Old Wed, Dec-21-2011, 10:09:04 PM   #21
Tp///M3
Got ///M?
Tp///M3's Avatar
Reputation: 0 Tp///M3 will become famous soon enough
Laos
Default Re: Insight into BMW's (Magna Donnelly) Failed Rear View Mirrors
I will be sending mine shortly. Thanks for great info!
04 CarbonBlack/ImolaRed
Jump to top Tp///M3 is offline   Reply With Quote
Old Wed, Dec-21-2011, 10:11:48 PM   #22
///MATTY C
///MATTY C's Avatar
Reputation: 0 ///MATTY C is on a distinguished road
Originally Posted by RaceMX-M3 View Post
Radar-Mirror.com is a proud new sponsor of the M3 Forum.
If you own a E46 M3 and haven't experienced a rear view mirror failure chances are good that you will down the road. I've owned a E46 M3 since 2004 and my mirror failed twice - I've been working on these mirrors for 5 years now and thought I'd share some info about how the mirrors work, why the Magna mirrors fail and why we hope you will choose us if your mirror needs to be repaired.
The first version of an auto dimming mirror was actually a prismatic mirror (the tilt mirror everyone had before auto dimming) - there was a light sensor on the mirror and a small motor inside the mirror that automatically tilted the mirror up and down. The mirrors were only available on very expensive cars for the time and became obsolete when the electrochromic auto dimming mirrors were developed. BMW was among some of the first car manufacturers to offer the mirrors on their cars.
There are two companies that produce all of the auto dimming mirrors for 90% of the car manufactures around the world. Magna Donnelly is one and if you're not familiar Gentex is the other. The companies actually originated from the same family and are both headquartered in Holland, MI. When the electrochromic mirrors were first made available Magna had the lion's share of the business - over time primarily due to the overwhelming number of mirrors that failed Gentex has emerged as the leader and now enjoys (I'm guessing) 80% of the auto dimming mirror business. The mirrors they produce have not had the issues that the Magna mirrors do - BMW jumped ship in 2007 and moved all of their business to Gentex.
What is an electrochromic mirror and how does it work?
An auto dimming mirror is comprised of two pieces of glass that are slightly overlapped on the edges, sealed together and have a transparent conductive gel or fluid injected between the layers of glass. A mirror coating is applied to the rear portion of the glass and when a very low voltage is applied to the overlapped edges of the glass the gel darkens and reduces the amount of light transmitted and eliminates glare.
An electronic circuit board is attached to the rear of the mirror with wire leads soldered to the edges of the glass. There are two photocells (light sensors) - one facing out the front windshield and one facing the rear of the car. If a sufficient amount of light is hitting the forward facing sensor the mirror will conclude that it's daytime and will not dim the glass, regardless of what the rear facing sensor sees. As it starts to get dark outside the forward sensor sees less light - concludes it's nightime and when the rear facing sensors sees any light behind the car the voltage flow is opened and the mirror begins to dim. The level of dimming is determined by the combination of light levels the two sensors are detecting.
How do the mirrors fail?
The failure of the mirrors is due to a manufacturing defect by Magna. The mirrors are sealed along the edges of glass and over time the seal breaks down and eventually fails, allowing the fluid to escape which is replaced by air. The amount of fluid that escapes and whether it begins to leak depends on where the seal breach is located. If the seal fails on the bottom of the mirror the fluid is going to escape a lot more quickly than if it's on the top. In most cases it takes a few years for the seal to fail - the environment that the car is in can have an impact on how long the mirrors last. Heat is known to accelerate the process so if you live in a hot climate and park your car outside in the sun for extended periods your mirror is going to fail sooner. From the pictures below you can clearly see where the seal failed on this mirror - with a small amount of pressure the two pieces of glass completely separate.
Why have so many of the mirrors manufactured by Magna failed over an extended period of time? Why wouldn't they have resolved this a long time ago?
This is the million dollar question. We repair 5 - 10 of these mirrors every day and the mirrors range from Jaguars built in the mid to late 90's all the way to Lamborghinis built as recently as 2008. I know Magna has struggled with this issue over an extended period of time and continues to make changes to their manufacturing process. They may have the issue resolved at this point but only time will tell.
What about the mirror repairs from Radar-Mirror.com? How reliable are your replacement mirrors?
We have repaired about 2000 mirrors at this point, many of them for members of the M3 Forum and we have yet to see one of our mirrors fail due to a seal breach. The only failures that have been reported to us were due to the glass cracking and there have only been 3 or 4 of these. We're an authorized dealer for Mito Corp (distributor for Gentex) and our repairs include a lifetime warranty.
Sybesmas has repaired many mirrors for M3 owners and gets great reviews, why should someone choose Radar-Mirror.com for thier mirror repair?
Hopefully the fact that I am a hard core BMW enthusiast, own an M3 and now sponsor the forum wins us some favor. Mirrors that are shipped to us will be repaired, tested and shipped within one business day and guaranteed to look and work like new. The one thing that really separates us from Sybesmas is our warranty - thiers is 90 days - if anyone experiences an issue with a mirror we have repaired we will fix it for free for as long as you own your car. Our mirror repair is normally $104 with shipping in the US, for M3 Forum members we're going to match the price Sybesmas offers @ $95 shipped in the US and $135 shipped out of the country. Please mention that you are an M3 Forum member when you contact us.
