Old Tue, Dec-23-2014, 12:43:01 PM   #1
mastek
M3 Pilot
mastek's Avatar
Reputation: 0 mastek is on a distinguished road
Default Is adding 70 hp possible to NA s54
Let's say you do the following to an OE s54:
- Race Pulleys
- CSL style Alpha-N Airbox
- Catless Headers
- Catless Exhaust
- 100 Octane
- Custom Dyno Tune
And let's say you did those and no engine (head or bottom end) modifications and took the engine out of the car and put it on an engine dyno. Would it read around 400 hp??
Because that is what the rwhp dyno math conversion says for my race car.
And I am having a hard time believing this engine is pushing 400 hp at the crank.
Jump to top mastek is offline   Reply With Quote
Old Tue, Dec-23-2014, 12:59:17 PM   #2
tjkenny15
tjkenny15's Avatar
Default Re: Is adding 70 hp possible to NA s54
I'd imagine its probably darn close. I'm interested in hearing feedback on this as well.
Jump to top tjkenny15 is offline   Reply With Quote
Old Tue, Dec-23-2014, 01:06:43 PM   #3
lunaslide
lunaslide's Avatar
Reputation: 0 lunaslide is on a distinguished road
Short answer: no, you've got to get into the engine to pull that much.
I've done pretty much all the bolt ons that you can do and on 92 octane non-ethanol summer blend, my dyno is 300bhp. The shop said tack on 20% for driveline loss and that's 360. I don't know what 100 octane and a tune adjustment would give.
I've seen a shop online selling purpose built race S54s with 430 at the crank. That is probably around the max you could pull without FI.
lunaslide
2005 M3 ZCP
[Supersprint v2 headers, race cats, resonated section 2 and Sport muffler][Carbonio CF CAI][Evolve Alpha-N][PWR 55mm radiator][4.10 3 Clutch LSD][Bilstein PSS10][TMS front and rear sway bars, camber plates, and rear lower control arms][StopTech ST60 380mm/ST40 355mm][Pagid RS29s][Apex EC-7 Anthracite 18x9.5][Toyo Proxies R888 275/35ZR18]
Jump to top lunaslide is offline   Reply With Quote
Old Tue, Dec-23-2014, 02:01:11 PM   #4
Mr. Wolfe
Anti-Bling
Mr. Wolfe's Avatar
But the question is, what bolt ons did you do - they are not all equal.
From countless forum members dynos (which I know aren't always totally accurate, etc. so I will use a wide range) using the following:
CSL Style Airbox (OEM, Karbonius, Evolve)
SuperSprint SSV1 <-- very important piece
Catless or HJS Section 1
Schrick 280/272 Cams
CSL Map Sensor/Rail
CSL Flash + Dyno Tune
You should be in the 340-370 range to the wheels which puts you over 400hp.
Mr. Wolfe
1994 Porsche 911 Turbo-Look
Old Tue, Dec-23-2014, 02:07:20 PM   #5
HassanEido
HassanEido's Avatar
Lebanon
ppl are getting there all the time. The stock M3 rates at 275, people are dynoing at 350~ after these mods..thats 70 whps more...SO yes is ur answer
Old Tue, Dec-23-2014, 02:53:36 PM   #6
sleeks
sleeks's Avatar
Reputation: 0 sleeks will become famous soon enough
CSL Map Sensor/Rail
Mr. Wolfe
This. 340-370 puts you 50+ HP ahead of stock at the low end of the range, so I think that 70 hp (400HP at crank) is entirely possible. Make the engine breath better and you can get there.
2002 ///M3 - Steel Grey/Black 6MT
Installed: Beisan / APEX / Dinan / PFC / Stoptech / Redish / Bimmerworld / AKG
Jump to top sleeks is offline   Reply With Quote
Old Tue, Dec-23-2014, 03:10:19 PM   #7
bjz
bjz's Avatar
Reputation: 0 bjz is on a distinguished road
Spain
It is, with cams.
Jump to top bjz is offline   Reply With Quote
Old Tue, Dec-23-2014, 03:11:19 PM   #8
m3 hal
- Race Pulleys
- Catless Headers
- Catless Exhaust
- 100 Octane
- Custom Dyno Tune
If the headers are SS V1, and the tuner is competent, I think that's possible. Especially on 100 octane.
Old Tue, Dec-23-2014, 03:19:13 PM   #9
m3 hal
An easier way to determine is with a vbox or at the drag strip. If you could hit a trap speed of ~114 mph that would equal ~400 hp in this car.
Old Tue, Dec-23-2014, 03:27:55 PM   #10
Cha5en
Reputation: 0 Cha5en is on a distinguished road
I think you all are missing the 100 octane part. You'd be very surprised what a difference in tuning and power 100 octane (US grade) will pull..
Jump to top Cha5en is offline   Reply With Quote
Discussing Is adding 70 hp possible to NA s54 in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
