Old Sun, Jul-30-2017, 02:24:40 AM   #1
Eric M3
shogun
Eric M3's Avatar
Reputation: 0 Eric M3 is on a distinguished road
Japan
Default when does the torque converter go into lockup?
Just out of interest I would like to know what criteria are standard requirements that the 5HP18 torque converter on a 1998 M3 U.S. spec locks up?
Car is all standard, no different final drive, wheels etc.
Checked the Bentley repair manual, but no info there.
My 7 series DIY site: http://twrite.org/shogunnew/topmenu.html
Jump to top Eric M3 is offline   Reply With Quote
Old Sun, Jul-30-2017, 11:42:34 AM   #2
Eric M3
shogun
Eric M3's Avatar
Japan
Default Re: when does the torque converter go into lockup?
Here is some info for E36 from around page 260, shift points at ...RPM etc, different automatic transmissions and engines, technical data https://web.archive.org/web/20110516...cal%20Data.pdf
better download it, I recovered it with the wayback machine, abt 400 pages in total
Old Mon, Jul-31-2017, 12:11:27 AM   #3
Eric M3
shogun
Eric M3's Avatar
Japan
here are pics, someone made a test drive with a computer https://www.bimmerforums.com/forum/s...go-into-lockup
quote
I drove my car with my laptop and DIS while in Diagnosis Request here is what I saw;
- The converter will lock up in 3rd, 4th and 5th gear.
- The load signal %(not just kick-down) has to be below a certain percentage and engine rpm or it won't lock up.
- I only took 4th & 5th gear photos.
Page 28 talks about the converter, http://www.e38.org/electran1.pdf
Old Fri, Aug-04-2017, 05:36:01 PM   #4
egebhardt
egebhardt's Avatar
Reputation: 0 egebhardt is on a distinguished road
Looks like you answered your own question. I had 2 auto sedans. On both cars, I could go out on a nice stretch of highway and test the lock. Once locked, you can push the gas pedal lightly and the RPMs won't change. Once unlocked, the RPM does change. The torque converter definitely locks and unlocks when working properly.
Sometimes you will get Failure 111.
Fault code 111 indicates a lack of transmission torque converter lockup (i believe). I think it's a common code that comes and goes. Keep the fluid topped off.
I also read this link.
https://blog.bavauto.com/11812/bmw-t...verter-clutch/
Also, it is OK to drain and fill these trannies at any mileage. I proved it with 2 cars at 118,000 and 168,000 miles. Neither car had ever had a tranny drain and fill. I did the job and it shifted fine before and after. Lifetime fill is a bunch of BS. All fluids need to be changed sometime.
Here's how to do it: http://www.m3forum.net/m3forum/showp...0&postcount=61
96 Boston on Grey 2dr - Sold 10.28.17 Benny and Suad
98 TiSilver on Black 4dr - Sold 7.19.17 Jono driving it
97 Byzanz on Magma 4dr - Sold 7.7.17 Jerad in CO
98 Estoril on Grey 4dr - Sold 9.23.13 Garrett driving it
98 Arctic on Grey 4dr - Sold 3.18.13 Brandon driving it
98 Estoril on Grey 2dr - Sold 8.6.12 Thy sold it
99 Estoril on Sand 2dr - Sold 7.31.12 Eric modding it
98 Arctic on Grey 2dr - Sold 3.10.12 Kyle driving it
96 Techno on Black 2dr-Sold 6.13.09 Ross totaled it
Jump to top egebhardt is offline   Reply With Quote
Old Sat, Aug-05-2017, 09:29:54 AM   #5
Eric M3
shogun
Eric M3's Avatar
Japan
Yes, ATF drain, fill and filter change is recommendable, my wrenching buddy is doing that quite often in my garage, as I have a lift+pit. He is doing a special valve body service by cleaning the valve body and checking all the parts, you can see here how much dirt sometimes is in the valve bodies, click on 5HP18 in the index http://e32b12.blogspot.jp/
there are some pics from an Alpina B3 valve body, there you can also see the small steel mesh inside the VB, when you scroll further down you can see the small ball inside the valve body, that is also smaller than original size, we replaced that too.
Old Sat, Aug-05-2017, 07:45:31 PM   #6
M-technik-3
Reputation: 0 M-technik-3 is on a distinguished road
I have one from my 95 M3 and it was fine when pulled if some one wants it here in the North East.
Jump to top M-technik-3 is offline   Reply With Quote
Discussing when does the torque converter go into lockup? in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
