Old Sun, Dec-02-2018, 07:23:18 PM   #11
Mcap
Reputation: 0 Mcap is on a distinguished road
Default Re: Question on used Bilstein PSS10's
Ok I appreciate the feedback. So Koni Yellows with stock springs is a good route...
Jump to top Mcap is offline   Reply With Quote
Old Sun, Dec-02-2018, 07:28:44 PM   #12
Paulo M
Nothing wrong with wanting lowering springs for looks. Look into Dinan springs, should ride real nice and look great.
BREMBO APEX DIXIS
Old Sun, Dec-02-2018, 07:36:32 PM   #13
Mcap
Cool thx I sure will. I do agree that a better shock would be best if doing springs. My initial post was inquiring about Coilovers so would be nice to find a decent setup that doesnít compromise too much ride quality and not totally break the bank. Figured by the time I do a good shock and spring, maybe Iíll be close in price to an acceptable set of Coilovers. Maybe the KW V2s etc ?? Iím definitely taking all of your advice, much appreciated!
Old Sun, Dec-02-2018, 08:15:45 PM   #14
TheSt|G
Resident Curmudgeon
TheSt|G's Avatar
Isle of Man
Dinan springs raise the car. They are comfy though.
KW V2s aren't worth the money.
911 Journal/Build Thread
Old Sun, Dec-02-2018, 08:38:02 PM   #15
Paulo M
Raise the car from stock? I thought dinan lowers the car 1Ē all around.
BREMBO APEX DIXIS
Old Sun, Dec-02-2018, 09:38:00 PM   #16
Mcap
Can you make a recommendation for a good setup to lower car and keep similar ride quality for $1500 max budget?
Old Mon, Dec-03-2018, 12:20:36 AM   #17
mrgizmo04
mrgizmo04's Avatar
Back to original topic, I thought Bilsteins lasted a good 100k miles and were cheap to rebuild. At $500, even requiring a rebuild, might still be good value.
'85 528e 164k miles (sold)
'05 M3 6MT coupe
Old Mon, Dec-03-2018, 12:31:12 AM   #18
Mcap
Hey thanks for keeping it real. I can see what a rebuild costs and possibly try to negotiate the price. From what I read, theyíre a pretty solid, middle of the road setup in general.
Old Mon, Dec-03-2018, 01:27:05 AM   #19
TheSt|G
Resident Curmudgeon
TheSt|G's Avatar
Isle of Man
If you are fine with the rather washboard ride the car comes with, Koni Yellows with your spring of choice will work fine.
Bilsteins require modification to work on this platform.
Old Mon, Dec-03-2018, 02:50:35 AM   #20
ddaniel1
ddaniel1's Avatar
Reputation: 0 ddaniel1 is on a distinguished road
What are the modifications? My car had 5K miles on them when I bought it. They have worked fine for me but I have nothing to compare them to.
Rebuild is $225 per shock:
https://www.bilstein.com/us/en/techn...ledge/service/
Jump to top ddaniel1 is offline   Reply With Quote
Discussing Question on used Bilstein PSS10's in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
