Old Wed, Feb-15-2017, 09:23:17 AM   #41
hemi8
M Power
Reputation: 0 hemi8 is on a distinguished road
Default Re: SMG Relocation to Engine Bay Side Comparment
USA hose supplier: http://us.helperformance.com/
Mike
2004 SMG M3, carbon black metallic w/cinnamon interior, OEM Euro Headers, Frank Smith engine & CSL SMG tuned, 300rwhp. Original SMG pump died @ 198k. Original clutch died @ 190k. Original rear diff. died @ 200k, driveshaft and axles shot @202k
Jump to top hemi8 is offline   Reply With Quote
Old Wed, Feb-15-2017, 02:17:25 PM   #42
SWRTstang_M3
Custom X
SWRTstang_M3's Avatar
Reputation: 0 SWRTstang_M3 is on a distinguished road
Mike
Thank you sir
  • M3 SMG (Stock) MartynT Tool SAP Delete TMS Power Pulley Kit TMS RSM Koni 1140 Sport Suspension Kit Powerflex Race Differential Bushings (F&R) ECS 80A Transmission Mount Set ECS RST Reinforcement Plates Michelin PSS Depo Smoked Corners
Jump to top SWRTstang_M3 is offline   Reply With Quote
Old Wed, Feb-15-2017, 03:50:43 PM   #43
Romad
Romad's Avatar
Reputation: 0 Romad is on a distinguished road
Thanks for the lead on a US supplier. Do these specs look right?
Fitting 1: M12 x 1.00 male swivel 90 - Pump side
Fitting 2: M12 x 1.00 female swivel straight - line side
Length: 78 inches each
Performance: Evolve Tuning, Highline Tuning CAI, Eurosport Pulleys, Delage 4:10 gears, SGT Headers with ceramic coating, SGT catted section 1, SGT resonated X Pipe, SGT SCZA 001, Suspension and Brakes: TCK D/A S/A, TCK camber plates, Hotchkis front sway bar, rear sway bar delete, Powerflex (RTAB, FCAB, Subframe), HPF subframe reimforcement, ZCP front conversion, Axxis Ultimates for street, Cobalt track.Wheels and Tires: 19 PIAA Superozzas custom painted CB to match body, Continental Ultra Contact DWS. Track related goodies: Recaro SPG XL, Schroth Profi, custom half-cage, interior stripped, Apex ARC 8 Continental.
Jump to top Romad is offline   Reply With Quote
Old Thu, Feb-16-2017, 09:19:15 AM   #44
hemi8
M Power
Thats what I ordered except I went with 75".
Mike
Old Fri, Feb-17-2017, 05:03:41 AM   #45
Romad
Romad's Avatar
Thank you!
Old Sun, Mar-05-2017, 10:21:41 PM   #46
Romad
Romad's Avatar
Mike,
Did you get this project done?
Mike
Old Mon, Mar-06-2017, 10:41:29 PM   #47
hemi8
M Power
Waiting for the hoses to show, I called them last week and they said were having website troubles. The owner said I should have them by Sat......nothing yet. When they arrive I'll post a couple pics. I also am designing a 1 piece bracket using CAD, but my time is really limited lately.
Mike
Old Tue, Mar-07-2017, 01:30:05 PM   #48
m3vos
Reputation: 0 m3vos is on a distinguished road
Mike
I am really curious to see what you come up with on the CAD, like I said I had just bought some steel plate at Lowes, cut it using some electric shears, and beat it over an anvil (decided low tech and not very refined!!!!). Are you going to have it CNC cut or something like that?
One issue I still have is that my reservoir mounting bracket is just a little (1.5 cm) too low. Even though the reservoir's fluid port is technically higher than the pump's fill port, the brake hose I have connecting the two has a slight rise in it, so I might have to remake my reservoir bracket.
Oh, and status update, after driving with this for a couple weeks, no heating issues on the pump. I live in Houston, TX, and we've had a couple of 87F-90F days, and even in bumper to bumper traffic in which the engine temp hit 210 on my dash gauge, I haven't had a problem with SMG at all.
I have noticed that after some spirited driving, in 90F conditions, that the pump does still get warm, but nothing like 212F (100C) at which it would shut off. I can still touch it, but it does feel warm. I don't want to guess, but if I were, I would say it's reaching perhaps as high as 125F (above that I think it would hurt my hand more). I will get a thermometer on it next day it gets hot and I can run the car hard.
Jump to top m3vos is offline   Reply With Quote
Old Tue, Mar-07-2017, 09:47:51 PM   #49
Distinct70
Distinct70's Avatar
Reputation: 0 Distinct70 is on a distinguished road
Someone makes a kit, I will buy it.
Jump to top Distinct70 is offline   Reply With Quote
Old Wed, Mar-08-2017, 01:25:59 AM   #50
AussieE46M3
Reputation: 0 AussieE46M3 is on a distinguished road
Hey Guys,
Just following on from a couple weeks ago. Guys has a 2004 RHD M3.
Swapped the pump the the LHS bin and states fluid temps dropped significantly. Supposedly was in the 70's in traffic and use to get kicked into neutral (89'+) on hot days. It now is yet to exceed 47'.
Some braided lines and a CSL reservoir is all it took. Plug had enough length to be redirected without any need for extending and supposedly an un-used stud for the factory bracket to hold the accumulator.
Jump to top AussieE46M3 is offline   Reply With Quote
Discussing SMG Relocation to Engine Bay Side Comparment in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