We appreciate the business and kind comments we've received from this forum and look forward to serving others as the need arises.
I'll be contacting you soon! Great price.
Jump to top ///MATTY C is offline   Reply With Quote
Old Wed, Dec-21-2011, 10:15:55 PM   #23
Project E46M3
Go big or go home...
Project E46M3's Avatar
Reputation: 0 Project E46M3 is on a distinguished road
I'm submitting my info on your contact page right now. I have an 02/01 m3 and my mirror has a huge blob it in...its rather disturbing to look into lol
I need to figure out how to remove the mirror so I can send it in.
2013 E92 M3 ZCP | AW | FR | DCT
Jump to top Project E46M3 is offline   Reply With Quote
Old Wed, Dec-21-2011, 11:38:14 PM   #24
RaceMX-M3
Scott@Radar-Mirror.com
RaceMX-M3's Avatar
Reputation: 0 RaceMX-M3 is a jewel in the rough
I'll get an email out to you in a couple of mins. If anyone needs instructions for removing their mirror we have it posted here http://www.radar-mirror.com/BMW_Mirror_Removal.html
Jump to top RaceMX-M3 is offline   Reply With Quote
Old Thu, Dec-22-2011, 12:00:45 AM   #25
BrokenM3
BrokenM3's Avatar
Reputation: 0 BrokenM3 has much to be proud ofBrokenM3 has much to be proud of
Croatia
Congrats on becoming a sponsor.
You fixed my mirror couple of months ago, and i have nothing but good things to say about the way you handled the business, from picking up the phone, answering emails, and the very quick turnaround
Jump to top BrokenM3 is offline   Reply With Quote
Old Thu, Dec-22-2011, 01:29:40 AM   #26
roarf
Jimmies: Not Rustled
roarf's Avatar
Reputation: 0 roarf is on a distinguished road
Check the fuse that powers the mirror - if the fuse is good and the mirror doesn't dim there's something wrong. Just send it in and we'll sort it out. I can add the alarm led to the mirror if I have a lens available, they tend to fall off the mirrors and get lost easily so they're hard to keep around. I can't guarantee the light will blink if the car wasn't set up for that from the factory. My car has the clown nose SOS mirror and my light doesn't blink but I don't have the alarm installed. The light blinked when I first got my car but a ecu update made it so it wouldn't blink anymore.
Thanks for the response. I will check the fuse. I am quite certain my car has the OEM alarm but I believe it may have been installed at the dealership when the first owner bought the car.
'02 M5 - Carbon Black/Silverstone
'01 M3 - Imola Red/Black
Jump to top roarf is offline   Reply With Quote
Old Fri, Dec-23-2011, 09:05:22 AM   #27
nis350
nis350's Avatar
Reputation: 0 nis350 is on a distinguished road
Sybesmas gets their mirrors from Magna - we've had a few sent in to us but I don't know how long ago the repairs were done.
What do you use for the replacement mirror for the M3 (Magna or Gentex)?
Jump to top nis350 is offline   Reply With Quote
Old Fri, Dec-23-2011, 01:56:39 PM   #28
KrisM3
Posts Per Day: 0.12
KrisM3's Avatar
Reputation: 0 KrisM3 is on a distinguished road
Had mine repaired by radar mirror and it's perfect like new! Congrats on being a sponsor!
Jump to top KrisM3 is offline   Reply With Quote
Old Fri, Dec-23-2011, 03:18:50 PM   #29
kkamakasi
울산박
kkamakasi's Avatar
Reputation: 0 kkamakasi is on a distinguished road
South Korea
i got mine repaired by Magna Donelly a while back. One thing I noticed was the stock mirror that came from the factory dimmed with a black tint. The new repaired/replaced mirror dims with a dark green hue.. just a fyi
Jump to top kkamakasi is offline   Reply With Quote
Old Fri, Dec-23-2011, 03:34:44 PM   #30
hyperboost
Imola Red M
hyperboost's Avatar
Reputation: 0 hyperboost is on a distinguished road
great info!
OEM+ E46 M3 IR/Black Cloth - light factory freak
ESS VT440|SS V1|Volk TE37|AS SSK|TCK S/A|Vorshalg Camber Plates|Brembo 8piston 380mm front 4piston 345mm rear|EAS AEs|PF RTAB|RE Tranny Mounts|RE FCAB & RSM|UUC front sway
E46 M3 TiAg/IR modded - sold
E92 M3 Melbourne Red 18" Volk TE37SL - Transported to China
E93 M3 AW/Black - sold
E39 540iA modded -sold
B6 A4 modded back to stock - totaled
W126 560SEC - Wintermobile - Totaled 4/14/2010
07 Bentley Continental GT Mulliner Package
87 Porsche 944 NA 5speed black OEM Boxster Wheels - Totaled due to a rock
E92 M3 Stage II+ Dinan 4.10s.....
2011 Mustang GT Procharged... fooking fast
2013 Mini Cooper
13 F10 535 Msport Xdrive some mods Sold
15 F80 YMB M3 DCT DD
Jump to top hyperboost is offline   Reply With Quote
Discussing Insight into BMW's (Magna Donnelly) Failed Rear View Mirrors in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
