Old Tue, Feb-10-2015, 05:31:35 AM   #141
bemami
bemami's Avatar
Reputation: 0 bemami is on a distinguished road
Default Re: Review 996 Porsche 911 Brembo Brakes Installed!
This thread is amazing. Big thanks to polar and Dave for continuing to innovate and coming up with creative ideas.
2006 M3 Vert AW/Imola 50K miles
2012 640i White with sport package
2011 550 White with sport package
06 M3 Vert AW/Imola 26K miles - sold
06 M3 Vert AW/Cinnamon 33K miles - sold
Jump to top bemami is offline   Reply With Quote
Old Tue, Feb-10-2015, 09:00:58 PM   #142
dafoe
dafoe's Avatar
Reputation: 0 dafoe is on a distinguished road
This is one caliper from the "CSL" kit... Six piston's up front, four in the rear... Cut and brackets for the OEM CSL size rotor!
2001 M3, LSB 6spd, purchased 6/09 with 25K miles.
Mods: Coyne Performance built ///M3, Carrillo, Mahle pistons ARP, Schrick 280/288, TTFS, CSL Airbox, CSL ECU, CSL MAP, CSL air rail, SuperSprint stepped, Larini exhaust, 3.91 gears, Pulleys, TCKline S/A coilovers, PowerFlex RTAB's, AKG Subframe, FCAB, Differential, Apex ARC-8's, Turner subframe reinforcement, Michelin PSS, Laser Interceptor, Coby Alcantara wheel, Beisan Vanos Fixes, Brembo BBK
Jump to top dafoe is offline   Reply With Quote
Old Tue, Feb-10-2015, 10:08:44 PM   #143
Wolf ///M3
Wolf ///M3's Avatar
Reputation: 0 Wolf ///M3 is on a distinguished road
Go on...
Jump to top Wolf ///M3 is online now   Reply With Quote
Old Wed, Feb-11-2015, 02:36:55 AM   #144
CoreyHendo
CoreyHendo's Avatar
Reputation: 0 CoreyHendo is on a distinguished road
So is the 6-piston Cayenne caliper you're using the 17Z (330mm crotor) or 18Z (350mm rotor) caliper? I'd assume the 18z based on your rotor diameter, but some of The VW and audi guys that have been using these calipers forever on their cars have mixed and matched them with various off the shelf rotors (MB and Volvo come to mind). The VW Touareg also uses the same calipers. The 6 Pistons can be sourced for a few hundred dollars per set.
Edit: I forgot that the Audi Q7 also comes with either 17z or 18z calipers (don't recall which).
Jump to top CoreyHendo is offline   Reply With Quote
Old Wed, Feb-11-2015, 03:08:07 AM   #145
p0lar
Naturally Agitated
p0lar's Avatar
Reputation: 0 p0lar will become famous soon enough
Those were originally 18Z calipers, but were converted from axial mount to radial mount using a CNC. When using a 345mm CSL rotor, the 17Z pads are required to mate to the rotor surface properly, which will sweep the entire surface area perfectly.
The 17Z could be made to fit, but the front bias would have been way, way way too high due to the piston sizes in the 17Z (34/36/38mm) compared to the 18Z (30/34/38mm).
Jump to top p0lar is offline   Reply With Quote
Old Wed, Feb-11-2015, 03:41:19 AM   #146
WyattH
Polar, is this something you would be able to do for an E9x M? They have nice rotors worth keeping, as are being used here, but can benefit from a caliper upgrade like this. Wondering if there is any scaling from this project (maybe just a unique caliper bracket?) or if it would require a complete re-engineer.
Old Wed, Feb-11-2015, 03:46:20 AM   #147
p0lar
Naturally Agitated
p0lar's Avatar
Originally Posted by WyattH View Post
Polar, is this something you would be able to do for an E9x M? They have nice rotors worth keeping but can benefit from a caliper upgrade like this. Wondering if there is any scaling from this project or if it would require a complete re-engineer.
I could absolutely do this for an E9x, I would just need one for a little while to develop and test on. I eat my own dog food, so to speak, so I'd want to have an E92 I could push around a bit to know the kit works well. Essentially, it would likely consist of the same kit that's on my E46 M3 with the E92 front/rear rotors, 996 GT3 rear calipers and modified 18Z front calipers.
Old Wed, Feb-11-2015, 03:55:23 AM   #148
WyattH
Awesome! Now to figure out how to get you some seat and tooling time around an E9x..
Are the 18Z Cayenne Turbo 6 piston calipers pretty much the way to go now? I realize the caliper selection has been an evolution.
Old Wed, Feb-11-2015, 04:07:40 AM   #149
p0lar
Naturally Agitated
p0lar's Avatar
IMHO, not really. The problem is that they require a very precise CNC operation that is irreversible. Sure, I love the dynamics, good pad selection, HUGE pads that dissipate tons of heat, and bolt-through-bridge design that makes pad changes a cinch, but getting them to that point isn't a simple process unfortunately.
Old Wed, Feb-11-2015, 04:13:51 AM   #150
WyattH
Interesting. What is the next best setup, all things considered? Boxster S/996 still?
Discussing Review 996 Porsche 911 Brembo Brakes Installed! in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
