Old Mon, Dec-03-2018, 02:37:40 PM   #1
Exclusivs
Exclusivs's Avatar
Reputation: 0 Exclusivs is on a distinguished road
Default Caliper Carrier Bolts:
Hey guys
Just to note, a lot of brake/rotor DIYs list the caliper carrier bolts a 16mm.
In process of brake install & caliper carrier bolts are an 18mm.
Unsure when this spec was changed. These suckers are seized on pretty tight. So be prepared w a breaker bar or impact to break free.
Anyone know if these are one time use bolts?
Thanks in advance !
Jump to top Exclusivs is offline   Reply With Quote
Old Mon, Dec-03-2018, 04:14:53 PM   #2
04yfz
Default Re: Caliper Carrier Bolts:
Originally Posted by Exclusivs View Post
Hey guys
Thanks in advance !
Caliper carrier bolts often have loctite, a little heat doesnt hurt to help break them free. Usually a breaker bar is plenty to loosen them up without issue or needing heat, I do not believe they are one time use.
Pat
Old Mon, Dec-03-2018, 04:39:49 PM   #3
bigjae1976
I just use a box end wrench and whack it with a hammer.
The bolts are reusable, not torque to yield. I donít think the BMW procedure calls for loctite but I use it. Not fun having one of those bolts back out.
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola Red
Old Mon, Dec-03-2018, 04:41:12 PM   #4
Exclusivs
Exclusivs's Avatar
Know the rear carrier bolts have factory green loctite on them. The fronts donít appear to; but sure feel so.
Breaker bar , still no go. Hesitant to use heat/in that general area because of sensor etc. May have no other choice
Old Mon, Dec-03-2018, 06:04:32 PM   #5
Exclusivs
Exclusivs's Avatar
Yeah, looking bit closer now. Believe there was life cycle change (2part #s)
That probably explains the 18mm head bolt now. Even w box wrench & hammer no go. PB no go. Guess need
Torch
Old Mon, Dec-03-2018, 08:31:54 PM   #6
lmtfi
lmtfi's Avatar
Sounds like someone didn't clean up the bolts/threads when they ware last out. Do that every time - no fail.
Just get a long-enough breaker bar on it and lean into it.
Old Mon, Dec-03-2018, 08:34:11 PM   #7
Are you 100% sure that your carrier holes weren't simply enlarged and (perhaps poorly) tapped for larger threads? I've never come across 18mm heads for those.
Old Tue, Dec-04-2018, 01:22:33 AM   #8
mrgizmo04
mrgizmo04's Avatar
IIRC, fronts are M12 18mm, rears are M10 16mm.
'85 528e 164k miles (sold)
'05 M3 6MT coupe
Old Tue, Dec-04-2018, 01:27:07 AM   #9
Kwakjoe
Kwakjoe's Avatar
Mine's 16mm for both front and rear
Old Tue, Dec-04-2018, 01:38:06 AM   #10
Exclusivs
Exclusivs's Avatar
Yes, 100% sure. Just removed , and not tapped. Extremely gummed up, yes.
Yep. 110% accurate.
Hence why I posted in my OP : most DIY's reported 16mm - I am here to confirm my fronts as well as GIZ & probably some other production models are an 18mm front.
In any event, thanks guys.
1/2" breaker bar needed for this.
Discussing Caliper Carrier Bolts: in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
