Old Fri, Aug-31-2018, 02:33:36 AM   #11
Bezugo
Bezugo's Avatar
Reputation: 0 Bezugo is on a distinguished road
Portugal
Default Re: HELP 04 M3 ticking under partial load/blip the throttle
Originally Posted by L0ADED View Post
Sounds like engine pinging. I've heard a few cars do this. The blip off idle click and the full load up hills between 2-4k rpm. Are you using 91 with ethanol or 93?
Posted this in another thread, but does it sound like this:
It only does it at partial load. If i apply full throttle, independent of revs, it does nothing.
I live in europe. I only use 98 octane.
Jump to top Bezugo is offline   Reply With Quote
Old Fri, Aug-31-2018, 05:41:55 AM   #12
HassanEido
HassanEido's Avatar
Lebanon
well it's not vanos rattle, since it would do that in neutral. Did you check ur oil filter for shavings?
Mods:
-Custom CF airbox
-Cat Cams 280 272.
-Custom dyno tune
385.7 whp 288 wtq
Old Sat, Sep-01-2018, 09:50:26 PM   #13
Bezugo
Bezugo's Avatar
Portugal
Could you guys hear the rattle/ticking sound on the driving video?
What do you think of it?
I've always thought it should be some kind of metal heat shield, but the sound has become louder and more frequent over time.
I have seen a few videos of Vanos rattle and it does not resemble any of those i have heard.
The last service was done about 5k kms ago at the bmw dealer. The rattle was present before and has remained.
I do have one (or more) brake dust shields that appear to rattle when i remove the wheels and try to move them around.
I always thought that was the cause. Do you believe it could still be?
My next step is to go to a shop. Lift the car and try to replicate the sound while someone could walk around to pinpoint it.
If that doesn't work, i'm going to a dyno. I'm sure there i'll be able to do it.
Old Mon, Sep-03-2018, 02:32:59 AM   #14
CSLM3Wannabi
Belt tensioner?
Chain guide?
2005 BMW M3 ZCP Nardo Gray | ESS VT2-550 | Dinan Throttle Bodies | 6MT Swap | Active Autowerkes Headers + Section 1 w/ 100 cells | Miltek Section 2 and 3 | KW V2 w/ GC camber plates and Eibach Front and Rear Swaybars | Porsche 996 BBK upgrade w/ OEM ZCP rotors | Umnitza V4 Angel Eyes | Euro bumper w/ Morimoto led fogs | 1 piece Carbon Lip | VIS XTS Full carbon hood | SCZA Carbon Fiber CSL Trunk | Carbon Fiber CSL Diffuser | Square ZCP Wheels |
Old Mon, Sep-03-2018, 04:21:36 PM   #15
Taxsonu1
Reputation: 0 Taxsonu1 is on a distinguished road
If you live in so cal you should bring the car to my home. I will diagnose it for you for free. And we can see everything else that's going on with her at the same time.
Jump to top Taxsonu1 is offline   Reply With Quote
Old Wed, Oct-31-2018, 05:12:22 PM   #16
Bezugo
Bezugo's Avatar
Portugal
I found these videos where they say it is a blown head gasket.
The sound is exactly the same.
What do you think?
Old Wed, Oct-31-2018, 05:14:48 PM   #17
Bezugo
Bezugo's Avatar
Portugal
Originally Posted by Bullbar View Post
Head gasket. Do a compression and leakdown test to be sure.
Apparently you are right!
Thank you
Old Wed, Oct-31-2018, 05:16:18 PM   #18
Bezugo
Bezugo's Avatar
Portugal
I would for sure, but my car is on the other side of the pond.
Thanks anyway
Old Thu, Nov-01-2018, 03:10:49 AM   #19
mrgizmo04
mrgizmo04's Avatar
Thanks anyway
So have you run a compression test to confirm head gasket?
'85 528e 164k miles (sold)
'05 M3 6MT coupe
Old Thu, Nov-01-2018, 07:13:53 PM   #20
Bezugo
Bezugo's Avatar
Portugal
I haven't, but will do as soon as i get home. I'm the US right now.
I'm fairly confident i have the right diagnose by now because after watching videos and reading descriptions of headgasket failure it all matches my symptoms.
I have a slight fluttering idle sometimes.
The sound i hear is apparently called pinging and all descriptions of what conditions make it ping match with mine.
From M3cutters:
Greetings,
I've been suffering some mild pinking at low to medium loads (on the throttle) in almost any gear above 2nd between 2000 - 3000 RPM.
The pinking is much more noticeable when the engine is cold and going up a slight hill. When the engine warms up it is more pronounced during light to medium throttle e.g. Climbing up a hill on the motorway around 70MPH.
Things I've tried:
1. Different grades of fuel (Shell Saver, Shell Super, Texaco, Tesco Momentum....)
2. Changed spark plugs to NGK Iridium (previous were Bosch)
3. Compression test (un-calibrated gauge from what I can tell)
The compression test reveals that Cylinders 1 to 4 are all consistent with one another. Sadly though Cylinder 5 and 6 are both more than half the pressure lower than the other cylinders. When cranking the engine with the compression gauge in either 5 or 6 a noticeable sound of air escaping can be heard.
Question:
Is this a clear enough sign that the Head gasket has failed between cylinders 5 and 6?
Other potentially linked observations:
The engine is relatively quiet no tappet like sounds.
Idle is not as smooth as I'd expect from a 6 cylinder (my e36 325i coupe is dead smooth when idling), this M3 feels like it goes through short phases of deep rumbles and light missing during idling (what you might expect from an older diesel car).
Car starts first time with no issues, no engine light (MIL), misfire codes only appear if someone has red-lined the car in 1st gear not realising their in manual mode (SMG) (checked codes with INPA).
https://forums.m3cutters.co.uk/threa...ailure.150528/
Discussing HELP 04 M3 ticking under partial load/blip the throttle in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
