Old Mon, Dec-03-2018, 04:35:28 PM   #21
nextelbuddy1
nextelbuddy1's Avatar
Default Re: Leather Swap on Front/Passenger Seats
just curious... if all you are doing is swapping the leathers from power seats to your manual seat bases..
whats wrong with just removing the seat leather/foam assemblies from the power seat frame? and then reinstalling the complete cinnamon leather/foam assemblies onto your manual base frames?
it should be a direct swap...
in the case you are trying swap the passenger side seat foam to the driver side then that means you are going to have to remove the passenger seat side leather from the seat foam to get to the SRS occupancy sensor to swap it over to the new passenger side seat foam/leather assemblies.
you can use needle nose pliers to expand each hog ring open so that you can save them and reuse them but you still need hog ring pliers to pinch them closed again. I use long 90 degree angle ones sometimes to help.
I bought a set of pliers and a bag of hog rings on amazon so i just use snps and cut all the rings out and use new ones. saves your fingers and some time.
ive done 3 sets of heated seat retrofits and have had to all of this numerous times. i hate it each time'its a slow grind process :/'
if you have any questions feel free to PM me or ask on here. happy to lend any advice that could cause less frustrations lol.
good luck
2003 ZHP 332i | S54 6 speed | M3 Conversion
Old Tue, Dec-04-2018, 08:12:05 PM   #22
conniem3
conniem3's Avatar
Reputation: 0 conniem3 is on a distinguished road
good luck
I realize I didn't word it right haha, when I say "leather only" I technically mean "leather and foam" lol. My bad. I'm doing a direct swap from driver>driver, passenger>passenger. I ordered my pliers + rings on amazon too, just waiting for it to come in now.
Thanks for all the help bud! Probably will be hitting you up each time I feel like rage quitting haha
2001 BMW IR/CIN E46 M3 6MT + Buildjournal B-Spec Tune
Build Thread / Album
IG: connie.m3
Jump to top conniem3 is offline   Reply With Quote
Old Sun, Dec-09-2018, 12:16:35 AM   #23
conniem3
conniem3's Avatar
Took me so long to realize how easy it was to remove this lever...
IG: connie.m3
Old Tue, Dec-11-2018, 06:57:27 AM   #24
conniem3
conniem3's Avatar
One out of 4 seats complete. This black one used to be on a manual base.
IG: connie.m3
Old Tue, Dec-11-2018, 02:32:25 PM   #25
Seems like passenger side has tilt forward holes on both sides of the seat, whereas the driver seat only has it on the outside. I'd assume this means the passenger side has holes in the leather on both sides whereas the driver only has a hole on one side... which would make them unswappable?
Old Tue, Dec-11-2018, 03:38:58 PM   #26
dutchhome
Reputation: 0 dutchhome is on a distinguished road
I'm pretty sure when I looked it up the part numbers were the same for both the seat back leathers as well as the seat bottom leathers for both passenger and driver.
Jump to top dutchhome is offline   Reply With Quote
Old Fri, Dec-28-2018, 05:17:53 AM   #27
conniem3
conniem3's Avatar
Update: the project has successfully been finished. DIY coming soon! Didn't need the hog ring pliers
IG: connie.m3
Old Fri, Dec-28-2018, 05:22:46 AM   #28
conniem3
conniem3's Avatar
The bottom foam assembly is the same for both seats. The back rest foam assembly is "technically" different for each side bc of the lever holes, but everything fits the same. You could technically use the driver side foam and cut an extra hole for lever on your own, but not vice versa for passenger>driver.
IG: connie.m3
Old Fri, Dec-28-2018, 05:57:44 AM   #29
vwrado
Reputation: 0 vwrado is on a distinguished road
Does the manual seats sit lower than the powered one?
03.5 M3 Dakar Yellow | CSL intake | TTFS Tune | Ground control coilovers
00 M Coupe
Jump to top vwrado is offline   Reply With Quote
Old Fri, Dec-28-2018, 07:04:40 AM   #30
conniem3
conniem3's Avatar
I think so, by maybe a quarter inch. Not too noticeable though IMO.
IG: connie.m3
Discussing Leather Swap on Front/Passenger Seats in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
