicker
Old Thu, Jun-22-2017, 05:08:12 AM   #13
zaharias
Greece
Maybe you can find out who made the springs for ACS? Could be H&R, for example. You might be able to figure out srping rates from there.
Eibachs are the best aftermarket spring maker, imo, so you couldnt go wrong getting a set to match with new Konis, then run the konis full soft, tightening them a quarter turn every 5k-10k as they age. My suggestion.
I think Eibach was making the springs (shocks were made by Sachs) for AC Schnitzer but with Schnitzer's specs as they are considered "softer" than the Pro Kit (I think)!
Thanks TboneM3!!
Jump to top zaharias is online now   Reply With Quote
Old Thu, Jun-22-2017, 04:35:34 PM   #14
IronJoe
IronJoe's Avatar
Reputation: 0 IronJoe is on a distinguished road
Ah, love this forum.
My set of Koni yellows are in transit, and I've been thinking of what settings to run them. I have Tein springs which I believe are a bit lower than some other aftermarket options, so I'm thinking of setting the Koni's a bit firmer.
Anyone pair koni & tein and live to tell the tale? I ran them on my E36 with H&R sports and kept them at full soft, actually rode really well.
E30 M3 cabriolet build
Cosmos Black E36 M3 Sedan
Topaz Blue E46 M3 build journal
Jump to top IronJoe is offline   Reply With Quote
Old Thu, Jun-22-2017, 05:31:33 PM   #15
Lower doesn't always mean stiffer and that's the case with the Teins. They're not a great spring because they're too soft for how much they lower the car.
Lowering springs will reduce the travel of your suspension; it's wrong to always associate a lowering spring with a stiffer spring notwithstanding the fact that yes, all springs get progressively stiffer as they're compressed. So in the case of Tein, you have a spring that's shorter than stock, but not stiffer (or not much anyway).
You chose your dampening based on spring rate. I wouldn't run the Konis much off of full soft as I don't believe the Tein's spring rate is much, if at all, heavier than stock. Your car being lower mean less travel, not that it's stiffer. You'll just be hitting the bump stops more, so make sure your bumps are nice and new.
Having said that, I wouldn't use Teins if you're at all serious about suspension.
Old Thu, Jun-22-2017, 08:08:33 PM   #16
IronJoe
IronJoe's Avatar
Awesome, thanks Tbone! I will most likely run them on full soft then. The Teins were cheap on craigslist and probably won't stay on the car long-term.
My car is a daily driver (~80m highway commute per day) so I am not really that "serious" about suspension in terms of racing, etc. I've got my E30 for crazy handling shenanigans
Old Thu, Jun-22-2017, 10:06:00 PM   #17
No worries. Ya the drop from teins looks amazing, but drive fast and you'll be on the bumpstops.
Old Fri, Jun-23-2017, 10:43:42 PM   #18
nbriggs1988
Reputation: 0 nbriggs1988 is on a distinguished road
Wanted to bump this thread as I'm looking into getting some Konis as well to address a leaking rear shock.
I'm on the fence on getting springs for my car or staying with the stock springs.
H&R's are on sale at ECS right now and was wondering if anyone here has any experience running those with the Konis, and what kind of ride quality it provides.
I'm mostly trying to retain a stock feel in terms of stiffness. I don't want to make the ride too harsh as I have a child.
Thanks guys!
Sent from my HTC 10 using Tapatalk
Jump to top nbriggs1988 is offline   Reply With Quote
Old Sat, Jun-24-2017, 12:22:10 AM   #19
H&Rs crash a bit up front imo. I think Eibach, CSL and Dinan are better choices. But they're decent. Wish the fronts were stiffer rate.
Old Sat, Jun-24-2017, 05:36:23 AM   #20
zaharias
Greece
Thanks guys!
I agree with TboneM3.
Why you want to change springs?
If you don't want lowering springs keep the oem ones that are the best!
Discussing Suspension - Koni Yellow (what springs & settings?) E46 M3 in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
