Old Wed, Dec-05-2018, 09:52:40 PM   #101
Dr M3an M3
GroupBuyingPower@outlook. com
Dr M3an M3's Avatar
Default Re: SMG Relocation to Engine Bay Side Comparment
Originally Posted by RichBusta2 View Post
Great stuff!!! I read you guys a nearly finished with all the brackets. Have you come up with an overall kit cost to consumer, including reservoir and hoses?
Will update my thread with my reply so as not to spam this one.
IG: DrM3anM3
Mods: Genuine OE CSL Bumper, Both Karbonius and Streamline CSL Airboxes, OE CSL Snorkel w/ working Flap, OE Map Sensor + OE Air Rail, Paul Claude Custom Tune, CSL Engine management with CSL converted DME, Supersprint V1 Stepped Headers w/ Oversized HJS Race Catted section 1, SS 2.5" Twin-Piped Oversized Custom section 2, Custom Oversized Supersprint muffler, WPC treated rod-bearings, VinceBar (weld) + Redish Plates, Full Beisan VANOS lockdown, BBS LMs w/ PSS, Brembo GT6 (front) + GT4 (rear) BBK, CSL style CF diffuser, Vorsteiner CF CSL Bootlid, CSL SMG Engine DME tune, CSL '255' SMG DME tune, SMG Pump Relocated.
Camshaft Group-Buy, OE CSL Bootlids, Supersprint Headers/Exhaust thread, New Supersprint Oversized Twin-Piped Section 2
Old Thu, Dec-06-2018, 07:02:01 PM   #102
m3vos
Reputation: 0 m3vos is on a distinguished road
How about plans? Like a list/receipt from HEL and/or other parts purchase? basic design plans for the bracket? This would be remarkably helpful. I'm not good with nozzle and hose diameter sizing and all that jazz.
Thank you!
I pasted the order info that I used my lines in the OP at the top of this thread, but here it is again:
Hydraulic Lines
The pump uses 4 hydraulic lines, which following the video from BMWMazing, I ordered the same ones. The connectors are type 469 and type 716, both are M12x1.0. Here are my order details from www.probrake.de (be sure to click the UK flag in the upper right, it will show the site in English):
Custom steel braided hose, brake-hose clutch-hose, custom made according to your specifications
Shipping time: ca. 1-5 Days 4 39,95 EUR 159,80 EUR
190 cm 4 0,00 EUR 0,00 EUR
F1 type 469 4 3,00 EUR 12,00 EUR
Bare (no jacket) 4 0,00 EUR 0,00 EUR
F2 type 716 4 2,00 EUR 8,00 EUR
Fittings Black 4 0,00 EUR 0,00 EUR
Shipping Worldwide 1 9,95 EUR 9,95 EUR
including 19% VAT.: 30,30 EUR
Gesamtsumme: 189,75 EUR
Converted to USD, it was I think $215, and they shipped to my location in Texas no problem, just took a couple of weeks. The only issue I had was that I guess in Germany the street name comes before the street number, and their website auto-formatted the shipping address in a weird way. I just replied to their order confirmation email and gave them the proper shipping info and it got sorted out no problems.
Note that one end is the F1 type 469, which is M12x1.0 (male)
The other end is F2 type 716, which is M12x1.0 (female)
I got these off of the site: www.probrake.de
For the brackets, I literally just took pieces of card stock, cut them with scissors into sizes that would like up with the threaded holes in the side compartment and with the pump hardware threaded holes as well (with it just held in position), went to harbor freight, bought a pair of electric metal shears, home depot to get some sheet metal, traced out my patterns, cut them to fit, bent them on an anvil, and primed and painted them. It wasn't easy, physically, but the work wasn't technically challenging either. A few hours over a couple days with trips to the store in between :-)
Best of luck!
Jump to top m3vos is offline   Reply With Quote
Old Fri, Dec-07-2018, 03:51:49 PM   #103
RichBusta2
Reputation: 0 RichBusta2 is on a distinguished road
Well that is great, thank you for the info!!
Jump to top RichBusta2 is offline   Reply With Quote
Old Wed, Mar-27-2019, 09:00:36 PM   #104
JohnVu
Reputation: 0 JohnVu is on a distinguished road
Hey everyone! Sorry for reviving this thread but I just wanted to get some opinions on reservoir options. I have an 02' so I will have to fabricate to accommodate the ABS system. On other issue I have been dealing with is what fluid reservoir to go with. I have considered using the CSL one but I am not sure if it will event fit. So does anyone know what minimum capacity for the reservoir is? I have seen that the CSL reservoir is about 150-200ml but would something in the 100ml (3.2oz) range work? A lot of clutch reservoirs and brake master cylinders are around this range but I am worried it wont be enough.
Here is a link to a reservoir I have been thinking about: https://www.aircraftspruce.com/catal...hp?recfer=4849
Thoughts? Thank you!
Jump to top JohnVu is offline   Reply With Quote
Old Wed, Mar-27-2019, 10:28:59 PM   #105
zivagolee
@zivagolee
Reputation: 0 zivagolee is on a distinguished road
You can use something like:
http://tiltonracing.com/product/remo...ervoir-716-20/
2003 Orient Blue M3
https://www.instagram.com/zivagolee
Jump to top zivagolee is online now   Reply With Quote
Old Thu, Mar-28-2019, 04:20:47 PM   #106
JohnVu
Originally Posted by zivagolee View Post
Thanks for the quick response and recommendation! I have been looking at reservoirs like that but my only concern is that the outlet will sit lower than the inlet on the SMG pump. Should I be worried about air being trapped in the line?
Old Thu, Mar-28-2019, 04:38:21 PM   #107
zivagolee
@zivagolee
Not sure how you are going to mount your pump but this what mine looks like (VT Motorworks fabíd me one):
2003 Orient Blue M3
Old Thu, Mar-28-2019, 07:57:25 PM   #108
JohnVu
That's the Wilwood reservoir I've been seeing but worried about since the outlet was at the bottom. Is your outlet point lower than the inlet point on the SMG pump? If so, and I am assuming yours is working fine, it doesn't seem to be a problem.
Old Thu, Mar-28-2019, 11:18:16 PM   #109
zivagolee
@zivagolee
The pump is below the output point of the reservoir. If you need better pictures, I can take some closeups when I get the car back.
I havenít had issues at all and everything works fine. Been to a few trackdays and havenít had to worry about heat anymore. I like the clear reservoir since I can now see fluid levels without taking off the cap. My shop did mark the reservoir differently telling me when it was full (like half the reservoir).
2003 Orient Blue M3
Old Tue, Apr-09-2019, 08:55:33 PM   #110
Distinct70
Distinct70's Avatar
Reputation: 0 Distinct70 is on a distinguished road
Did anyone have bleeding problems? Anyone have to run the bleeding process many times and it not pressurize properly?
Jump to top Distinct70 is offline   Reply With Quote
Discussing SMG Relocation to Engine Bay Side Comparment in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
