Old Wed, Dec-30-2009, 12:07:40 AM   #11
Hankdoll
Hankdoll's Avatar
Reputation: 0 Hankdoll is on a distinguished road
Wow, those numbers are high. When was the last time you cleaned the MAF? Not sure how the dinan intake is set up, but the oil from my ECIS gets it filthly. Could be a reason for the high HCs.
Jump to top Hankdoll is offline   Reply With Quote
Old Wed, Dec-30-2009, 12:09:02 AM   #12
MellowYellow M3
Reputation: 0 MellowYellow M3 is on a distinguished road
OK so when I checked the coils, I simple ran the car idle and would check if there was a difference in idle. Each coil was unplugged and a noticeable change in the sound of the motor was observed through each coil. I assume that they are functioning correctly.
Next I ran the r5 scantool. It reads:
FF18 Ignition coil #6
FF19 Ignition coil #5
FF32 Ignition coil #1
FF33 Ignition coil #3
Is there something else I can check for with this coils to see what is exactly failing? Would this be the cause of the numbers I am getting for smog?
Jump to top MellowYellow M3 is offline   Reply With Quote
Old Wed, Dec-30-2009, 12:20:21 AM   #13
Porschetech
Cocky Brit
Porschetech's Avatar
Reputation: 125 Porschetech is a name known to allPorschetech is a name known to all
England
i'd check your actual values of teh O2 sensors and make sure they iz working correctly. also check for airleaks as your HC's & NO are really high! this would fool teh MAF sensor and dump in more fuel as it thinks its running weak. another basic test would be to hook up a vacuum gauge and see what manifold vacuum is doing. other than that a shop would be your best bet as they have teh equipment to diag your problems correctly
I love all gingers 'n Plambers
Jump to top Porschetech is offline   Reply With Quote
Old Thu, Jan-14-2010, 11:52:57 PM   #14
BMWGuy206
Reputation: 0 BMWGuy206 is on a distinguished road
With NO(NOx) that high it's going to be the cats especially with your mileage. I have a 1995 M3 and that cat had to be replaced at 100,000 miles because of high NOx levels just like yours.
Jump to top BMWGuy206 is offline   Reply With Quote
Old Sat, Jan-16-2010, 02:47:23 AM   #15
M3_Cliff
M3_Cliff's Avatar
Reputation: 0 M3_Cliff is on a distinguished road
Op, once you get the errors cleared up and no cels, drive up to mission viejo and let USA Smog test it.
The tech there is knowledgeable and understands these cars.
If it can pass, it will.
Or you'll have good numbers to determine the best course of action.
Plus the retest cost is minimal.
No I'm not affiliated with them just another e36 M3 owner living in an enhanced area in California.
USA Smog
25721 Obrero Dr. Unit D
Mission Viejo
949-380-7635
Jump to top M3_Cliff is offline   Reply With Quote
failing, smog
Discussing M3 failing Smog in CA Help!! in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
