Old Fri, Jul-21-2017, 04:46:11 AM   #531
bigjae1976
Originally Posted by lrz14 View Post
Hey guys just seeing if anyone can help, I put in the manual transmission connected everything. Just one problem when I press the clutch pedal it feels soft, like if clutch isnt engaging. Dont know if I installed the clutch backwards, if its the clutch fork or if theres air in the system. I bleed most of the air by pressing in slave cylinder, but i have never bleed a clutch before. Any suggestions are greatly appreciated.
It's air. It takes a lot of bleeding to get the air out.
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola Red
Old Fri, Jul-21-2017, 01:38:19 PM   #532
Being3
Being3's Avatar
Reputation: 0 Being3 is on a distinguished road
Default Comprehensive SMG to 6MT Conversion Thread
Need to open the bleed valve on the under car and make sure the break fluid is topped up. Then have some one press clutch peddle and hold it down then by had tighten the bleed valve. Then they pump the peddle and hold to floor and u loosen bleed valve till air is out and oil squirts out. Do this till all air is out and clutch peddle is firm. May take several times or more. I just did mine and had same issue but I hadn't backed-out bleed screw far enough
Jump to top Being3 is offline   Reply With Quote
Old Fri, Jul-21-2017, 08:28:08 PM   #533
rfranzen
Reputation: 0 rfranzen is on a distinguished road
Hi guys, any of you have done this conversion using the same bell housing? If yes, could you show us on pictures of the procedure including the machining of the holes? I would appreciated, in the moment im down in south o brazil and we are installing a E46 M3 drivetrain in a 130 E87, and converting its SMG to manual, down here there is no bell housing from a manual trans to buy.
Thank you!
Jump to top rfranzen is offline   Reply With Quote
Old Sat, Jul-29-2017, 04:00:51 AM   #534
lrz14
Reputation: 0 lrz14 is on a distinguished road
Thanks for the help brotha, I was freaking out that the clutch fork wasnt working. But followed your steps and bam worked great. Thanks again!
Jump to top lrz14 is offline   Reply With Quote
Old Tue, Aug-01-2017, 11:24:40 PM   #535
lrz14
Talking Re: Comprehensive SMG to 6MT Conversion Thread
Hi guys so I'm back to square one with the car I finished it all drove it home the next day it was fine drove it again. The second day went to start it and nothing. When I first started the car dsc and abs turned than went away. Than I saw the battery light turn in, thinking it was the alternator I pulled it out than had it tested. Still won't crank or nothing can hear the fuel pump prime so it's not that. I'm thinking maybe the clutch switch but have no idea I'm lost. About to read the codes hoping something pops up, any help with this is greatly appreciated!
Old Wed, Aug-02-2017, 01:37:58 AM   #536
ThunderMoose
If you have access to INPA you can test to see if clutch switch is engaged. It's typically something simple. Make sure wire didn't pop out of clutch switch or EWS.
#67 2017 NASA TX TT3 Champion
Old Wed, Aug-02-2017, 12:39:21 PM   #537
lrz14
Yea I'll double check the wiring, I thought maybe the dme went into safe mode, and needed to do the coding. My inpa isn't working so I have to reorder the program. How do you test to see if the clutch switch is engaged? I also never tapped into the manual trans gear position switch if that has anything to with it. Thanks for your help so far.
Old Wed, Aug-02-2017, 01:50:31 PM   #538
ThunderMoose
The only thing needed honestly is power to the EWS pin
Old Fri, Aug-11-2017, 01:45:20 AM   #539
sdeezym3
Reputation: 0 sdeezym3 is on a distinguished road
Can I connect pin 3 (12v) to the EWS pin 8 to disable the clutch switch?
I believe this is whats stated above?
Jump to top sdeezym3 is offline   Reply With Quote
Old Fri, Aug-11-2017, 01:49:29 AM   #540
sdeezym3
Also I am using my SMG transmission converted. Which of the 3 remaining connectors need to be connected? I currently have all three on the smg box connected, but I believe not all are supposed to be connected once its recoded....?
