Old Tue, Jun-20-2017, 06:27:02 AM   #1
zaharias
Greece
Default Suspension - Koni Yellow (what springs & settings?) E46 M3
Hi guys!
My M3 E46 coupe currently has AC Schnitzer shocks & springs (unknown millage) and ground control street camber plates.
Its not a DD (street use only) but i want a comfort set up with a slight lowered look compared to stock and like oem handling.
Also installed a front sway bar (H&R) and I want to try some CSL bushings to see if things soften up a bit or else I will put the stock arb back.
Car is on staggered oem 18s and Apex square 9.5 255/40/18.
I ordered a set of Koni Yellows and expecting to have them in July.
Should I keep my ACS springs or get a new Eibach set?
I will also keep the camber plates.
I was reading some old threads and I read that with oem springs they set them at full soft where others say that koni doesn’t recommend setting them at full soft.
Any info on the settings?
Jump to top zaharias is offline   Reply With Quote
Old Tue, Jun-20-2017, 01:48:03 PM   #2
VinceSE2
FKA VinceSE
Sweden
Originally Posted by zaharias View Post
Hi guys!
Are you replacing the ACS shocks because you find them (and/or the springs) to firm?
Or are the shocks worn out?
And are you happy with the ASC ride height or not?
Old Tue, Jun-20-2017, 03:08:10 PM   #3
Default Re: Suspension - Koni Yellow (what springs & settings?) E46 M3
Maybe you can find out who made the springs for ACS? Could be H&R, for example. You might be able to figure out srping rates from there.
Eibachs are the best aftermarket spring maker, imo, so you couldnt go wrong getting a set to match with new Konis, then run the konis full soft, tightening them a quarter turn every 5k-10k as they age. My suggestion.
/// 2004 SilberGrau M3 · Coupe · 6MT · slicktop · manual seats · no nav____________________JOURNAL
Evolve-R Alpha N · Evolve CSL CF Airbox · Eventuri Scoop · Supersprint V1 stepped · SS V1 S pipe + 200 cell HFC · OE sect 2 · SS Sport · BMW Motorsport 4.10 · Besian · RE pullies/fan delete · WPC rod bearings · TMS Camber & Subf plates · RE Trans Mounts · AKG poly SUB/DIFF · SDW RTAB · ZHP knob + UUC DSSR · GroundControl S/A (Koni/Eibach 440/550) + tall RSMs · OE CSL trunk · APEX 75mm Studs · Sportline 8S 18"x8.5/9.5" · MPSS 245/275 · ss brake/clutch lines · Pioneer DEH-80PRS · Eclipse PA5422 · CDT HD-6 + WS-100i · CDT EX-530 · 8" Kicker
DD/Beater: 1999 Civic LX - Kenwood x998 · PPI 1600.4 · CDT HD-6 + HD-100 · CDT EX-530 · Clarion 10"
Old Tue, Jun-20-2017, 03:09:28 PM   #4
zaharias
Greece
Bought the ACS suspension from a friend 1.5 year now (unknown millage). It is comfier than B6s & oem springs that came with the car when i bought it + a slight lowering. Body roll was more with the ACS. (thats why i installed a front H&R arb)
I would like to do a suspension refresh because the shocks are worn out.
Wife is pregnant and she sometimes uses the car also.
Iam currently happy with the height (even though i might move to a new house and the pro kit might be better cause it might be a tad higher).
I dont know the rates of the Schnitzer springs mate and how they will work with the Konis.
Old Tue, Jun-20-2017, 03:51:38 PM   #5
VinceSE2
FKA VinceSE
Sweden
Then I'd keep the ACS springs and set the Koni's at somewhere between 1/2 and 1 turn at least.
As your adjusting rebound it gets more composed, within reason of course, moving away from full soft. Otherwise you'll probably find in bouncy.
Old Tue, Jun-20-2017, 06:29:10 PM   #6
zaharias
Greece
The problem is that you have to remove them to change settings.
Can the fronts be adjusted on the car when you have GC street camber plates?
Old Tue, Jun-20-2017, 06:59:53 PM   #7
VinceSE2
FKA VinceSE
Sweden
Yes, the fronts can be adjusted on the car even with those plates.
The standard rears will, as you said, need to come off. But thats not a big deal if you leave the trunk lining loose.
I had the top adjustable tear Koni's. That's certainly easier.
Old Tue, Jun-20-2017, 09:35:53 PM   #8
zaharias
Greece
It definitely is the top adjustable!! Couldn't get them to Greece unfortunately!!
Old Tue, Jun-20-2017, 11:19:13 PM   #9
M3 dude
i had 1/2 turn from soft in the rear, and 1/4 turn from soft in front.
you can then tweak the front to suit your driving style, while the rear is a pain to adjust.
i had eibach springs too
Old Wed, Jun-21-2017, 03:44:51 AM   #10
EricSMG
40 something
Rears aren't bad - don't even need to remove the wheels. Pop the limbers back, raise the rear up just a bit and pop them out. 30 min job.
Discussing Suspension - Koni Yellow (what springs & settings?) E46 M3 in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
