Old Sun, Dec-02-2018, 04:00:22 PM   #41
BTB
BTB's Avatar
Default Re: Bad paint/rust - touch up/respray panels or entire car?
Originally Posted by chatcher View Post
It's been said before and I know you don't want to hear it. This car is not worth paying someone else to fix. For sure if you DIY its ok but as soon as you start sinking thousands of dollars into having someone else repair the body work that money is gone. At the current age and mileage if you are in an accident whether its your fault or not the car will most likely be totaled (rust or no rust) Then there's ever increasing chance of major mechanical failure that could be the end for this car. Just drive it. Then on the weekends get yourself some bondo and sandpaper at Autozone and have a wack at it.
Probably a good call. Maybe I should just sand it all out myself, prime/rust protect it and get it wrapped. I really don't like the matte wraps though, I wonder how the gloss ones look.
I guess I am curious at how long the existing rust will stay put and not be an issue, given that I'll be in socal weather. I don't mind how the car looks, most normal people never notice it. The rust above the tail is really the most concerning
My Journal
Old Sun, Dec-02-2018, 04:21:57 PM   #42
KS Golfer
Reputation: 0 KS Golfer is on a distinguished road
garaunteed there’s twice as much under there that you can’t even see.
Jump to top KS Golfer is offline   Reply With Quote
Old Sun, Dec-02-2018, 07:24:06 PM   #43
M3An.M
Reputation: 0 M3An.M is on a distinguished road
Iím also going through the same thing my passenger rear quarter panel is bubbling and rusting and arch is now chipping and rusting unfortunately I was quoted $1,100
Jump to top M3An.M is offline   Reply With Quote
Old Sun, Dec-02-2018, 10:07:01 PM   #44
neopolymath
neopolymath's Avatar
Reputation: 0 neopolymath is on a distinguished road
Originally Posted by KS Golfer View Post
garaunteed thereís twice as much under there that you canít even see.
Yep. OP, you should be more concerned and acting on this since you have stated this car has sentimental values specifically. Time to act like it
Jump to top neopolymath is offline   Reply With Quote
Old Sun, Dec-02-2018, 10:13:11 PM   #45
FrankJones
Pyro Tech
FrankJones's Avatar
Reputation: 0 FrankJones is on a distinguished road
I would fix the rot so it does not get any worse and then wrap the car. If you are moving to Anaheim ca. 111 Ink in Valencia is who I go to. It’s around $2500 for most colors, and that includes the door jambs. Instant gratification, no over spray, and will at least protect what’s underneath.
04' Carbon Black, ZCP Rack, Autosolutions 40% SSK,
Evolve carbon roof, Evolve CSL Air Box, CSL Base tune, 280/272 Cams, SS V1 Header, SS sec 1,2, & SS Street, 3.91 R&P, JRZ RS Pro
Jump to top FrankJones is offline   Reply With Quote
Old Sun, Dec-02-2018, 10:18:26 PM   #46
BTB
BTB's Avatar
Yeah I was figuring around a grand
Itís pretty easy to tell where thereís rust, no? There would be some sort of texture if the metal was rusting underneath the areas of good paint..?
Originally Posted by FrankJones View Post
I would fix the rot so it does not get any worse and then wrap the car. If you are moving to Anaheim ca. 111 Ink in Valencia is who I go to. Itís around $2500 for most colors, and that includes the door jambs. Instant gratification, no over spray, and will at least protect whatís underneath.
Not a bad idea. Thanks for the reference
My Journal
Old Sun, Dec-02-2018, 10:42:33 PM   #47
neopolymath
I have done restoration. The rust you can see is the tip of the iceberg unfortunately.
Old Sun, Dec-02-2018, 11:19:00 PM   #48
BTB
BTB's Avatar
Default Bad paint/rust - touch up/respray panels or entire car?
Do you then believe that completely strip and respray or wrap are the only valid options?
I can believe that the rust will continue to grow and maybe appear in other areas, but to suggest that the rest of the car is absolutely no good seems a bit extreme..?
My Journal
Old Mon, Dec-03-2018, 02:33:25 AM   #49
neopolymath
I would strip and respray the car, but that is easy to say because I have the ability and gear to do so. I have nothing against wraps, but it's one of those things where you already did the hard work in repairing and stripping the car so why would you stop short of the finish line?
I did not say that the car is "absolutely no good" but that there is an incredibly high likelihood that there is more rust either in multiple other isolated areas or as extensions of the bad spots under the paint that just aren't visible to you.
Old Mon, Dec-03-2018, 04:47:22 AM   #50
bimmerdriver
OP, you really need to put the sentimentality aside and sell the car for whatever you can get for it. Maybe part it out. As others have said, the rust you can see is the tip of the iceberg. I've never seen any E46 this rusted. It's beyond economic repair. You are wasting your money to repair it.
Discussing Bad paint/rust - touch up/respray panels or entire car? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
