Old Wed, Dec-05-2018, 03:22:17 PM   #21
zaharias
Greece
Default Re: knocking noise after cold start
Could this be a faulty Vanos pressure accumulator?
Jump to top zaharias is offline   Reply With Quote
Old Wed, Dec-05-2018, 06:14:44 PM   #22
Cmamainer
Reputation: 0 Cmamainer is on a distinguished road
I changed this and in my case it made no difference.
Jump to top Cmamainer is offline   Reply With Quote
Old Thu, Dec-06-2018, 12:22:05 PM   #23
mpwr92
Reputation: 0 mpwr92 is on a distinguished road
Problem in the actual Vanos unit I rebuilt mine twice changed accumulator change solenoid
Changed internal pressure valve still resulting in 800psi of pressure no fault code just poor downlow mid performance and extremely rattley only on cold start brand new Vanos solved it must be worn bores or blockige check your Vanos pressures first.
Jump to top mpwr92 is offline   Reply With Quote
Old Sun, Dec-09-2018, 01:09:52 PM   #24
Andy2424
Reputation: 0 Andy2424 is on a distinguished road
Germany
Please check the exhaust pump
Sorry my englisch is bad
Jump to top Andy2424 is offline   Reply With Quote
Old Sun, Dec-09-2018, 01:44:58 PM   #25
TropicalM3
Reputation: 0 TropicalM3 is on a distinguished road
Jamaica
Do you think a stretched timing chain could cause this? Reason y I asked, when i did my hub change and was catching the timing, for the life of me I couldn't the timing marks lined up 100%(when 1 side is lined up the other side was out a bit) and I figured maybe my chain was stretched. So on cold start up it would take more time for the timing chain tensioner to build the right pressure to take up the extra slack. What you guys think? Makes sense?
Jump to top TropicalM3 is offline   Reply With Quote
Old Sun, Dec-09-2018, 02:14:50 PM   #26
zaharias
Greece
Don't think it's related to this.
I changed the chain tensioner in June (no difference) and did a full Beisan Vanos refresh 1.5 year back. Ive done around 15K kms since the vanos repair. That cold start sound started a year after the vanos repair and around 10K kms.
Old Sun, Dec-09-2018, 07:45:04 PM   #27
Arehman
Arehman's Avatar
Reputation: 0 Arehman is on a distinguished road
Pakistan
My issue ended up being the rod bearings. Changed those noise gone. A couple were down to the copper. My noise was consistent though, you could hear it at low rpms. caught it just in time before they spun.
2002 AW/IR 6spd coupe
Jump to top Arehman is offline   Reply With Quote
Old Wed, Dec-12-2018, 12:51:18 AM   #28
E46Hoonigan
E46Hoonigan's Avatar
Reputation: 0 E46Hoonigan is on a distinguished road
Mine still makes this noise only on really cold mornings and my rod bearings have about 7k miles on them. I think its just take a second for oil pressure to build when its cold.
Edit: Looks like I already replied to this thread a while ago lol.
Instagram: sid_e46
CarbonBlack/Cinnamon E46 M3
Koni/Vogtland, Apex ARC-8 18" Square/PS4s, Powerflex, Megan Racing Sec. 3, WPC Rod Bearings, CSL Diffuser, ECS OCC, Besian VANOS, Mishimoto Electric Fan, 3.91 Gears
Alpine White/Sakhir Orange F10 M5 Comp
Stage 1 Vargas Turbo Upgrade
Jump to top E46Hoonigan is offline   Reply With Quote
Discussing knocking noise after cold start in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
