Old Sat, Jul-29-2017, 06:43:21 PM   #1
JitteryJoe
Default Cam tray camshaft bearing
I noticed that one of the camshaft resting points (whatever you call them) is scored. This is the intake cam tray. Running my finger across it, it is definitely rough. I'm installing new cams to a newly machined head. Can I just use a fine grit paper to smooth? I don't want to leave it as it.
Thanks!
Joe
Jump to top JitteryJoe is online now   Reply With Quote
Old Sat, Jul-29-2017, 07:23:53 PM   #2
Default Re: Cam tray camshaft bearing
Fairly common. I use small scotch pad balls for drills to clean mine up. Machine shops will use a fine grit flap wheel.
Old Sat, Jul-29-2017, 07:30:26 PM   #3
JitteryJoe
Thank you. At $450 per tray I was hoping a new tray was not required.
Old Sat, Jul-29-2017, 07:41:49 PM   #4
As long as you knock down any peaks that might score the cam bearing journals, it’s fine. Unremovable valleys don’t fuss over.
Old Mon, Aug-28-2017, 06:21:27 AM   #5
joecamp
Reputation: 0 joecamp is on a distinguished road
Hi there! Thank you guys for detailed answers, because I had the same problem with my car recently. Now it's gone. Thanks once more. Best regards, essaywriter expert.
Jump to top joecamp is offline   Reply With Quote
Discussing Cam tray camshaft bearing in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
