Old Wed, Aug-09-2017, 11:47:21 PM   #11
cmstrilchuk
Reputation: 0 cmstrilchuk is on a distinguished road
Default Re: 2006 model year subframes
My 06 had subframe cracks at 60K miles. There's no hiding from the issue in my opinion.
I'm now reinforced by Redish
06 ///M3 ZCP SMG FStreet
Jump to top cmstrilchuk is offline   Reply With Quote
Old Thu, Aug-10-2017, 01:36:44 AM   #12
MVAM3
Reputation: 0 MVAM3 is on a distinguished road
No matter the year, every owner should keep reinforcement in mind. Not that bad to fix and even better to do a preventative reinforcement. Most cars, unless they are garage queens, will likely need diff and subframe bushing replacement now anyway.
Jump to top MVAM3 is offline   Reply With Quote
Old Thu, Aug-10-2017, 02:26:57 PM   #13
binary
Reputation: 0 binary is on a distinguished road
Just bought an 06 and this thread title got me excited for a moment, spreading hope to my heart but I knew better after reading all the SF threads. I just hit 100k and will be doing the Redish plates this month.
Do you have a plan to look for secondary failure of the RACP separating? Did your shop also do extra seam welding while doing the plates?
My loose plan is to do the plates/bushings now then do a Vince type bar if/when the RACP starts to go. I just don't know if it will be too late by then. Or should I bit the bullet and do them both at the same time? it's probably another $1000 minimum on top of the $2000 i'm already shelling out. That 1000 can go towards the Vanos or bearings that I also need to prevent from failing.
Jump to top binary is offline   Reply With Quote
Old Fri, Aug-11-2017, 04:12:47 AM   #14
cmstrilchuk
I like the Vince bar very much. I feel it addresses the fundamental weaknesses. It would make sense to install it if dropping the subframe for plates (assuming cracks are present). Unfortunately for me, it came along just after I did the plates. So I'm in the wait and see if plates are enough category. And I have not heard of any plated RACP failures, so I am optimistic. No seam cracks were observed when the plates went in, so no welding done.
Old Sat, Aug-12-2017, 09:27:48 PM   #15
TheDoogan
Forward Loaded
TheDoogan's Avatar
Reputation: 0 TheDoogan is on a distinguished road
Verts need the reinforcement just as much as Coupes, yeah?
2006 E46 M3, 6MT, Convertible, Black/Black - 72k miles
Active Autowerke Catless Headers, Section 1 High-flow cats & Section 3, Evolve CSL Intake w/Alpha-N tune. Schrick CSL Cam - 60k mile Service II.
Jump to top TheDoogan is offline   Reply With Quote
Old Sun, Aug-13-2017, 04:50:17 AM   #16
///ALpineVert
Reputation: 0 ///ALpineVert is on a distinguished road
So they say. There are threads out there that give detail on it, bottom line is that verts need it too.
Jump to top ///ALpineVert is offline   Reply With Quote
Old Sun, Aug-13-2017, 05:13:10 AM   #17
youinreverse
Reputation: 0 youinreverse is on a distinguished road
My sedan had the RACP replaced by the dealer (subletted out to one of the best BMW body shops in the state), and I still had to fix a couple cracks and popped spot welds while installing Reddish plates and a Vincebar.
Reinforcement should always be done, no matter the year.
Jump to top youinreverse is offline   Reply With Quote
Old Sun, Aug-13-2017, 12:38:45 PM   #18
TheDoogan
Forward Loaded
TheDoogan's Avatar
What about 2005 sedans that have already had the airbags replaced?
Just kidding
Thanks guys. I still need to do this.
Discussing 2006 model year subframes in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
