Old Tue, Sep-05-2017, 03:32:52 AM   #11
tomj87
Reputation: 0 tomj87 is on a distinguished road
Default Re: knocking noise after cold start
Thanks for the feedback.
I agree with arehman, I think is is somehow related to the oil pump/pressure. The noise goes away as soon as the red oil pressure light goes out.
@e46hoonigan and e36sport: did u check/replace/rebuild the oilpump as well when u changed the rod bearings? Did the noise change after you replaced the rod bearings?
@Cuz5150: Good point! Thanks! I will check tomorrow how much oil I have left in my oil filter housing.
@redM3/4: red oil pressure light stays on for about 1-2 seconds. I watched a couple of videos on youtube when people start their M3s. It looks pretty much the same.
Thanks again for your help,
Tom
Jump to top tomj87 is offline   Reply With Quote
Old Tue, Sep-05-2017, 06:38:37 AM   #12
L0ADED
L0ADED's Avatar
It seems like your M3 is slow to startup in regards to the revs. If the battery is weak, it can cause a slow startup and might not build oil pressure as fast as one with a good battery with high cold cranking amps. Some people say that it could be from the VANOS building oil pressure (especially on cold starts where the car has been sitting for a few days/weeks).
Old Tue, Sep-05-2017, 10:39:25 PM   #13
Arehman
Arehman's Avatar
Reputation: 0 Arehman is on a distinguished road
Pakistan
Tom
OP does your car make this noise while driving? Or only on cold start?
2002 AW/IR 6spd coupe
Jump to top Arehman is offline   Reply With Quote
Old Thu, Sep-07-2017, 04:44:29 AM   #14
tomj87
@Arehman: no, the clicking only appears on cold starts. The clicking is completely gone as soon as the engine runs.
I uploaded a video:
Off topic: Btw, there is a "farting" noise (starting at second 8) which shows up from time to time. Does anyone knows what this is?
I opened my oil filter housing today. How much oil should be in this housing? There was probably 1" of oil in this housing.
Kind regards,
Thomas
Old Thu, Aug-30-2018, 02:08:37 PM   #15
zaharias
Greece
Any updates here?
Did you find what was this sound at startup?
Jump to top zaharias is offline   Reply With Quote
Old Thu, Aug-30-2018, 10:25:42 PM   #16
stogybear
stogybear's Avatar
Reputation: 0 stogybear is on a distinguished road
Armenia
If I were to guess, I'd say it has something to do at the top of the engine. The reason the sound stops after a second or two is because oil gets to the top and muffles it. It might be a chain tensioner or something related to the chain.
2005 AW M3 - 6MT - Bay Area
Jump to top stogybear is offline   Reply With Quote
Old Thu, Aug-30-2018, 11:05:59 PM   #17
Cmamainer
Reputation: 0 Cmamainer is on a distinguished road
I have exactly the same issue before and after installing all the Beisan upgrades, however on his rattle procedure, he recommends installing new S62 hub springs which i didn't do. I'm going to try this next.
Jump to top Cmamainer is offline   Reply With Quote
Old Thu, Aug-30-2018, 11:22:27 PM   #18
zaharias
Greece
http://www.m3forum.net/m3forum/showp...1&postcount=26
Old Wed, Nov-14-2018, 06:20:04 PM   #19
zaharias
Greece
I think it's related to the oil pump..
Iam thinking of changing it in 2019.
Old Fri, Nov-16-2018, 03:33:58 PM   #20
zaharias
Greece
Sent my video to Raj (Beisan) and he told me "the cold startup rattle possibly being caused by a vanos solenoid valve body leaking valve."
Discussing knocking noise after cold start in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
