Old Thu, Nov-29-2018, 08:56:59 PM   #1
M3Lyfe617
Reputation: 0 M3Lyfe617 is on a distinguished road
Default Square Setup Front Tire Size
I'm interested to know what front tire sizes guys are running for their square setup. I'm currently running stock sizes now, 265/235. I'm keeping the 265 rear as I have a 20mm and lowered. Any one see any issues with running 265s in the front as well?
06 ZCP | Macht Schnell Spacers 20MM | GC Plates | KW V1| E60 Shifter | Eibach F&R Sways | ZCP SQ. | Morimoto LED Fogs
05 X5 4.8is | H&R spacers 30MM | X-pipe | Lowered
| FOR SALE
Jump to top M3Lyfe617 is offline   Reply With Quote
Old Thu, Nov-29-2018, 09:07:02 PM   #2
Default Re: Square Setup Front Tire Size
What wheel width? 265 on a 9 or 9.5" et 20-30 is very common, but usually requires some neg camber depending on ride height, even up to -3.5.
_
Evolve-R Alpha N Evolve CSL CF Airbox Eventuri Scoop Supersprint V1 stepped 2.5" SS V1 S pipes 2.5" + 200 cell HFC OE sect 2 SCZA 2.5" sect 3 Besian RE pullies fan/SAP/washer delete CSL battery
Bilstein HD B6/Eibach 325/600lb + GC "tall" RSMs Hotchkis front sway (med) rear strut bar TMS camber & subframe plates Eibach alu rear camber arms RE trans mounts AKG poly subf/diff 95a SDW RTAB weighted ///M knob + ZHP alcantara boot + UUC DSSR + delrin bushing Mason clutch pedal + brass bushing TMS black pedals delrin brake pedal bushing
Old Thu, Nov-29-2018, 09:10:52 PM   #3
eacmen
I am on 18x9.5 ET35 square with 265 35R18.
I have Turner camber plates up front. -3 deg camber. No spacers.
Rear I run 10mm spacer just to make the stance the same as the front.
Jump to top eacmen is offline   Reply With Quote
Old Thu, Nov-29-2018, 09:12:43 PM   #4
M3Lyfe617
19' 9.5 ET27 (rear stock zcp) and I will apply spacers as or if needed. I'm lowered but not by much that would cause any issues
| FOR SALE
Old Thu, Nov-29-2018, 09:13:04 PM   #5
ggrslc
Reputation: 0 ggrslc is on a distinguished road
Duh... not enough information. Neither of your sizes were OEM sizes. Are your wheels 18Ē or 19Ē and what sidewall dimensions, ie., 30, 35, 40..... you need to help us out a little bit.
Jump to top ggrslc is offline   Reply With Quote
Old Thu, Nov-29-2018, 09:17:13 PM   #6
M3Lyfe617
I have ZCP wheels. Just bought two new rears for the front. Trying to determine if I could fit 265/30 in the front as well. Will start without spacers and go from there. Lowered about an inch from stock height. -2.0 currently in the front
Originally Posted by ggrslc View Post
Duh... not enough information. Neither of your sizes were OEM sizes. Are your wheels 18” or 19” and what sidewall dimensions, ie., 30, 35, 40..... you need to help us out a little bit.
| FOR SALE
Old Thu, Nov-29-2018, 09:23:14 PM   #7
You'll be fine if you have camber plates. If no plates, but you pull pins on stock hats, you might get away with it (with no spacers) - but maybe you'd need a higher ride height, not sure.
But anyway, plenty of people have done what you're asking about.
_
Old Thu, Nov-29-2018, 10:03:28 PM   #8
tjkenny15
tjkenny15's Avatar
Hey bro, just a tad bit of info, when I lived in Arlington and Tysons my front wide tire setup would really follow the groves of the road. Just food for thought. And I'm running 255s up front.
I'm not sure I'd go bigger than 255. The car will really dart around.
2005 BMW M3 INDIVIDUAL - Estoril Blue
Jump to top tjkenny15 is offline   Reply With Quote
Old Thu, Nov-29-2018, 10:26:46 PM   #9
LakerE46
Reputation: 0 LakerE46 is on a distinguished road
I run a 265/35r18 square setup. Tramelining is heavily dependent on alignment IMO - with 0 toe up front I have very little, but as soon as you add a little toe out it can get a little darty. Not unmanagable, but you have to keep your hands on the wheel
Current:
03.5 Silver Grey on Black E46 M3
Suspension & Braking
GC Race/Track Coilovers + Camber Plates + Rogue RSM
Turner Monoball FCAB / SDW Monoball RTAB
Brembo 355mm GT kit
Apex ARC8 18x9.5 ET 35 square + Michelin PSS 265/35
Engine & Driveline
SGT Headers - Custom rasp pipe - Modified OEM section 3
AutoSolutions 30% SSK - ZHP Knob - CDV Delete - Clutch Stop
ACT LWFW/Organic clutch
Past:
95 Nissan 240SX (S14)
14 Lexus CT200h
06 Range Rover Supercharged
91 Mercedes Benz 420SEL
05 BMW M3 SG/Black 6MT (RIP)
02 Saab 9-5 Aero
01 BMW 325I (RIP)
Jump to top LakerE46 is offline   Reply With Quote
Old Thu, Nov-29-2018, 10:27:45 PM   #10
ggrslc
Thatís a pretty nice (265x30x19) setup for the track. Be aware that the offsets are gonna be a little different than the OEM ETís and it may cause some unwanted issues. The 30 series tyres are great for the track but are getting a bit skinny for curbs and potholes. If youíre looking for reduced understeer and want to be able to move your tyres front to rear then I would suggest using 255x35x19ís with about 2.8 degrees front and about 1.6 degrees in the rear. If youíre spending about half your miles on the street you should get pretty even wear. Good luck.
Discussing Square Setup Front Tire Size in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
