Old Wed, Aug-17-2016, 01:46:12 PM   #261
HassanEido
HassanEido's Avatar
Lebanon
Default Re: Review 996 Porsche 911 Brembo Brakes Installed!
Originally Posted by Taron View Post
Is it possible to make this kit work with the e92 front rotors (360x30) or is ZCP the biggest you can run?
I believe you need 18z Brembos(Porsche Cayenne S) for those. The Boxster S still a better option, as the 18z require some milling of the calipers, p0lar says turn key, i'd wait to see Hopefully not too long tho, as my disks are cracked and I neeeeeed new ones pronto
Old Wed, Aug-17-2016, 03:57:17 PM   #262
UdubBadger
UdubBadger's Avatar
Reputation: 0 UdubBadger is on a distinguished road
Originally Posted by p0lar View Post
I'm working on a different caliper that will be turn-key with the E92 front rotors. They absolutely require modification to the front shield to even mount, however.
I'm absurdly busy with domestic home renovations, so there's no time frame on delivery quite yet.
Good to hear!
GoingHAM mobile
2004 E46 ///M3 IR/IR 3 pedals - RETIRED 01/16
Jump to top UdubBadger is offline   Reply With Quote
Old Wed, Aug-17-2016, 04:27:53 PM   #263
p0lar
Naturally Agitated
p0lar's Avatar
Reputation: 0 p0lar will become famous soon enough
Calipers that require milling are a serious pain even when it's only a simple milling of the bosses. I've been there -- over, and over, and over again.
Almost every fixed-caliper augmentation to the E46 M3 requires trimming of the dust shield, so that's not a huge ordeal with a cut-off wheel or snips, but actual caliper mods drag down the project quickly. Turn-key is the way to go, but then it requires finding a caliper with pads that match the rotor pad widths, rotor thickness allocation within the caliper body, piston size bias matches, OEM mounting boss offset compatibility, etc. I could go on at length about the various challenges, but it sums to a single word: difficult.
Jump to top p0lar is offline   Reply With Quote
Old Wed, Aug-17-2016, 04:39:34 PM   #264
nasieg
nasieg's Avatar
I understand that not everybody has access to a mill, however, it seems to me that milling off 1.5mm of those front pads on the 996 calipers, is a lot less work than all that stuff you just described.
If anybody needs pads milled off on their 996's calipers let me know. I can do it for $40 plus shipping.
My Journal
Besian VANOS, Euro Headers & Section1, TTFS tune, TMS under-dive pulleys, TC Kline S/A Coil Overs, Brembo 996 Calipers, ECS 2 Piece Rotors, Sportline CS8's, SG CSL Diffuser, OEM CSL Trunk
Jump to top nasieg is offline   Reply With Quote
Old Wed, Aug-17-2016, 06:10:24 PM   #265
silvergray545
silvergray545's Avatar
Reputation: 0 silvergray545 is on a distinguished road
Are you saying the Boxster S and 996 front pads aren't the same even though the calipers are?
2004 BMW M3 6MT - TiAg/Gray
2016 BMW M3 ZCP 6MT - AW/SO
2000 BMW M Roadster 5MT - TiAg/Black
2014 VW GLI 6MT - Black/Black
E46 M3 Build Journal
Jump to top silvergray545 is online now   Reply With Quote
Old Wed, Aug-17-2016, 06:38:20 PM   #266
SeanE46
SeanE46's Avatar
Reputation: 0 SeanE46 is on a distinguished road
Armenia
One question. What components are the most expensive?
2001 M3 6MT TiAg Coupe SOLD
2002 M3 6MT TiAg Coupe SOLD
2004 M3 SMG Silver Grey CURRENT
Jump to top SeanE46 is offline   Reply With Quote
Old Wed, Aug-17-2016, 08:24:33 PM   #267
p0lar
Naturally Agitated
p0lar's Avatar
He was probably referring to the mounting bosses on the calipers.
Old Wed, Aug-17-2016, 08:25:18 PM   #268
p0lar
Naturally Agitated
p0lar's Avatar
It's a tossup between the calipers and associated repairs/refinishing and new OEM rotors.
Old Wed, Aug-17-2016, 08:26:32 PM   #269
Pirelli Condoms
Pirelli Condoms's Avatar
Reputation: 0 Pirelli Condoms is on a distinguished road
Best place to find calipers car-part.com?
“On a given day, a given circumstance, you think you have a limit. And you then go for this limit and you touch this limit, and you think, 'Okay, this is the limit'. And so you touch this limit, something happens and you suddenly can go a little bit further. With your mind power, your determination, your instinct, and the experience as well, you can fly very high.”
― Ayrton Senna
2002 E46 M3 CB/Cinn. 102k 6MT
AST 4200 Coilovers | Square 67's with 275 NT01's | Swaybarian front bar | Poly errthing | Powerflex lca | Gtfour cage | Rogue front strut bar | Recaro SPG w/ black vinyl cover | Z3 shifter | Gloc R12/10 | Macht schnell elbow/filter | Mishimoto efan |
Jump to top Pirelli Condoms is offline   Reply With Quote
Old Wed, Aug-17-2016, 09:02:26 PM   #270
nasieg
nasieg's Avatar
Yes, that is correct. Pads was not a good word to use for to describe the mounting surfaces on the calipers. My bad.
My Journal
Discussing Review 996 Porsche 911 Brembo Brakes Installed! in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
