Old Thu, Dec-06-2018, 01:04:36 PM   #1
midnighted
Reputation: 0 midnighted is on a distinguished road
Default Broken belt tensioner
Had my main belt tensioner fail on me the other day. Anyone see one fail like this before?
Jump to top midnighted is offline   Reply With Quote
Old Thu, Dec-06-2018, 02:17:30 PM   #2
bigjae1976
That’s odd but I could see that happening if the hydraulic arm or roller bearings are seized up.
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola Red
Old Thu, Dec-06-2018, 03:43:33 PM   #3
Texaz3
Default Re: Broken belt tensioner
Probably defective. Unlikely to crack like that under normal use.
Old Thu, Dec-06-2018, 07:34:21 PM   #4
BTB
BTB's Avatar
My mechanical (ac belt..?) tensioner failed similarly, the cast casing just broke apart. Got the part at an advance auto so I think it’s just low quality manufacturing
My Journal
Old Thu, Dec-06-2018, 08:06:40 PM   #5
Interesting.
OP: is that part original or aftermarket?
Old Wed, Dec-26-2018, 04:47:44 PM   #6
midnighted
Sorry for the delay. Checked it out the other day before tossing it. It was INA branded.
Old Wed, Dec-26-2018, 06:23:59 PM   #7
That's oe, probably a flaw in the casting.
/// 2004 SilberGrau M3 · Coupe · 6MT · slicktop · manual seats · zero options · ~3200lbs · JOURNAL
_
Evolve-R Alpha N · Evolve CSL CF Airbox · Eventuri Scoop · Supersprint V1 stepped 2.5" · SS V1 S pipes 2.5" + 200 cell HFC · OE sect 2 · SCZA 2.5" sect 3 · Besian · RE pullies · WPC'd OE bearings · oil catch can · fan/SAP/washer delete · CSL battery
GroundControl S/A Koni (Hyperco/Eibach 300/550) + tall RSMs · Hotchkis front sway (med) · rear strut bar · TMS camber & subframe plates · SPC alum rear camber arms · RE trans mounts · AKG poly subf/diff 95a · SDW RTAB · weighted ///M knob + ZHP alcantara boot + UUC DSSR + delrin bushing · Mason clutch pedal + brass bushing · TMS black pedals · delrin brake pedal bushing
OE CSL trunk · Sportline 8S 18"x8.5/9.5" · MPSS 245/275 · APEX 75mm Studs · 12mm/10mm F/R spacers · Brembo 996 4 pot 36/40 345mm CSL & 28/30 328mm CSL · ZHP "712" rack · Pioneer/CDT/Eclipse/Kicker
Old Wed, Dec-26-2018, 06:47:53 PM   #8
It's been known to happen on occasion. The INA replacement kit is pretty cheap
https://www.fcpeuro.com/products/bmw...1287838797-1-2
Old Sun, Dec-30-2018, 12:40:40 AM   #9
///mtree
Reputation: 0 ///mtree is on a distinguished road
I had this happen to me a couple of years ago as well. Base plate snapped and also took one of the mounting bolts with it, I had to get the broken piece tapped out from the hole it was bolted in to.
It was also an INA tensioner, someone mentioned that it probably seized and rattled until failure.
Jump to top ///mtree is offline   Reply With Quote
Discussing Broken belt tensioner in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
